Question about Brother IntelliFAX 4100 Laser Fax
Black lines on incoming faxes
I can not figure out what to fix on this. I have recently changed the drum and that fixed the problem for a couple days, but the black lines are back. At some points you can not even read the faxes that come in.
Please help
    Genius:
  • 2,120 Answers
Pull out the drum cartridge. There should not be any toner on it.
(it could be defective [drum cleaning blade] especcially if it's a refilled unit.
There might be a small blue tab on top of the unit that you can slide back and forth to clean the charge wire.
But then again, if you just changed the drum, it sounds like it's defective.
Posted on Sep 10, 2008
Incoming faxes are dark. They keep getting darker by each page faxed. Any ideas what could be causing this?
Open the fron cover & remove the drum.In the drum unit you will see a BLUE knob just move it right to left approx 20 times.
After that fix the drum back & try to copy.
If the problem is same change the drum unit as the cleaning blade of the drum has been damaged
Rate me if it was helpfull...
Aug 04, 2010 | Brother IntelliFAX 2800 Laser Fax
Incoming faxes have black line running through the centre
If it is just from incoming faxes and not from anything you print/copy then it is the sender's fax machine that is dirty. If everything you do has that line, try cleaning the scanner glass and corona wire.
Jun 09, 2010 | Brother IntelliFax-2920 Fax
We are getting black vertical lines on all...Can anyone help?
Have you changed the drum recently? This can indicate the drum needs to be replaced.
Jun 04, 2010 | Brother IntelliFAX 2800 Laser Fax
There are thick black lines down the incoming fax pages of our Brother Intellifax 2800. How do I fix it?
You need to open the front cover of the machine and remove the cartridge( drum and toner) On the tope right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Apr 08, 2010 | Brother IntelliFAX 2800 Laser Fax
Solid black lines on the right side of page
Try sliding the blue tab on the drum unit side-to-side. If that does not cure it, you need a new DRUM UNIT
Oct 02, 2009 | Brother IntelliFAX 4100 Laser Fax
PROBLEMS WITH CLARITY OF INCOMING FAXES /BLACK STREAKS DOWN ENTIRE PAGE/VERY HARD TO READ SOME OF THE INCOMING FAXES.RECENTLY REPLACED DRUM AND TONER/WHAT WOULD BE CAUSING THIS PROBLEM?
First, make a copy of something to determine if your machine is at fault.
Move the blue slider on the drum cartridge back and forth 10 times.
Oct 01, 2009 | Brother IntelliFAX 4100 Laser Fax
Lots of Black Lines through Paper...
BEFORE YOU CHANGE DRUM UNIT, TRY CLEAN EXPOSURE GLASS RIGHT UNDER THE DRUM UNIT-USE DRY WIPE CLOTH IF THIS WON'T HELP DRUM WILL BE NEXT STEP,ALSO YOU MIGHT NEED REPACED UPPER FUSER ROLLER. GOOD LUCK
Mar 16, 2009 | Brother IntelliFAX 2800 Laser Fax
2 inch black lines on left side of outgoing and incoming faxes and copies as well
Sometimes the drum cleaning blade craps out. Remove cartridge and inspect the drum, it should be clean.
Sep 12, 2008 | Brother IntelliFAX 4100 Laser Fax
Printing Faxes
try another drum unit.
Jul 02, 2008 | Brother MFC-8220 Fax
BLACK INK LINES ON INCOMING FAXES KX-FL511
It's time to change NEW DRUM UNIT..and that's why your Toner will Not Last Longer because unnecessary toner (the black lines) will be on the copy every time the fax comes or you make a copy.
Oct 01, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
94 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
