Lamp Door I did see the handle,I'll take a pic and send it to you tommorro. Thanks
  • 51 Answers
No problem.
Posted on Sep 09, 2008
Trying to get at the door linkage,cause my passenger side manual sliding door on 2001 mantana will not open,so I want to take the panel off but im not to sure how to go about it..(sounds like everythings...
you must remove the screws along the bottom of the door panel. you must remove 2 screw in under the door "arm rest" (they're toward the front) you MUST remove the metal clip behind the window crank (those with pwr w/l dont have to worry about this step obviously) to do this: you can try to use a thin towel. placing it between the panel and the thin black disc and pulling in a teeter-totter motion. HOWEVER, the best and easiest way to do this is to get ahold of the tool made to do this. it can be picked up at most local auto stores. Or if you live near a best buy or other stores that does installations, tell them you are having trouble getting them out and ask them to remove them for you. (they have a Snap-On tool for this and it works like a CHARM!!) once the metal clip is removed pull the window crank off once you have the bolts and screws removed, you need to go along the edges of the door panel with a long screw driver or your hands and seperate the panel fromm the door (there are several push-pin that hold it to the door) then lift up and out slowly. you'll have to move it around the door handle. before you try to complete take the panel off, UNHOOK the speaker wiring (and power doors/locks if you have them)
to put the panel back on, basically repeat the steps. the first thing you need to do is put the panel back on by starting at the top where the window comes out. there should be a groove that the door rests on. then line up all of the push-pins with their holes (and connect any needed wires) put the bolts back in under the arm rest, and along the bottom of the panel, then the window clip. (this may take a few attempts, but you'll get it)
Kindly rate me If you like my answer.
May 23, 2011 | Pontiac Montana Cars & Trucks
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
Why I can't see tex pics in my phone?
Your thought is very correct,
There is no mush trouble to be think about the way out to solve your phone problem is that you need to contact your service provider to send you your setting on your MMS or they should do the setting from their office .
please note, if the setting is send to you, you have to save it on your phone so that you will be able to send and receive your pics
Good luck and thanks for using fixya.
Mar 20, 2010 | Cell Phones
Sony kdf e50 a60 when TV is turned on picture goes off almost immedately and red light starts blinking in stand by mode.
Red light blinking is an indication of lamp problem. Check and secure tightly the following:
  1. Outside lamp cover
  2. Lamp door
  3. Lamp
If all of the above does not solve the problem, you need to replace the lamp. Let the lamp to cool for 30 minutes after unplugging. Use XL-2400 replacement lamp.
  1. Remove the outside lamp cover.
  2. Remove the lamp door.
  3. Pullout the lamp
  4. Hook a finger through the loop of the lamp handle and pull the handle upwards. Then pull the lamp straight out.
  5. Mount the new lamp securely.
  6. Reattach the lamp door. Turn the knob back to "CLOSE" and secure the cover.
  7. Put the outside lamp cover back in its place.
or visit
Aug 11, 2009 | Televison & Video
Handle doesn't return to upright position
Send a pic to
I'll get you one.
May 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Power door lock switch replacement
Remove or Disconnect
Door handle trim plate.
  1. .Install or Connect
  2. Electrical connector and door lock cable.
  3. Trim panel by engaging hooks on backside of panel.
  4. Push pin fastener in defroster duct.
  5. Screw from behind lamp assembly.
  6. Courtesy lamp assembly.
  7. Two screws in arm rest.
  8. Arm rest cover plate.
  9. Door handle trim plate.
There May Be A Need to Drill Out RIVETS that Hold Motor in place,. Just Replace with>>MACHINED SCREWS & BOLT'S
  1. Trim panel. See: Doors, Hood and Trunk\Doors
  2. Four tabs retaining switch.
  3. Electrical connector.
Install or Connect
  1. Electrical connector.
  2. Snap switch into trim panel.
  3. Trim panel.
Mar 14, 2009 | 2000 Buick Park Avenue
How to install exterior door handle on 95 Safari Van
hi, remove the entire door interior panel, keep notes and diagrams as you go, even take pics, usually the exterior handle is secured by 2 small screws or nuts, undo these and the handle will detach . there will be a small rod connected to this handle by a small clip or similar. reassembly is a reversal of the entire process, just take your time
Feb 11, 2009 | 1999 Chevrolet Silverado 1500
No pic...humming noice on 62'' toshiba dlp
was the lamp blown if it was blown you could be hearing the ballast
if the lamp was not blown and the new one did not fix it the red light indicates the door there is a little switch when you put the door back on if you look at it it may need to be adjusted so it will connect with the door if that is not it you could have a fan that is not turn if it is making a real loud constant humming noise while it trying to fire the lamp you probably have a bad color wheel
Nov 19, 2008 | Toshiba 62HM95 62" HDTV
Lamp Door
open will see the handle of the lamp..I have a few RCA's in here but they have the doors o the back...can you send a picture?
Sep 09, 2008 | Televison & Video
No pic and shuts off
If the housing of the door comes open you will lose the sound and picture almost instantly. Have you replaced your lamp in this tv it sounds like the life on your lamp is coming to an end.
Oct 15, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Televison & Video Logo
Top Televison & Video Experts
