Question about Philips CDR778 2-Disc CD Recorder
Freezing up The unit will constantly freeze up does not respond to any button but the power button.
  • Anonymous Dec 13, 2008
    i have the same problem i find picking the cd player up nd shaking it makes it responsive again but isnt a permanent fix.
Can you buy a new,lazer for it the player dosenot want to play
Posted on Feb 23, 2007
Try the surface mount ic i had the same problem
Posted on Jan 13, 2007
    President:
  • 3,130 Answers
Sounds like the lasers getting weak ?? time to get a new player?? sorry to tell ya bad news\
Posted on Apr 02, 2006
RT50 control panel not responding
It still sounds like the child lock is on since that prevents accidental setting changes on the refrigerator's control panel.The following will NOT work if the child lock function is activated: Freezer Temp Button Fridge Temp Button Power Freeze Button Power Cool Button Ice Type Button Water Button Ice maker Water OR it may be in Cooling Off/Demo Mode. Cooling Off/Demo Mode is a feature used by retailers to display the refrigerator without running the compressor. If your unit is not cooling, and the bars are constantly scrolling up and down the temperature, check your manual for reset advice
Mar 31, 2014 | Samsung Refrigerators
Belkin f6d46304 v2
hold reset button unplug and plug back in after few secons make sure your ethernet is pluged in from sevice provider
Jan 16, 2014 | Belkin Computers & Internet
Kelvinator fridge compressor running constantly, but freezer section barely freezing
CHECK THE CONDENSER COILS UNDER THE UNIT. THEY PROBABLY ARE DIRTY AND CANT REJECT THE HEAT.
Oct 18, 2012 | Kelvinator Refrigerators
Error when turning system on/constant freezing
when u r done playing and u want to turn ur PS3 off, keep holding the PS button u will see some kind a small menu asking u wither u want to turn off the system or the controller u go with the Turn off the System, thats how u should turn it off, DON'T U EVER shut ur PS3 off by pressing the power button, and about the Freezing thing i want u to turn ur Ps3 off totally NO LIGHT ON, now keep ur finger over the EJECT button and then turn ur PS3 ON buy pressing the 0/1 button from behind, ur PS3 wil make a very loud noise this will make ur ps3 clean it self automatically with no need to open it and get over the freezing thing have fun :)
Apr 16, 2010 | Sony Playstation 3 (PS3) Console
GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Nov 26, 2009 | Refrigerators
My 9242 HD PVR is constantly freezing. Is there a
Try unplugging the unit from the wall for a couple of hours to see if the unit will reset. Also you could try and see if there is a firmware update for the unit from the manufacturer.
Regards.
Aug 17, 2009 | Televison & Video
Our GE monogram refrig compartment is constantly below freezing.
2 possibilties most likely is a bad temp sensor it thinks its warmer in the refrig than it actually is. the next possibilty is a motherboard has gone bad in the unit.
Jan 21, 2009 | GE GSS20IEP Side by Side Refrigerator
Xbox freezing constantly
You can check out the articleatezinearticles.comhttp://ezinearticles.com/?Xbox-360-Freezing-Fix&id=1527369formoreinformation on fixing freezing problem of your xbox 360
Jan 01, 2009 | Microsoft Xbox 360 Console
Outside unit freezing over
check the outside drain in the pan if there is a plug in the bottom pull it out.the ptac unit will go into emergency heat and run more the colder it gets outside
Nov 23, 2008 | Amana PTH123B25AJ Heat Pump Air...
Sansa c250 constantly freezing
Hi
Try to scan with antivirus!!! maybe your unit is have a virus thats why your unit is freezing.
Thanks! Likha
Sep 20, 2008 | SanDisk Sansa e250 MP3 Player
Philips CDR778 2-Disc CD Recorder Logo
187 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
