Question about Philips 32PFL7332D 32 in. LCD HDTV
PHILIPS HDTV Model 37PFL5522D/05
MY PHILIPS HDTV Model 37PFL5522D/05
Suddenly made a loud 'POP' noise, smoked a bit then flashed and went AwOppaloOOOlaloOo!
Now its dead as a Doughnut!
I suspect the inner Power Supply has wacked out?!
If so, where can i get a replacement??????!!
Liverpool UK Area
Thanx -
R o b b i e
racer7x
  • 42 Answers
SOURCE: Philips 47PFL7422 Flat Screen no power
Check the main fuse
If that is ok look for puffed up capacitors on the power supply
Check the 1000ufd @ 35v change them to 1000uf @ 50volts
Good luck
Posted on Feb 08, 2009
D_LLAMA
  • 6 Answers
SOURCE: NO POWER ON PHILIPS 42PF9966/37
I had the same problem with a philips 42FD9932 and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Posted on Mar 03, 2009
  • 146 Answers
SOURCE: I tried turning my Philips Flat Tv by pressing the
Unplug your unit for 5 minutes and plug it back in - turn it on - if problem persists then your TV's power supply is finished.
No it is not your circuit breaker or fuse otherwise you would not get ANY power to your outlet and would not see a blinking light. It sounds like a bad power supply.
This is may cost you a lot of money to repair - I hope your TV is under warranty.
Posted on Sep 20, 2009
jnash_21
  • 32 Answers
SOURCE: plasma TV went dead after a loud pop. What part is the likely pr
fuse
Posted on Jul 01, 2010
SOURCE: Philips Power supply flashes 5 times
one day not start his open. stan by red led and after switch on ,his green bligkig is not open.sound is ok.(the relay his not click)
Posted on Sep 04, 2010
How do I change my tv to hdmi without remote
press mode and then either channel or volume button thenit should work
May 13, 2015 | Philips Silver Tilt/Tilting Wall Mount...
How to resert colour on philips tv model 37PFL5522D/05
there will be an option on your controls that allows you to reset.
go to colour
select factory default
Aug 12, 2013 | Philips Silver Tilt/Tilting Wall Mount...
Watching the TV heard a loud pop picture went blank and smelled a little bit of smoke.
The first and most likely cause is that your lamp has blown. Simply remove it and inspect when they have blown its really easy to tell. Remove lamp door with a philips screw driver. The door is located I believe on the back of the set towards the right side. Once the lamp door is off there will be 1 maybe 2 screws holding the lamp assembly itself in place. Remove those then the housing should slide right out. The lamp number is 915B403001 for that model.. Good Luck!!!
Dec 02, 2010 | Mitsubishi WD-65735 Television
Loud pop, smoke and screen went dead
Your mainboard is damaged, just replace it and that will fix it.
Jul 01, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
When I was watching the tv it suddenly started to flash off and on and then finally will not even turn on
Watching tv all of a sudden loud buzz noise,I shut off unit turned back on loud buzz came back about 30 seconds later loud pop pop then smoke came out of top of unit, i'm not please as this unit i bought about 17 months ago @ Canadian Tire Belleville & warranty is now not covered, pobably will never buy another Proscan product but am more concerned there could be a fire caused buy this than getting unit replaced
Apr 23, 2009 | Proscan 19LA20Q LCD TV
No heat, rough idle then pop and smoke from coil pack 2001 caravan 3.3
YOu should be able to tell if coolant leaks caused the coil pack to fail. I believe it is 2 issues.
Oct 29, 2017 | 2002 Dodge Caravan
LG 50px10 loud noise & then color and image quality loss.
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
Apr 04, 2008 | LG DU-50PX10 50 in. Plasma HDTV
Philips 32PFL7332D 32 in. LCD HDTV Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
