Sony Handycam CCD-TRV318 Hi-8 Analog Camcorder
Problem for Sony Handycam CCD-TRV318 Hi-8 Analog Camcorder
LCD won't project
By Fireslayer on Mar 22, 2006
When I turn the camcorder on to tape. I will get a flash of image on the LCD the it goes black with a white line running up the left side. it plays back all previously recorded tape and when taping now it tapes what I see, a black screen with a white line.
Same Problem
Sep 07, 2008
-   LCD show nothing but lines,it blise,it's seen like it stuck and everything .-   waldogreen
Best Solution
posted on Mar 27, 2006
Helpful)
eran
Rank: Wiz
Rating: 80%, 243 votes
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue.
To see if you have this problem:
Power On your camcorder (make sure the battery is fully charged).
Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible.
Put a tape in the camcorder.
With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice.
Rewind this section of the tape (using tape counter to verify start of your recording).
Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear.
If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Was this helpful?
Yes
No
Popular Solutions for Sony Handycam CCD-TRV318 Hi-8
Questions and Unsolved Problems for Sony Handycam CCD-TRV318 Hi-8
Do you recommend Sony Handycam CCD-TRV318 Hi-8 Analog Camcorder?
Answer
Answer
lcd works good, playback ect.. Put on camera screen is black like lens cap is on. will record... (More)
Answer
how to fix a sonytrv318 ntsc the tape went in half way and jamed after it was closed by me
Answer
I have a Sony Handycam CCD-TRV318 Hi-8 Analog Camcorder and I when I tried to view the tape, I get... (More)
Answer
When trying to play back, tape plays approx 5 seconds, then blue screen and the flashes C30:13 and... (More)
Answer
Have an older model. 80's or early 90's. Can't figure out how to hook it up to the tv and playback... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Handycam CCD-TRV318 Hi-8...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
