Question about Canon PIXMA iP90 Mobile Printer
CanonPIXMA iP90 Color Ink Tank installation problem
I keep getting an error message that reads: "The following ink tank is not installed: Color Ink Tank. Install the ink tank properly and close the printer's cover. If you do not want to install the ink tank, click cancel."
The cartridge is installed properly. While traveling, I removed the ink cartridges for 3 weeks. Once I settled in Mexico, I tried to use the printer and kept getting the error message. I tried cleaning, deep cleaning, print head alignment, and installing new cartridges. I occasionally am able to print a test page, but the ink pattern is not good, even with a new cartridge.
  • 5 more comments
  • Anonymous Oct 02, 2008
    I have the same problem with one of my printers as well. I have taken the printer apart and noticed a large amount of excess ink all over the bar that has the ink tank sensor on it. I cleaned that off and took the metal cover off of the ribbon cable to clean the ink off from under there.
    I have come to the conclusion that the switch that is depressed when an ink tank is installed has been broken or the connections to the switch has been broken.
    *I have not confirmed this with Canon
  • Anonymous Nov 05, 2008
    It reads install color ink cart. however it is installed. It will not print.
  • Anonymous Nov 11, 2008
    I have the same problem and my tank is installed properly. It was working fine with a low black ink tank. I replaced it with the exact same black ink tank and it won't recognize it. I've tried recycling the power, making a shim with a piece of paper to try to push the swtich (underneath the cartridge) activate. But I think the switch may be just broken, because there is no ink in the tank holder or anywhere....it's very clean.
    Anyone have any other suggestions????
  • tony one Dec 02, 2008
    I have the same problem, is there way to carry on printing when this message is called up?
  • Anonymous Mar 22, 2014
    color ink light won't go out after I put a new color cartridge in the printer.
  • Anonymous Mar 25, 2014
    I just installed a new Cartridge 920XL into my HP Officejet 6500. I have tried to print several pages and it seems like the ink is not getting through. I just replaced the 3 color cartridges last week and they are fine.
    What's the problem?
  • Anonymous Mar 29, 2014
    want printer to clean and align heads. how do I override error message
Can anyone tell me what to do
Posted on Sep 24, 2008
2 Suggested Answers
  • 76 Answers
SOURCE: CanonPIXMA iP90 Color Ink Tank installation problem
yeah it sounds like a cartridge sensors are stuck or broken. i would say to replace the whole print unit. It will need a service support dealer to fit this part unless you can buy it and fir it yourself.
part number: QM2-2020-020
hope this helps
Posted on Oct 24, 2008
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
I have purchased a ''Virtually Mint'' Canon Pixma ip90 printer however, when I try to print a document a message pops up stating ''the following ink tank is not installed: black ink tank, colour ink tank....
Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 21, 2010 | Canon PIXMA iP90 Mobile Printer
Color tank isn't installed --- but it is!
Make sure that all tickers are off from the tank and clean the housing good and run self clean first and reset the printer
Nov 07, 2009 | Canon PIXMA iP90 Mobile Printer
New black cartridge installed. Won't print. HELP please.
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
I have a Canon Pixma i90 printer and I keep getting error message "color ink tank not installed" and it has already been installed.
There's a small switch under where the ink tank goes on the left side of the carriage. You have to make sure you install the right side of the ink first, under the lip, and then press down the left side. When the switch goes bad, you need a new carriage which means you get a new print engine. Costs as much as a new printer.
Aug 13, 2009 | Canon PIXMA iP90 InkJet Printer
Keeps telling me the following ink tank is not installed - color ink tank It is installed and i have replaced it with a new one
That printer has a little switch on the carriage assembly that is made when the ink is put in. It's a tiny switch easily broken, and you have to replace the carriage assembly if it's broken. Make sure you place the ink in properly, the right side goes in under the ledge and then press down the left side.
Jul 29, 2009 | Canon PIXMA iP90 Mobile Printer
My IP90 stopped recognizing the instalation of the color ink tanh
Take to a ink refill store and ask the to test on there machine(cartridge world etc) it will tell if cartridge is good or not! hope this helps!!!
Jun 21, 2009 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
hope this helps
Oct 20, 2008 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP90 Mobile Printer Logo
1,118 people viewed this question
old marine
old marine
