Black & Decker Cafe Noir DCM1400 Coffee Maker
Problem for Black & Decker Cafe Noir DCM1400 Coffee Maker
Filter basket retains water
By JohnMuir on Mar 21, 2006
Beginning yesterday morning, our 10 cup B&D Cafe Noir is retaining about two cups of water in the filter basket.
Spring looks OK, nothing seems to be sticking - it just is retaining the water. What is the problem?
JohnMuir
Same Problem
Aug 11, 2008
-   put in water, just sits and dosent empty cant hear the brewing sound evan...light is on.-   maryg54
Mar 09, 2008
-   We have a new B&D 12-Cup Under Counter Coffee Maker that overflows the filter basket on a regular basis. I have checked to make sure the filter basket is clean and clear of obstructions. I have reduced the amount of coffee placed in the basket. When is doesn't overflow, the filter basket will retain about 2 cups of liquid. I have noticed that if I remove the pot and replace it the 2 cups will then drip out.-   TColburn
Nov 22, 2007
-   I'm having trouble with my B&D space-saver coffee maker also the water collects in the basket and does not drip out, not only some but all the water and then I have no coffee brewed. My maker is less than a year old. What can I do to repair the problem myself, It's really frustrating and i would really appreciate some help with this . Thank-you Cindy McPherson Cinmac16@msn.com Looking forward to hearing from you,Bye now.-   Bubbles9330
Best Solution
posted on Mar 28, 2006
Helpful)
techman
Rank: Guru
Rating: 86%, 7633 votes
it sounds like a restriction in the perk tubes have you cleaned I mean deep clean the unit??? It should be as any auto coffe maker should be clean deeply every three to six Months depending on how much you use it. How you do this is take 1/2 viniger in pot and fill to capacity.. Dump this into the unit and brew it through. Then ite recommended to rinse them by brewing three to 4 times with clkean water. now if this dosent work its probably behound feasability to repair
Was this helpful?
Yes
No
Solution #2
posted on Oct 02, 2008
Not Rated)
gradyshirin
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem, I found out that when I was using the grinding machines in the stores, I would change the setting to expresso or fine. Try using other setting that should solve your problem.
Sharon G
Was this helpful?
Yes
No
Solution #3
posted on Feb 19, 2007
Not Rated)
crunger
Rank: Apprentice
Rating: 0%, 0 votes
If your Saeco is backing up and no water is coming through, the following may help you fix the problem:
If you have ever taken off the two screws at the top of the brew group that hold the water exit coupling, make sure you placed the spring back in correctly with the CHECK BALL in the right place. I put the check ball in and the fat part of the spring down first and it clogged the "exitway" for the coffee. I think the spring should be the other way, with the ball contained in the spring. However, I just removed the ball altogether, because I cant remember. Anyway, hope this helps...I just wasted an entire morning.
Was this helpful?
Yes
No
Popular Solutions for Black & Decker Cafe Noir
Questions and Unsolved Problems for Black & Decker Cafe Noir
Do you recommend Black & Decker Cafe Noir DCM1400 Coffee Maker?
Answer
Answer
can you mix hot chocate in with the coffee inside the coffee maker?
Answer
black and decker cafe noir - this morning i turned it on and there was loud cluncking noise in the... (More)
Answer
Water (cold) leaks out. Got worse after cleaning with white vinegar. Used several months before... (More)
Answer
I have used black and decker for alot of years. Now this th second brew that has leaked from the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Black & Decker Cafe Noir...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 2511
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
