Question about Kyocera Copystar CS-1820 Black and White Copier
KYOCERA CS-1820 ERROR CODE C7990
Do you have any suggestions for the above error code?
  • 38 Answers
Apologies for the late reply. This is a waste toner full problem. Pull out the process unit (in case you don't know, it's the big black unit where you fit your toner into, also the one that you need to remove to check for paper jams. Turn it around so that the side where the toner fits is furthest away from you. Now on the side closest to you, on both the left and right hand side are two small covers, each fastened with 1 screw, hidden in deep holes. Remove these screws and covers, and empty the toner inside.
Be advised that this is a very messy job. Also, after you've removed these covers and you turn the unit on its side, the toner may not fall out. in this case stick a screwdriver or something in there to loosen the toner.
When done, refit the covers, place the unit back into the machine, restart the machine, and thats it. If the code still appears, you've got toner on the waste toner full sensor, which sits just above where the waste toner part of the process unit is, inside the machine. you can take a cloth and wipe this. although this is highly unlikely, nothing in this industry surprises me anymore.
if this still fails, you could have a faulty sensor or circuit board, but again, highly unlikely
have fun (nothin like gettin your hands dirty) ;)
Posted on Sep 18, 2008
Error occured call service person C7990
What to do if the current display is "Machine Failure Call Service C7990" but few days ago it displays "Toner Waste Box is Full".?
May 23, 2012 | Kyocera Copystar CS-1820 Black and White...
My photocopier has been displaying this error code message C-7990 a photocopier kyocera KM-1500
C7990 is
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
Mar 05, 2011 | Kyocera Copystar CS-1820 Black and White...
QUE DEBO HACER CUANDO ME PRESENTA EL ERROR C7990 Gracias DORIS RODRIGUEZ OSORIO
El error corresponde a "deposito de desecho lleno"; Sacas la unidad completa donde va el toner, colocas la pestilla verde donde la flecha indica cleaner, en cada lado lateral trae un tornillo en un agujero profundo, quitarlos y luego quitar las tapas pequeñas, vacias el contenido en la basura y listo.. (favor no hacerlo con ropa blanca porque queda negra)
Jun 21, 2010 | Kyocera Copystar 1820 Grayscale Copier
Kyocera cs 1820 or copystar = error message = 3200
3200 is a problem with the exposure lamp. If you are in a dirty enviroment, the problem could be dirty mirrors under the scanner glass.
Apr 02, 2009 | Kyocera Copystar CS-1820 Black and White...
KYOCERA copystar CS-1820 ERROR C6000
Your problem is heat related, or the lack of heating at least. one of 2 things went wrong here... either the fuser unit overheated causing the thermal fuse (aka the thermostat) to blow, or the heating lamp in the fuser unit is blown. Basically the 6000 code is displayed when your machine fails to reach the correct temparature at a specific time. Unfortunately you will have to call a service person to check which to of the mentioned components are at fault and to replace that component for you. After replacing, the component the code will still be displayed as a safety measure, so the service representative will need to clear the code via the machine's service mode
Sep 22, 2008 | Kyocera Copystar CS-1820 Black and White...
Kyocera Copystar CS-1820 Black and White Copier Logo
13,571 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
