Question about Microsoft Xbox 360 Console
E 73 error code
I have a problem with my xbox 360 it will not work it only displays E 73 code as a error, how do i solve this problem?
  • 26 more comments
  • Anonymous Sep 09, 2008
    yea my xbox had the e74 error message and i had called microsoft and they had asked me the peoblem and they said thqat 1 red light isnt covered under the warranty so i had read the warranty and the warranty clearly sates any hardware falure is covered under the warranty so if ur having a problem with microsoft tel them this a general hardware falure and they will fix it
  • Anonymous Nov 10, 2008
    yea i got the error 73 prob with the one red light flashing on bottom right hand corner . i played not even an hour before when i tried to relog in thats what came up . called 18004myxbox and he told me to send it back to repair .
  • runner_jeof Nov 16, 2008
    i have e73 too idk why?
  • Anonymous Nov 29, 2008
    When I turn on my 360 the bottom right light flashes and has error code E 73
  • Mvp4eva Dec 02, 2008
    I read the problem is related with the XBOX 360 ethernet port as I'm also stuck with an error 73 and with one red annoying light
  • gamer2104 Dec 09, 2008
    iv had to live with this problem FOR A WEEK AND A HALF im so pissed off how do i fix it AND QUICKLY!!!!!!!!!!!
  • hab3146 Dec 22, 2008
    I just turn on the console and it just says E 73 what can I do to fix this??
  • Anonymous Dec 25, 2008
    I have the same problem one light flashes red and says e73
    is there anyway to fix this yourself?
  • wyldcard3791 Jan 16, 2009
    lower right red light flahes and the E 73 error code shows up
  • Anonymous Jan 24, 2009
    i have the same problem you should call them or go to xbox,com/sopport were you can find there number
  • don dyablo Jan 24, 2009
    i have error e73 how can i fixe the problem
  • Anonymous Feb 16, 2009
    my xbox come up with red light then e73 message
  • shawnanana76 Feb 16, 2009
    I have the same error code. e 73. The bottom right light flashes red. How do I fix this without sending it to India?
  • PsychoBob Feb 17, 2009
    lower right red light with e73 code 1 month after warrenty expired. sigh :(
  • stephen1151 Feb 18, 2009
    i had fixed error e-74 and got to play the xbox360 for about three ours and then it went to error e-73 how do i fix this
  • Anonymous Mar 07, 2009
    bottom right flashing light, av cables and hard drive all ok ( checked with others),
  • chris mace Mar 07, 2009
    my bottom right light keeps turing red what do i do
  • Anonymous Mar 28, 2009
    Xbox 360 console error red flashing light with error E 73
  • Anonymous Mar 29, 2009
    one red light E73 comes up and disk drive struggles to open
  • Anonymous Apr 16, 2009
    either it is a power surge ethernet port or AV cable i tried every temporary fix and nothing
  • Anonymous Apr 18, 2009
    i turn it on and it just shows that and ms says it will cost like 140$ to repair. :(
  • Eddie_505 Apr 22, 2009
    I have a problem with my xbox 360 it will not work it only displays E 73 code as a error so what is the Problem.
  • Domintor1294 May 04, 2009
    My ethernet cord is working fully but its the port you plug it onto that is messed up and i dont know how to get it fixed i entered a repair order but nothing happened
  • gallardo6065 May 05, 2009
    yah got the problem too it sais e73 contact customer support and its the rrod (red ring of death).
  • joe_mpk May 06, 2009
    same problem...does anybody have any idea to fix it? let me know..thx :p
  • Anonymous May 09, 2009
    lower right quadrant light flashes and e73 appears
  • zeekay26 May 20, 2009
    got an error E73 one day out of now where and that too just as soon as i had turned the xbox on. contacted the ms helpline. they told me its not covered so i will have to pay. i agreed. then they said someone will be in touch with me regds confirming my address. later i get a call from their side and the person tells me that they will replace the box free of cost since E73 is a type of E74. i was ecstatic. however, once i tried to ship the box to ms, they refused to give me a free replacement and backtracked on what their own rep had told me. so i got furious and started looking up E73 on google and her i am venting my frustration...
  • Anonymous May 23, 2009
    man if u get this it sucks
Try this, I saw this on a u-tube vid, and i can't believe it worked. Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on. Like I said it worked for my system and I hope it works for all of yours out there.
Posted on Mar 23, 2009
    Problem Solver:
  • 15 Answers
Please don't use solution number 2 its a temporary fix and will ruin your system. If you don't know how to open your system then you might aswell send it in, its cause by an internal issue and can be fixed doing a few things, they are not easy to do on your own. if its under warranty send it in if not find a repair company ConsoleMD is awesome and they have low prices they fixed mine with an e72 error
Posted on Apr 22, 2009
Another solution is to check your connection from your ethernet cord from your computer to your xbox and make sure it is ok and then if it is your ethernet input is broke and needs to be repaired and if your cord is broke just buy a new one my xbox just did that today 05/04/09
Posted on May 04, 2009
With the X-Clamp fix
this is due to the fact that the gpu is undergoing stress
(overheating)
when you apply PROPER thermal paste/grease
and new bolts from X-CLAMP FIX it will return your xbox to normal or even better than new
because micro$oft decided to use cheap paste that dries up and causes poor connect between the heatsync and GPU.. RRoD is the result of the CPU or both same problem.
im not a person that advertises that product
im just a normal person that had the same error
i used arctic cooling 5 its probably the best if not one of the best.
Posted on Jun 28, 2009
Solution #3 worked!!!!! try this!!!!it worked for me!!!!how??? dont know but worked!!
