Question about Uniden BC250D Handheld Scanner
Scanner turns it self off
When I turn on my scanner, it stays on for about 5 seconds, at which time you hear a beep, and then the scanner turns off. Unfortunately, I dropped my scanner several days ago. When I dropped it, it landed with the buttons side down. I tried changing the battery and the AC adapter, but that did not solve my problem. Could it have anything to do with it landing with the buttons side down?
  • itsmecyndi08 Nov 22, 2008
    I've never dropped mine and it does the same thing? I can't get it to "stay on". When it turns on it says the APCO card is not installed and it is installed properly. There is no charge to the battery. The AC adapter doesn't seem to charge it? What do I do? Is it poss I'm using wrong ac adapter? Where can I find a picture of the accurate ac adapter for my Uniden BC250D? Thanks, in advance.
    Novelist:
  • 96 Answers
Try doing a reset on the scanner, and make sure your battery is good. For the one that dropped it, remove the battery, remove and reinstall the APCO card, bci25d, and then try powering it with the wall adapter, leave the battery out. If it turns on and stays on you might just have a bad battery, they fail and there is plenty of reports online of battery failure causing weird problems.
For the next post regarding your problems to get it to stay on and the APCO card. Remove the card completely, reset the scanner, and then reinstall the card. Make sure its off and the battery and wall adapter are disconnected when removing and replacing the card for safety. After replacing the card leave the battery out and plug in the wall adapter and try turning it on, again eliminating the battery as the possible problem. If it won't turn on you have a bad wall adapter, if it turns on then off yet you could still have a bad wall adapter, get a voltmeter and check it. If it now turns on and stays on you have a bad battery, replace it. You mentioned there is no charge to the battery, how did you check that, is it acting like the battery is not charging? That can also just be symptoms of a bad battery.
The adapter for the 250D is the AD600U, 12v 500ma.
Posted on Jan 06, 2009
Hi, I need to know how to program the DB Power barcode scanner model # BCE0008
Unfortunately, this is all I can find for instructions.
Operation Instructions:
1. Connect the USB receiver to the host (e.g.: PC)
2. Pull the trigger to start the scanner. It works on two beeps.
Notes: 1. The charging port on the scanner is for battery charging only. Do not connect it to data cables.
2. The LED light at the scanner bottom is on and red under charging and off when charging is finished.
3. During working, the scanner will auto shut down in case of not in use for 20 second.
4. The receiver was paired to the reader at factory. Do not pair again unless necessary. When self pairing is needed, please first read the code CHANNEL SETTING. (Before setting, please reset the receiver until the light turns long green. Reset it to the light off when setting is finished.
Package Including: 1 x Wireless Barcode Scanner 1 x Receiver 1 x Charging Cable 1 x Instruction
Sep 08, 2016 | DBPOWER 2.4GHz Wireless Handheld Automatic...
Scanner is adding the characters }w before bracodes.
Do you have a configuration manual book?
I think you can go to factory settings from there.
Mar 18, 2014 | Symbol Lot 4 Ls1902t-1000 Barcode Scanners
How to program itouchless doorlocks
change master code
0 + * + default/old mastercode + new 8 didgit master code + #
when successful it will make a solid single beep if unsuccessful it will beep 3 times
enroll finger print at random no user ID
1 + # + master code + #
first scan place finger on the scanner and remove when the scanner light turns off
second scan replace same finger when the scanner lights back up you will hear a single beep if enrollment is successful
if scan fails you will hear 3 beeps
Jan 15, 2012 | Itouchless Bm003l Bio-matic Fingerprint...
How can i stop the squelch ive tryed turning the sqcuelch doesnt help
Plug the AC adapter into the back of the scanner and into a wall electrical outlet. Screw the antenna into the receptacle on the back of the scanner (extend the antenna to full length for best reception).
