Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
2001FP LCD Half Display
Hello
My dell LCD 2001FP show half display and half green color bar in horizontally on left side of screen what is this and one more thing i want to tell you this LCD warranty was expired . One more interesting thing i see in seniors it was the end day of warranty this LCD make half display on same day tell me what can i do and is it repair able or any part for it and i have five LCD with same problem help me
    Genius:
  • 1,142 Answers
Please refer to this link for help..
http://support.dell.com/support/edocs/monitors/2001fp/EN/trouble.htm
Posted on Sep 09, 2008
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Half the screen is white, half the screen is colorful
I would try using an external display. That will prove the GPU. If it is OK then the display is faulty, if not the GPU is faulty.
Nov 20, 2013 | ASUS Eee Computers & Internet
Half of the Dell 2100FP screen is color bars???
Please specify this happened after which event ,e.g. like when you connected another device or installed a game
May 11, 2013 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Vertical Lines Dell Ultrasharp 2001fp
Sorry to say that it is a permanent damage of your monitor screen. Usually you can do nothing. But if you want to change the monitor screen, you have to visit a monitor & television specialist.
Cost will be 1/4 of a new monitor.
Sep 22, 2017 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Vizio half of screen is solid color bars. Top half works great.
You have either the circuit board that drives that half of the screen(one for top and another for the bottom) or you have a bad display panel.
May 25, 2012 | Vizio 32-inch Sv320xvt Full 1080p 120hz...
My 2001FP shows the contrast cotrol greyed out and the screen has very low contrast, which I need to correct. I use it with a Dell Inspion 9300. The laptop screen has excellent contrast. The 2001FP...
I have four Dell 2001FP monitors. The unavailable contrast is standard for this monitor when used with digital input (DVI). Make sure your brightness is at 100%.If you want a better result of dynamic range and color, the only effective option is color calibration. I use the inexpensive Huey Pro, available
several places, including eBay. Retail is around $100. It something one uses maybe twice a year, takes five minutes to install and use, and the results are notable. I'm a designer, and need excellent color. This is the best solution. Calibrate your laptop as well, and the color should be almost exactly the same between them.
As an alternative, you can use the color settings, select User Preset, and start with something around 40 red 43 green and 37 blue. Adjust proportionately upward until you get what you want.
Another possibility is to use a different connector cable if your laptop has that option, since your monitor an take four different input formats.
Good luck.
Dec 07, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Vertical lines on left half of screen
The problem is the driver tabs that go from the panel controller board to the panel itself.
This is normally a fatal failure since having it repaired is extremely expensive.
Mar 17, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Verticle blue lines, left side
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new one.
Mar 07, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001fp - Ramdom horz strips
Just had the same issue with the horizontal lines. In my case, too, turning off the monitor would make it go away for a while. called Dell, turned out it was still under warranty (3 years), got a replacement monitor the next day. Way to go Dell!
Dec 05, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Left half of screen is perfect. Right half of screen shakes
Look to see if there is any kind of magnet by the screen. Even speakers wil do it. So does anything that emits micro waves such as cell phones and microwave ovens. So just move it or anything that you think could mess it up.
Jan 14, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
282 people viewed this question
Alun Cox
