IF STARTER RELAY BAD THE STARTER WONT MAKE NO NOISE AT ALL HEADLIGHTS WONT DIM.IF YOU CLICKING NOISE BATTERY VOLTAGE TOO LOW. MAKE SURE BATTERY VOLTS ARE 12.6 VOLTS AND USE TEST LIGHT TO SEE IF STARTER GETTING POWER.COULD HAVE BLOWED IGNITION FUSE OR FAULTY IGNITION SWITCH. TO CHECK STARTER SOLENOID FIRST TURN OFF RADIO THEN REMOVE NEGATIVE BATTERY CABLE AND POSITIVE BATTERY CABLE.THEN REMOVE STARTER BUY A REMOTE SWITCH.YOU NEED BATTERY JUMPER CABLES HOOK BATTERY JUMPER CABLES TO BATTERY PUT POSITIVE CABLE ON POSITIVE BATTERY POST THEN PUT NEGATIVE BATTERY CABLE ON NEGATIVE POST. HOOK BATTERY CABLES TO STARTER USE NEGATIVE CABLE GROUND STARTER BODY AND PUT POSITIVE BATTERY CABLE ON THE LARGE POSITIVE POST ON STARTER SOLENOID. NOW TAKE REMOTE SWITCH HOOK RED WIRE TO STARTER SOLENOID POSITIVE POST THEN HOOK BLACK WIRE TO REMOTE SWITCH TO STARTER SOLENOID SWITCH TERMINAL WITH LETTER S THEN PRESS REMOTE IF STARTER SPINS STRONG WITH A GOOD KICK STARTER GOOD.YOUR PROBLEM COULD BE CORRODED WORN BATTERY CABLES. WEAK BATTERY FAULTY IGNITION SWITCH. IF STARTER DONT WORK WHEN YOU PRESS THE REMOTE SWITCH STARTER SOLNOID BAD OR STARTER ITSELF BAD.IF ALL IS GOOD. CODE SCAN CAR FOR THEFT SECURITY FAULT CODE.
