Question about Philips Magnavox 51MP392H Rear Projection Television
Tv philips my tv philips works good but after 5 minutos it turn off
  • 1,139 Answers
Hello c_guerrero1,
This may be the shutdown circuit activating due to excessive current I would check the Horizontal Outout transistor, and the IHVT Intergrated High Voltage transformer. These are usually the cause of these problems. I would advise getting this repaired at a TV repair shop, due to the nature of the problem and the section that may have the problem.
Thank you
Posted on Sep 14, 2008
I have a 27inch Philips flat TV that when its pluged in the light is solid red and TV won 't turn on
Common TV Repair for Emerson, Sylvania, Philips, Magnavox
? 5:35
Oct 11, 2013 - Uploaded by Tampatec
Top most common LCD TV repairs for Emerson, Sylvania,Philips, ... my tv wont turn on neither the led ...
Nov 01, 2015 | Philips Televison & Video
Problem seccion vertical, el televisor se enciende por unos minutos, no sale la imagen completa y luego se apaga
You have a bad capacitor near the flyback transformer. Location would be 2465. Look for a 100volt 10Mf cap. Esta no bueno! Pero cuidad senor. This requires special care to remove this cap or the TV will be ruined. The circuit traces are vey delicate. Cannot tell you enough....use extra care in removing this! Tambien.....change capacitor location 2415 as it is weak. It is a 160 volt 2.2MF. Good Luck....Mathias!
Apr 03, 2010 | Philips 27PT5445 27" TV
My 36'' Philips tv shuts off after about 5 seconds after I turn it on. The on light stays on but the tv doesn't.
ive had many problems with mu three philips tv and every repair on them was very exspensive they are unfortunately throw aways never buy one again. ive lost thousands..
Jan 28, 2010 | Philips 36PT842H 36" TV
Hi and welcome to FixYa,
Offhand it would appear that the VCR section of the combo unit would require a bit of cleaning. Specifically, head cleaning. The easiest approach is to use a VHS tape head cleaner.
The other post of "tv turns on then 5 seconds later shuts off" would be the auto-protect kicking in. This indicates that a likely hardware fault exists. Try to initially reset the unit by unplugging from the mains for an extended period. Otherwise it would require opening the unit for voltage measurement/diagnosis.
Pls post back updates. Good luck and thank you for using FixYa.
Jan 25, 2009 | Philips Magnavox Learning Universal Remote
Universal remote???
Porque no tratas por el siguiente metodo,prende la TV que vas a programar manualmente,en el control remoto presiona la tecla code search hasta que el led se quede encendido sueltala y despues presiona la tecla Tv. sueltala enseguida dirige el control rumbo a la Tv y presiona el boton power en intervalos hasta que la television se apague despues presiona la tecla enter para que el codigo se quede almacenado en la memoria te vas a llevar unos cuantos minutos para hacerlo pero siempre funciona.
Mar 11, 2008 | Philips 19PS45S 19" TV
Philips 42
Initially if it is near the bottom, I would suspect that somehow you have activated the "Close Caption" feature. Corrective procedure would of course be to disable/turn it off.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 19, 2008 | Philips 42PF7220A 42 in. Plasma Television
Apagado repentino
yo tengo el mismo problema se apaga repentinamente y se vuelve a encender se apaga hasta en 5 minutos y varia
Dec 16, 2007 | RCA 20F420T 20" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
