Question about Philips 27PT543S 27" TV
TV Sings Like a Bird!
My Philips 27PT543S37A won't turn on. When I plug it in, it makes a high pitched bird chirping sound. When I took off the back case of the TV, the sound appeared to be coming from the transformer. If it is not coming from the transformer, I know for sure the sound is coming from the green circuit board with the transformer on it.The noise slows down and stops when the TV is unplugged, and pushing the power button when the TV is plugged in does nothing. What's wrong? Can I fix this?
  • Kenneth Smith Nov 09, 2006
    The solution posted above is reliable and accurate. I took my tv to a repairman and he fixed the power supply for $80.
Phillips TV, 27”, model:27PT543S37A REPAIR…
SYMPTOM:
Clicks and turns off after turning on set when cold. Have to turn on and off several times to work, or keep changing channels, right side of screen is black for a while.
PROMLEM: It is almost always a bad transistor and a bad capacitor. (about $0.70 in parts)
SOLUTION:
This repair is fairly straightforward. You will need a soldering iron, a solder ******, and a small torx bit. Unplug the set. Lay the TV on the floor, screen down. Remove the torx screws holding the rear cover on. There should be 10, (don’t forget the 2 by the input panel). You will see 2 circuit boards, the one of interest is the large one near the bottom of the set. This board has a retainer clip on each side that needs to be pulled out to allow the circuit board to slide out. Slide the board out about 5-6 inches. You might need to support the board so it doesn’t slide back down into the TV set. This circuit board should have numbers by each of the components. You want to look for 7461 (transistor) and 2455 (capacitor). They are located right next to each other near the center of the board. The transistor will usually overheat and discolor the circuit board immediately around it. Warm up the soldering iron and get the solder ****** ready. Heat up the solder joint while removing excess solder with the ******. Once the transistor and capacitor are free, check the numbers on each. The capacitor (round cylinder) should have “47uf” on it. The transistor should have “C33725” on it. You can order these parts from Digi-Key (google it) for about $2.50 including shipping if you use USPS option. The part numbers are: 493-1060-ND for the capacitor and BC33725-ND for the transistor. Once you get your parts, solder them in and check TV operation. It should work as it did before. (Wouldn’t it be nice if these companies could focus on quality rather than saving $0.04 here and there??!!??). This repair can be done by anyone familiar with a soldering iron in about 30-45 minutes their first time. Good Luck!!
Posted on Oct 09, 2008
    President:
  • 3,130 Answers
The "singing" you hear is an overloaded Power supply and that could be a shorted Horz. output xsistor as well as a bad Flyback xformer.. Its a posiblity that you could even have an open B+ cap off the flyback that supplys a voltage to the scan drives but most likly the earler.
Posted on Mar 22, 2006
  • 3 Answers
Shorted diode R2KY on b+ or shorted h.out.
Posted on Oct 10, 2007
I don't have a solution for you unfortunately, but I have the same problem! Did you figure out what was wrong? I own an RCA tv that is only about 3 years old. The SAME EXACT thing is happening to my tv. I don't know if it's worth it for me to bring it to a tv repair man.
Posted on Nov 06, 2006
4 Suggested Answers
  • 1694 Answers
SOURCE: Replacing Circuit Board Capacitor
820pf / 2KV capacitor Philips # 483512257004 Andrews
Or # 13-821U HB Electronics .......T.
Posted on Nov 08, 2007
  • 280 Answers
SOURCE: TV won't turn on, makes high-pitched clicking noise
Its a real good chance that the HOT (horizontal output tranistor) transistor is shorted if so the flyback trasformer may be bad also. the transformer will make a tick tick sound if it is trying to start.
Posted on Apr 10, 2009
  • 35 Answers
SOURCE: My Philips 27pt643r 27" TV has a high-pitched whistle
this is the line lin coil needs replacing
Posted on Sep 04, 2009
Tv wont come on
Did you try unplugging the TV? Also if that does not work then call the TV provider and ask them for help.
Mar 14, 2016 | Philips TV Tuner Video Capture PCI Card -...
TV chirps like a bird but does not come on.
does this sound like some thing burning or sparking??
and do you see the stand by light blinking?
if yes how many times?
if you tell us the interval of blinks it would be much helpful for us to decode it.
Aug 12, 2008 | Philips 51PW9303 51" Rear Projection...
Aoc tv bird chirping sound
If this is affecting the brightness of the screen, then I would guess that you have a high voltage power supply problem. This TV uses high voltage to power the fluorescent tubes that illuminate the screen. It will need repair.
Jan 15, 2014 | AOC Televison & Video
Fix chirping
Chirping sounds could be a bird stuck inside. If you are not missing any birds then I would suspect you need a drop of oil on the pin behind the bobbin case.
Nov 17, 2013 | Husqvarna Sewing Machines
My Magnavox tv will not come on. I hear what sounds like a small bird chirping inside the tv but nothing else. It started a few weeks ago taking a long time to come on. Once we unpluged it and left
The TV has developed defects in the board such as leaky/dry capacitors, dry solders etc. Kindly look for a qualified service technician around your area.
Jul 25, 2012 | Philips Magnavox 42MF521D/37 Television
Dryer makes noise like a bird chirpping.
You'll need to access inside the cabinet and oil the tires and belt pulley. Hope this helps!
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
NO PIC & NO SOUND ONLY HI PITCH SOUND SURGE FROM BACK
Goto the site www.TvRepairKits.com and get their "chirping" TV repair kit. It will fix the problem of the dead set with high pitch sound or chirping sound.
Jan 01, 2009 | Philips 43PP9202 43" Rear Projection...
On off button blinking.
If your set is making a high pitch sound or chirping sound you can get a repair kit from www.TvRepairKits.com.
It will fix the no audio + no video + set makes chirping or high pitch sound.
Dec 27, 2008 | Philips 43PP9202 43" Rear Projection...
No av-input picture with sound
Sep 25, 2008 | Philips 60PP9363 60" Rear Projection...
High pitched car sounds
does the noise and light occour at the same time ? another cause of a high pitched noise can be slipping drive belts, alternator,powersteering etc so check them for tightness, condition etc, does the noise happen when car staionary and just rev the engine ? if so i would say it is the drive belt/s, go back to the VW dealer re the ABS light and get them to check the OBD as should be done as part of the service , hope this helps
Mar 29, 2017 | 2001 Volkswagen Jetta TDI
Philips 27PT543S 27" TV Logo
785 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
