Question about Air Tools & Compressors
Installing a drop-in sink
I'm trying to install a drop-in stainless steel sink into a new gramite countertop. The granite installer made a cut-out and told me to use silicone to hold it down. I'm trying to use tyhe clamps I had before that held the same sink to my old formicsa counter, but the clamps are too short. Any ideas? I saw something about weepholes. What are those?
  • 550 Answers
The stone installer told you to use silicone,
what makes you think that you know more than he does about his product.
IF you go use lockdown screws, you will put tension on a thin granite slab at 4 or 6 points around the perimeter of a hole.
stone breaks under very small tensions
do as instructed and silicone the sink in place,
or void any warranty and buy the counter top again when you break it
formica is plastic on a chipboard substrate -not stone
not perhaps the answer you want to hear,
Posted on Sep 09, 2008
My black granite countertop has a stain which must have soaked thru seal, now shows a whitish spot, How can I fix this? Thanks
Remove Water Marks/Stains from Granite Countertops ...
? 2:55
https://www.youtube.com/watch?v=VO571n_4Jns
Jun 10, 2011 - Uploaded by KristyU2178
... the water mark/stain from my black granite countertop in mybathroom. ... @TheJefferyjones The stains ...
Removing Stains from Granite Countertops - YouTube
? 5:51
https://www.youtube.com/watch?v=hPPFe8902Zg
Oct 1, 2010 - Uploaded by MonkeySee
I left a bag of sweet potatoes on my black granite and there were some ... @Oxidized181 yes I have lots of ...
Stains on Black Galaxy Granite - Countertops
Jan 17, 2016 | Home
I need a cutout template for teka sink model 86555
If u have the sink. Put card board down for your pattern set sink on card board and trace sink .if no sink measure sink cut to size
Mar 31, 2014 | Trion Teka Sink 60 S Stainless Steel...
What type of adhesive to use to fasten underhung stainless steel sink to granite countertop
No adhesive will permanently hold the sink, you should have a fabricator drill and install pins to screw the sink into place, you could also push it tight to the stone and then secure it a piece of wood screwed into the back wall of the cabinet.
Oct 23, 2012 | finehomebuilding.com
When installing do you silicone each piece for example the faucet , the soap dispenser ,the sprayer , and the tap
Hi seawitch678,
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
Installing an undermount sink in case it need to be removed
under mount sinks are 'glued' to the underside of the granite countertop using clear silicone caulking. Clean both surfaces really good with alcohol or acetone (or even disc brake cleaner, apply caulking to bowl flange and position bowl up to underside of counter. Temporarily block in place and let cure for 48 hours. To remove bowl later, use a thin cutting blade like a hacksaw blade to slice through the caulking line. It helps if you don't squish all the caulking from between the bowl and the counter so that you can just get the hackwas blade in there in the future.
Jun 09, 2009 | Home
Sink won't fit cut out
You will either have to go with a different sink or contact a local granite dealer and they can send someone out that can enlarge the hole for you on site.
Apr 05, 2009 | Home
Installing stainless steel sink with metal clips
if you look at edge of sink you will see small rail the bulbous end of clip goes in rail and flat side of clip goes against under side of countertop you then tighten clip which will pull sink and counter together you should install with plumbers putty around rim
Mar 24, 2009 | Neptune Home
Pegasus Push Button Vessel Sink Drain with overflow
Put plumbers putty around the flange that will be in contact with the sink. When you put it into the hole, try to line up the overflow as good as possible. The nut that goes onto the bottom (tailpiece) has a rubber gasket that will go between the nut & the sink. Adding some plumbers putty here won't hurt. After all is secure, just remove the putty that squeezed out from tightening.
Feb 21, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Deep scratches on blanco granite sink
The only way to fix scratshes and chips from a granite surface is to use a sander. You would be safer to have the company thet installed it, resurface it. They have the proper equipment.
Feb 17, 2009 | Blanco 511-620 supreme 2 One-Piece...
Air Tools & Compressors Logo
768 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