  • 2 Set the squelch level to allow signals to be heard by turning the squelch knob counterclockwise. Rotate the volume knob clockwise until you hear static. Slowly turn the squelch knob clockwise until the static noise disappears.
  • 3 Start programming frequencies into the scanner by pressing the "Manual" button.
  • 4 Press the up arrow or down arrow key until the channel you wish to program is visible on the display.
  • 5 Use the numbers on the keypad to enter the frequency for the local transmitter you wish to receive.
  • 6 Press the "E" key to complete the process of entering the frequency.
  • 7 Repeat steps 3 through 6 for each additional frequency you wish to monitor.
  • 8 Press the "Scan" key to start the scanning process. The scanner stops on a channel when it detects a signal strong enough to hear over the squelch setting. Two seconds after the signal stops, the scanning process resumes.
  • Dec 06, 2011 | Uniden BC248CLT Base Scanner
    Is there a Master reset feature for the Uniden Bearcat BCT8 scanner? Need to reprogram and start from scratch. See nothing in the manual on how to perform this function.
    turn off scanner hold down the state/highway the number 2 and 9 then while holding the 3 buttons turn your scanner back on while holding the state/highway, 2 and 9 buttons if you did everything correct you will see a clear message show up and about 2 seconds later hear a beep
    Oct 24, 2010 | Uniden BCT8 Base Scanner
    I have a barcode scanner Symbol S/N M1J82M51E. When scanning the item barcode it makes very low volume. How to increase the bipping scanning volume for the Symbol Scanner?
    1. Press and hold the trigger for an extended period of time (approximately 5 seconds). The scanner cycles through three settings (Low, Medium, High) emitting a 2-beep tone at each setting.
    2. To select a particular setting, release the trigger after you hear the desired 2-beep tone.
    Sep 18, 2010 | Symbol LS9208 Hands Free Barcode Scanner
    I had posted this problem once before hopefully get assisted this time. I purchased a casio TE-4500F register with scanner I had to reinitialise it to clear old data, and reset it now the scanner red light...
    Hi. This is normal. Unless you made a backup, you will have lost a lot of system programming. Firstly you must make sure you have initialised it with the code for scanning and not check tracking. To do this:
    Turn key to program mode 5 SUBTOTAL SUBTOTAL
    This will print the memory allocation. Next to file 16, you should see a figure in the thousands (usually 6000).
    Next you need to allocate the I/O port for the scanner. Try this:
    Turn key to program mode 3 SUBTOTAL 298 SUBTOTAL 2000 CASH SUBTOTAL
    Now perform a flag clear to set the new I/O:
    Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL.
    Turn back to REG mode and try it. You might have to log a clerk back on after the flag clear. See how you get on.
    Dec 29, 2009 | Casio Parts Cash Register PC Desktop
    My pro 82 keypad is locked. How do you unlock it?
    To turn on the keylock, hold down key
    for about 3 seconds until the
    scanner beeps three times and
    appears. To turn it off, hold
    down key for about 3 seconds
    until the scanner beeps three
    times and the key disappears
    For Future refernce you can go here
    http://support.radioshack.com/support_tutorials/communications/20-315.htm
    and click on user manual
    Oct 20, 2009 | Radio Shack Pro-82 Scanner
    Scanner works but keypad will not
    The keypad may be locked. Lock and Unlock procedure is below:
    To turn off the Keylock, press FUNC then keylock.gif. The scanner beeps 3 times and Key unlocked appears.
    To turn on the Keylock, press FUNC then keylock.gif. Key locked appears for about 1 second. Key locked appears when you press any key.
    Here's a link to your scanner manual:
    http://marksscanners.com/97/97.shtml
    Oct 08, 2009 | Radio Shack Pro-97 Handheld Scanner
    Uniden BC250D Handheld Scanner Logo
    136 people viewed this question
    Top Uniden Radio Communications Experts
    Jason
    Steve
    eradiostore
    eradiostore
    Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
