Question about Microwave Ovens
Kenmore microwave My micro just stopped in the middle of a cooking job. The screen says F6, and when I push any of the buttons they all just "beep, beep, beep" and nothing works. What is with the F6? Thanks!!
  • 1 more comment
  • jjwducks Sep 09, 2008
    This solution seems to work great!!!
    Thanks so much for your help and for saving us tons of money.
    Hopefully it is fixed!!
  • 143scoobydoo Apr 06, 2009
    panasonic nn sd797s does not cook, time knob turns time on display but no other buttons works,light does come on in microwave,what do i do?a P10 code shows up
  • Anonymous Mar 13, 2014
    how do I turn off the beeps when cooking is done.
  • 76 Answers
I fixed by unplugging the microwave with the door open. I plugged it back in and the F6 was gone. I was then able to set the clock and turn the light on/off . When I closed the microwave door, the F6 came back on and the microwave was making a humming noise. I slapped the side of the microwave near the keypad, and the F6 cleared from the readout and the humming stopped. The microwave is working fine now. Don't know why, except maybe slap on the side reset a relay or something. Anyway, I will never by a Sears Kenmore appliance for the rest of my life. The door rattles when you open a close it (like a part inside the door is broken) and this is the second time a fault code has appeared during use. I had GE Profile appliances at my last house, which are more $$ initial cost, but who wants to screw around buying a new microwave every four or five years. I'll happily spend a couple hundred more for the peace of mind and knowing that it will work during Thanksgiving dinner with the family over.
Posted on Sep 09, 2008
Why does the fan keep running on a kenmore spacemaster 300?
Check those 3 micro switches in the door latch assembly. A bad microswitch can blow the main fuse. This usually ruins the microswitch.
Nov 13, 2017 | Kenmore Microwave Ovens
Food not cooking in center
What make and model?? Sounds like it is not a carousel model. Have you tried a "Micro Go Round" ?? Otherwise, try rotating the 'plate' each quarter cycle...ie; every 30 seconds on a 2 minute cook time. Be sure to push the stop button first before you open the door to save wear and tear on the door switches......
Nov 04, 2013 | Microwave Ovens
Frigidaire microwave has annoying beep, can it be turned off? model no. FFMV162LQA
Hold the 2 button and Stop button at the same time. To restore hold 2 button and Start button at the same time for 30 seconds.
Aug 19, 2012 | Kenmore 80809 Microwave Oven
My ge micro will not stop turning
HELLO.
If by not turning mean turntable fault,the solution is given below in detail.
1 Press "Stop" to halt microwave operation.
2 Press the "Turntable" button once to turn off rotation.
3 Push the door-release button to open the microwave oven if you do not have a "Turntable" button on your control keypad.
4 Lift and remove the glass platter from the oven, then pick up the plastic track with three wheels below the platter. Set aside these parts.
5 Insert the elevated microwave cooking tray into the oven. The tray has three to four short legs that hold it above the bottom of the microwave, keeping it from interfering with the rotating bolt in the bottom center of the oven the drives the turntable. You can now place food on the elevated tray and cook normally without disrupting the drive bolt.
Thanks.
Sep 20, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Micro does not heat
Without your model number, I'd have to assume that it's a Whirlpool -made Kenmore. If so, then F6 means the cook relay is failing on the control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 23, 2010 | Kenmore 62702 Microwave Oven
Fan stopped running while heating something up
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uyiu4
Mar 17, 2009 | Amana ACO1860 Microwave Oven
Kenmore over the range microwave 721.67600 will not cook
One of two thing happened here...
1. most likely...One of the interlock switches has malfunctioned. Micro. will NOT opperate unless ALL switches are working properly for safety
2. possible...the start button on the touch pad has failed in the circuit.
Feb 23, 2009 | Kenmore 62702 Microwave Oven
Microwave stopped working
There is a internal locking mechanisim that has 2 or more switches that is usually attached with two or more screws next to the door latch side. Crack open the micro and adjust this by shutting the door then pushing this assy toward the latches untill all the switches look like they are being pushed in fully. If this doesn't solve the problem one of the switches or possibly more are defective. Call a local appliance repair center and get a switch there called micro switches.
Sep 14, 2007 | GE JE1540 Microwave Oven
Microwave Ovens Logo
337 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
