Question about Zanussi FJS1225W Front Load Washer
Broken noise machine stopped in the middle of a wash and since then if you try and turn it on there is a terrible noise coming out of it, obviously something broken, but what?
  • Elena Giuliana Mar 30, 2006
    I did get someone to fix it for me, there was a key stuck in the motor. This broke the part and it had to be replaced.
    I was then told:
    - start loading with small items at back of drum AND
    - always check inside rubber at door
    For all those people out there who never really looked at a machine carefully, all those coins, etc. get in between the rubber and the drum. Some machines have larger gaps than others!
    Champion:
  • 277 Answers
Hi sounds like the belt is torn thats why it stoped in the middle if you want you can fix it yourself go to the store and buy a new belt for this specific model open the unit serch for the motor - there are to polies there is a stretching unit for the belt 1) relese the bolt of this unit and change the belts 2) pull and stretch the new belt and then close the bolt or just call a tech gay home good luck
Posted on Mar 21, 2006
How do I stop my aav 8000 washing machine from making a rattling noise in spin cycle? It's on level ground ;-\ I disassembled some of the washing machine and the noise is coming from a metal par
It is so common that the washing machine can maketerrible noise in many ways and is a common fault. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that machine isvibrating when it is running then the motor /drum suspension has to beinspected. Since these fittings are located on the underside of the machine itis important that you look for the noise with a good inspection lamp. Manuallyturn the motor and drum and listen for the noise, if so the motor bearings, thedrum agitator shaft and fittings must be checked. Also the suspensions whichinclude the shock absorbers and springs, the body clamps must be checked to bein correct alignment and not changed in position. Tightening of themounting is also very important. Finallyin most cases a drop of OIL or smear of grease on the moving parts cane solvemost issues.Check this link :http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlFor replacement of bearings check for tips on thisvisual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jul 05, 2012 | Admiral Washing Machines
Wahser makes loud noise trying to stop spin cycle It seemed to spin ok and agitate but made terrible noise when trying to stop
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing. but more than likely its the brakes, or the belt itself ,, a solinoid signals the machine to stop which in turn applies brakes just like a car only smaller, when these wear they tend to do the same as a car and squeal , its just an indication your machine is up for some maintenance,
Jul 25, 2011 | Washing Machines
Tub quit in middle of wash. tried turning on and off, machine will not come back on. made noise before stopping
I would suggest that your only option is to call for a service engineer as we would not be able to diagnose or help you from a distance ;-0(
Sorry,
Good luck,
John C
Mar 10, 2011 | Maytag Performance MHWE500V Front Load...
NO WATER COMING THROUGH ALTHOUGH TANK IS FULL, AND A TERRIBLE NOISE AS MACHINE IS TRYING TO MAKE COFFE
turn unit on let it set up as norm ... when it trys to wash or even if it dont ..turn steam knob fully open until noise has gone .. all done ..oh turn steam offf... bsc appliances 07779933829 postal service too
Jan 04, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
When my washing machine is spinning it makes a terrible banging noise! and i cant get it to stop. also, the legs of the washer are stripped and i cant adjust them so one is higher than the other one
it sounds like the balance springs inside the washer have come off or broken if so when ever the washer spins it jumps about and the drum inside bangs around to check if the springs are broken open the washer door and try to lift the iner drum up if it lifts a lot the springs are off or broken to help get it level try packing out the leg with a small strip of wood (ei: a bit of ply wood) would do to stop the washer from tipping its that or if you can get the striped leg off put some steel washers over the threds to pack the leg up
Mar 20, 2010 | Washing Machines
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Terribly load noise when washing
could need a new bearing
Jun 10, 2009 | Washing Machines
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Terrible noise while agitating
THAT COULD BE A BROKEN or LOOSE SCREW THAT HOLDS THE INNER TUB in the Center mast, hope this helps AJ
Oct 25, 2007 | GE WHRE5260E Top Load Washer
Machine won't work. kenmore 90 series
Might be a broken motor or a blown fuse. I would suggest having your machine looked at by a specialist. If it's old, you might consider replacing it.
Mar 21, 2006 | Kenmore 15864/15862 Top Load Washer
Zanussi FJS1225W Front Load Washer Logo
Top Zanussi Washing Machines Experts
jimorris77
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
