I have a lexmark 3580 and it doesnt print i have it plugged in power on etc but when i hit the print button nothing happens
  • Anonymous Sep 30, 2008
    does not print when I hit the print button
  • 43 Answers
Good Morning :
Hope that you are wellJ
You may wish to uninstall and reinstall your computer software. This posting is aged, but I hope that you were able to find a solutions.
If I can be of further assistance, please let me know.
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful morning.
Posted on Sep 30, 2008
  • Sonja Perdue Oct 03, 2008
    Please don't forget to leave a comment or rate me.
    Thank you!
Power wont come on
Look for a reset button, inspect the cord and if it failed while on make sure whatever it uses for a filter is not blocked with dirt.
Dec 23, 2012 | Shark Euro-Pro Ultra Steam Blaster...
The remote doesnt work with the tv at all. and when i try to change the channel manually with the button it says no input availiable. but the volume button works just the channel button that doesnt. I...
UNPLUG THE SET FOR A WHILE AND PLUG IT BACK IN TO SEE IF IT WILL REBOOT-sounds like a microprocessor problem and could have been caused by a power outage etc.
Apr 01, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Lexmark C544dn laser printer just up and died - I had just put in new paper, hit print on my Mac and when nothing happened, I realized the machine was off. Yes, I checked the power cord at the machine...
Please try to do the following steps
• Check the AC line voltage. Is the line voltage correct? If not connect it to the correct line voltage
• Check if the AC line cord damaged. If damaged replace the AC line cord
• Is the LVPS cable correctly connected at JLVPS1 on the controller board? If not Reconnect the cable at JLVPS1
• Turn the printer off, and then on. Does the problem persist?
• Damage to the printer is possible. Be careful to touch only one conductor at a time, Rest the probe against the connector to steady it.
• Replace the LVPS - Low-voltage power supply (LVPS)
Please contact Lexmark Technical Support for further assistance.
Mar 26, 2011 | Lexmark C544dn Laser Printer
OK, following your advice of March 9th I got a new lamp from Mitsubishi and replaced it tonigh in my Mitsubishi rear projection model WD-62725 TV. The old lamp was clearly broken. However I have...
That sound may from the color wheel. Open the angine, open block front of lamp.
open cover of color wheel and grap it.
mas_baz_23.jpg Rotate color wheel manualy , listen it. If hear fristing sound, means color wheel is bad. Replace it too.
mas_baz_24.jpg Good luck.
Mar 24, 2011 | Televison & Video
2500 Lexmark won't scna
print an alignment page and scan that page.
it would work.
Jun 24, 2009 | Lexmark All-in-One Printer with PictBridge
No power on my Lexmark X8350
That's the same printer I have.
First, make sure the blue "copy" button is lit. Printing is done there.
Then, go to the circle with the checkmark in it and hit the menu, and arrow down to copy papy size and make sure it says "letter".
Click start on your computer, then click control panel, then printers, and make sure Lexmark 8300 series is the default printer and has a green checkmark in a circle.
If all these things are right, you should be able to print a test page and the computer should work fine.
If any one of them are wrong they must be corrected. If you need help on any one of those please write back.
May 14, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark x1270 printer power button blinking won't print
I had the same issue with my Lexmark X1290, I solved it by opening up the device, so the ink cartridges should pop, they didn't so I pressed the power button to switch it off, and then switched it back on (with the device open!) and all the paper flowed out, the flashing stopped and it could print again. Good Luck!
Feb 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
48 people viewed this question
