Question about Kenmore 44072 Front Load Washer
Kenmoore front wash - he detergent
I'm looking for Ivory Snow 'he' however there isn't any; is this detergent mild enough to use on this washing machine & if not what is my alternative?
  • 943 Answers
Hi. thanks for the question .I found some ivory snow on E_BAY. thanks the appliance doc
Posted on Sep 30, 2008
How to wash
Crystal should be washed with mild soap (like Ivory) and lukewarm water.
1. Line the bottom of your sink with a couple of dish towels.
2. Fill with lukewarm water and add *mild* dishwashing liquid.
3. Wash one item at a time.
4. Rinse with solution of lukewarm water and vinegar, 3:1 ratio.
5. Dry with soft cotton or linen cloth.
Items will spot if allowed to air dry.
Oct 05, 2012 | Washing Machines
Can chicco keyfit30 head support be machine washed?
From the Chicco Keyfit30 Manual:
Fabrics may be spot-cleaned with mild soap and water, or
machine washed in cold water on delicate cycle using mild
detergent. Hang to dry. DO NOT USE BLEACH.
- Marc
Aug 17, 2011 | Chicco Key Fit 30 (Atmosphere) Infant Car...
The soap tray fills with water at the back conditioner section on every run (no matter which programme) and does not drain, so I have to manually remove it and empty it after every load. I also think this...
Remove the detergent drawer by pulling it out and then pressing down the yellow part on the back of the drawer. Clean the drawer fully by hand in a washing up bowl using a mild detergent. Detach the yellow part from the grey part by turning it upside down and push in the clips gently. Clean the yellow part thoroughly. Put the yellow part back on - it just clicks back in place, and push your detergent drawer back in. Do an empty cotton wash at 85C (with no washing powder) to sanitise your machine.
Apr 13, 2011 | Dyson Memory CRO1 Front Load Washer
My Duet washer stinks so much. The wash does not come out smelling good. It is clean but it doesn't smell good. I do use those cleaning tablets but it still stinks. It has over-suds many times where...
I have found that using a l/4scoop of oxi cleaner any brand will do along with my regular wash detergent helps keep the odor under control . I leave my door open to the washer when not in use. Occasionally I will clean under the gasket with a mild cleaner. Remember the front loaders use less water and therefor less detergent. Good luck.
Sep 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Are all material parts machine washable?
Good question! "No" is the simple answer, but washing is easy nonetheless. Here is some more detailed, general advice about washing:
The fabric parts should not be machine washed. Instead they should be hand washed and do remember to use a mild liquid detergent, preferably a non-biological one, or mild soapflakes. Never scrub fabrics with abrasive material or strong detergent.
Always dry the seat naturally; i.e. on the washing line please note that some fabrics, especially navies, are prone to colour loss if abrasion is used during cleaning. You are recommended not to rub localized marking. Refer to the product instructions for washing method. Colour loss can also be caused by sunlight. Do not leave your product in direct sunlight unnecessarily. Never use a tumble dryer or try to dry in front of a fire, as the high temperature may cause damage to the seat.
Reinforced parts such as hoods can be soaked, rinsed well and dried, as per the seat. The carrycot can be sponged clean with mild soapflakes and excess water removed with a dry cloth. Allow to dry naturally.
May 28, 2010 | Bebecar Raider AT Stroller
I have a Creda W200FW. The rubber packing of the front door is full of black mold and smells bad. What kind of detergent is good to get rid of them. I have moved to a renging house and the washing machine...
Hi , Bleach will get rid of the black mold and stop it coming back for a while. Don't leave it on too long as bleach has a hardening effect on rubber. If you occasionally give it a wipe with a mild bleach based cleaner it will stop it coming back.
Jun 08, 2009 | Creda W100FW Front Load Washer
My machine stops at "delay start", yet the cycle is not complete.
PROBABLY NOT USING ((((H E DETERGENT) REASON FOR ERROR CODES,, POUR A SMALL AMOUNT OF COOKING OIL ON A SPOON AND POUR INSIDE SHOULD SOLVE PROBLEM
Nov 29, 2008 | Hoover AAA160 Front Load Washer
Kenmoore wont spin front end loader
won't spin on the spin cycle it just has a grinding sound
Sep 10, 2008 | Kenmore Elite 45986 Front Load Washer
Detergent Dispenser
The syphon tube needs cleaning by poking something through it to clear blockage.
Jan 10, 2008 | Hotpoint WMA76 Front Load Washer
Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Oct 07, 2007 | Washing Machines
Kenmore 44072 Front Load Washer Logo
50 people viewed this question
Sal De
fordexpert
Robert Rankin
