Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Machine shuts down and flashes F 06
Is there a way to get a copy of what the codes mean because there looks to be a lot of people having a lot of problems with the HE3t?
    President:
  • 1,314 Answers
They should be in your owners manuel but if you remove the top of your machine they are under the top in an envelope i beleive on the left han side f06 means your motor is having trouble turning you should check to see iff all the shipping bolts have been removed
Posted on Sep 09, 2008
  • 5,911 Answers
"F06" is a Motor Speed error code. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Now BEFORE you assume you have a component failure, the manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. In many cases this is all it takes to clear common "glitches" in the system. If the error reappears, follow the advice in the link by first checking all your connections on the Motor Control Unit (MCU) and Drive Motor. Then take resistance checks of your motor windings. The link gives you all this information.
To answer your initial question, there should be a tech sheet included with your washer that explains all the error codes and how to troubleshoot them. The manufacturer places this inside the washer behind the lower panel under the door. It will be located either on the back of the panel, or on the interior wall of the case. I hope you find this information helpful. Let me know if you require additional assistance.
PS If you locate your tech sheet, it is recommended that you leave it inside the appliance so you know where it is. The most common thing that consumers do is remove the tech sheet for safe keeping, then forget where it is.
While sewing a straight stitch after about seeing 2 inches the machine stops 06 stitch lights up and beeps
Since you didn't provide the make & model of your machine, we are unable to help. However, you can check what the error code means by looking in the troubleshooting section of your owner's manual or search for:
Make Mode error code 06
Sep 23, 2017 | Sewing Machines
I got code 3c00 on a konica c25 how do i reset this code its lock up
YOU GOT THE BIG ONE!!!!!! Some one tried to copy MONEY on that machine. NOW you will need to get a Konica Minolta Representative out to remove a special chip that will be sent to Konica Minolta then to the SECRET SERVICE. IN the mean time ask the Konica Minolta tech if they have a loaner, your machine is down until the SECRET SERVICE determines what has happen. SORRY the Color copiers are so good these day that they have a small chip that looks for info on currency and shut the machine down. SORRY
Oct 19, 2015 | Konica Minolta Office Equipment & Supplies
Intertherm furnace model # MMHB-070ABHR-06 red light blinks two times
Number of flashes mean different things for diff models. The meanings of those flashes should be posted somewhere on the unit; usually inside front of the bottom service panel. Though you can't truly diagnose a problem by number of flashes they can give you an idea of where to look for a problem. There are a ton of videos and how-to's about furnaces on youtube by real service techs. Most modern furnaces have basically the same set-up and features so don't worry about your paticular brand; but of course that would be the best place to start looking. You could start here to familiarize yourself with your brand of furnace:
http://www.youtube.com/results?search_query=Intertherm+Gas+Furnace+&oq=Intertherm+Gas+Furnace+&gs_l=youtube.12...62316.62316.0.63907.1.1.0.0.0.0.202.202.2-1.1.0...0.0...1ac.Ko9QBdxK6OM
And then here:
http://www.youtube.com/results?search_query=gas+furnace+won%27t+light&oq=gas+furnace+won%27t+light&gs_l=youtube-reduced.3..0.5619.10061.0.11544.11.5.0.6.6.1.741.1982.0j1j2j5-1j1.5.0...0.0...1ac.1.5-0zJyxNMEo
Hope this helps.
Dec 21, 2012 | Heating & Cooling
I have a whirlpool GHW9300PW4 that keeps flashing F-06
hi janice f06 means The F/06 is:
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
The tech. should check these:
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor
Check the MCU
Check the Wire Harness hope it helps
regards
shaun
Nov 10, 2011 | Washing Machines
I have an AC unit with the model # PDH12K3SD-C the unit stops working and flashes an error cod = "06" anyone know what the error code means?
According to the Owner's Manual if the Error Code flashes "06" the O.D. coil Temperature > 175 Deg
F for 2 consecutive minutes. (Heat Pump models only).
The action taken by the unit is Alternate flash set point and error code. Shut unit down for 5 minutes, then try again 2 times, if fails the 3rd time, then shut down unit.:
All of this is can caused by several things:
• Dirty filters
• Dirty coil
• Fan motor failure
• Restricted air flow
• Improper refrigerant charge
• Restriction in refrigerant circuit
The dirty filters, dirty coil and restricted air flow you can troubleshoot and solve yourself. The reaming ones should be handled by a an authorized service technician.
Here's a link to your Owners Manual, that you can download and print for future reference.
http://www.ajmadison.com/ajmadison/itemdocs/92008705_9-07_PTAC_IO_manual.pdf
Hope this helped to to troubleshoot and solve the problem . Please let me know. Thanks.
Jun 10, 2011 | Friedrich PDH12K3SD Air Conditioner
Washer beeped a few times then stopped and is flashing F then 06 i don't know if the 06 is time remaining or part of the code
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Jan 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does a code o6 mean on a Whirlpool Calypso top load washing machine.
is this the code your refering to
ob" Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an "ob" for Off Balance
The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
Press STOP/CANCEL to clear the display
cuz they list no code 06 hope this helps
Jul 18, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
  • Check the MCU
Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Washing Machines
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
  • Check the MCU
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
193 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