Posted on Jul 03, 2009
  • 43 Answers
The guest is true
Posted on Sep 13, 2008
Hi, I had a problem I did 3RROD clamp fix now me 1 red LED lights do not work any instructions. He could someone help me?
Posted on Mar 14, 2010
It has red light on the front and the screen says error 73
here is a webpage with some tips http://www.360errorcodes.com/xbox-360-error-73
also i you want to get it repaired go to craigslist.com and search up xbox repair
Jul 28, 2011 | Microsoft Xbox 360 Console
Hello my problem is in xbox 360 elite e 73 one light red
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 28, 2011 | Microsoft Xbox 360 Console
My xbox 360 has an e 73 error code. they say it a problem with the ethernet port.
Hello sir
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
Apr 19, 2010 | Microsoft Xbox 360 Elite Console - Black
E73 xbox
When turning on the Xbox 360, a red light would be flashing at the fouth section of the Ring of Light. You should then recieve a ghost screen indicating an error E 73.
You recieve a screen error E 73 and section 4 of the RoL flashing red. This type of error was caused by a General Hardware Error relating to the Ethernet Port not functioning correctly or became faulty and unable to operate even with or without an Ethernet Cable connected to this port. The secondary code would be identified as 1021 for faulty ethernet port. I believe that there is no fix at the moment. If you encounter this error, I would suggest call 1-800-4MY-XBOX or visit www.xbox.com/support
The specific type of hardware error can be determined by these hidden codes:
0001, 0002, 0003, 0010, 0011, 0012, 0013, 0020, 0021,0022, 0023, 0030, 0031, 0032, 0033, 0100, 0101, 0102, 0103, 0110, 0200, 0203, 1000,1001, 1002, 1003, 1010, 1011, 1012, 1013, 1020, 1021, 1022, 1023, 1030, 1031,1032, 1033, 1100, 1444 and up
More information about these codes and errors, visit this webpage:
http://forums.xbox-scene.com/index.php?showtopic=484726
  • Note: There is known to be a temporary fix for this problem but is not recommended if the device still has available warranty on it. Doing so will avoid it's warranty, thus for you will pay $100 if sent for repair.
The Sticks Method:
  • Requirements: Xbox 360 (Power Cable and Composite/Component/HDMI Cable), two sticks (Like toothpicks, swabs)
1.) Turn off your Xbox 360 and unplug everthing.
2.) Get two sticks (Something like toothpicks or something that could fit in the back of the Xbox 360.
3.) Insert each stick to jam the two fans at the back of the Xbox 360 to prevent it from spinning.
4.) Plug back cables (Power and Cable connecting to TV; the RRoD will not appear unless the cable to the TV is connected).
5.) When RRoD appears (One Red Light), wait for about 10 to 15 minutes or maybe less for the Xbox 360 to overheat.
6.) At this point, you should get two red lights (Resembles Overheating Error) so remove the two sticks so that the fans will spin in an increased speed. After a few seconds, the Xbox 360 will turn off to cool down (RRoD will still appear).
7.) Unplug only the cable connected to the TV. You can unplug the power cord if you want to. Then let it cool for about 30 minutes or so (Feel the Xbox 360 if it's cool or still warm)
8.) Replug all wires and turn your Xbox 360 on.
The Xbox 360 should now be able to boot to your Xbox Dashboard. I don't know how this fix works but it's only temporary. Note that doing this continually would cause it to now work even if you try to redo this fix again and again. Doing so would make other hardware components to fail permanently such as the GPU for example.
If this first temporary fix did not work, do the second method: The Towel Trick. You can find the tutorials in Youtube. Again, this is not recommended if you have warranty left and never do this continually. Your Xbox 360 would completely and permanently fail after that. if it doesnt help after all this....I suggest sending it to Microsoft for repairs
Apr 02, 2010 | Microsoft Xbox 360 Console
I have one red light on my xbox 360 elite with code E 73
https://www.yousendit.com/download/THE2b3BORkUrV3lGa1E9PQ.
hope this helps its two ebooks on how to repair red light error ,full instution plus pics show u how.this download is only there for 7 days or 100 downloads.DT
Feb 23, 2010 | Microsoft Xbox 360 Elite Console - Black
Xbox 360 system error 73
E73 is the scaler chip and that deals with the display on your Xbox 360 you will need to get it fixed and you can send it in to do this or repair it yourself using a good guide.
Jan 04, 2010 | Microsoft Xbox 360 Console
Xbox F73 Fault
E73: I/O Hardware Error - Couldn't calibrate HSIO Bus from edram: this error is likely caused by a problem with the Ethernet port or supporting control devices
Jul 12, 2009 | Microsoft Xbox 360 Console
Xbox E 73 error
Hi Brett,
FYI. the 3yr extended warranty only applies for the 3RED LIGHTS and E74 issues only..if the console is already in the service center,you dont have to worry anymore,microsoft technicians will surely work hard to get it fixed. just wait 2-3weeks for the whole repair process,and you& your son will enjoy playing xbox in no time. :-)
May 15, 2009 | Microsoft Xbox 360 Console
Xbox 360 error 73
Sometimes the easiest way is the fastest way. The signal reset button (the little one to the left of the power button) is also the unofficial reset button for the Xbox 360. With the Xbox turn off, press this button and keep pressing it while you press the power button. Do not release the reset button until you see the system booting up normally. Of course, if there is a permanent or a more serious damage to the system, it won’t work or the error will be recurrent until it is solved. Resetting just clears the error from memory.
Dec 09, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
17,334 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
