Question about Palm LifeDrive Mobile Manager Handheld
Versamail Errors Hi. I just bought a wi-fi card for my palm Tungsten T5 and tried to set up Versamail to connect to my optonline.net account. I can receive e-mail without a problem, but cannot send any. I've received the following messages: 530 5.7.0 no Auth command and 553 5.0.0 unbalanced < as well as messages about timing out and errors with the SMTP server. Please help, I need to use the palm to send attachments on an international trip and have to resolve this problem. Thanks!
    Champion:
  • 277 Answers
Hi first of all here are Support Knowledge Library links: http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(39328) there are two main reasons your mail will not get sent from VersaMail: 1) The outbound email server is not allowing your mail through. The server thinks your email is SPAM. Go to the section on Outgoing Mail server issues: http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=95,E=0000000000299122694,K=3846,Sxi=5,useTemplate=Case.tem,CASE=39211#outgoing 2) You have entered some of the information incorrectly in your setup and need to check for typos and verify the settings with your ISP or carrier. follow all the instructions home page: http://www.palm.com/us/support/lifedrive/ good luck
Posted on Mar 21, 2006
SOURCE:
I have bought a Palm Tungsten T5 which came without installation disc. Can you help.
Here is a link to all the downloads you will need. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/t5/unlocked/home/page_en.html
Nov 14, 2009 | Palm Tungsten T5 Handheld
Cannot create versamail account that can work with my business
If you aren't using an sd card by now, you should. If this is helpful, please post as such. TY
Jan 16, 2009 | Palm Tungsten E2 Handheld
Tungsten e2 wi fi card
this weblink might help you
http://www.palm.com/us/products/handhelds/e2/
Easy wireless connections
Bluetooth wireless configuration is easy, quick and intuitive. Use the Bluetooth Manager as a one-stop-shop to configure wireless connections for HotSync, Internet access, text messaging or to dial phone numbers from Contacts.
Synchronize wirelessly
Transfer information from your handheld to your Bluetooth-enabled computer from across the room. Anything you can sync via cable or cradle you can sync wirelessly – Contacts, Calendar, photos and documents.
Send email and access the web1
Browse the web with the Blazer® web browser and access your email with the VersaMail® email client. Simply connect your handheld to a Bluetooth equipped mobile phone, or a Bluetooth equipped laptop connected to the Internet.
Jun 22, 2008 | Palm Tungsten E2 Handheld
Wi=Fi connection
Hello
First question is do you have a wireless router connected to your internet, and if yes, you may need to tell your router to broadcast your ssid. Instructions differ on how to do this so check the manual for the router. Hope this helps.
May 25, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Palm Tungsten t5 WiFi
I suspect that you're in fact holding a Palm TX and not a T5 as the T5 does not have WiFi. If you're using the Palm SD WiFi adaptor, do a hard reset without the card.
(hold down the ON/OFF button whilst using the reset pin to press the reset button. You'll be asked if you are sure you wish to reset. You'll then be prompted to choose the language caliberate the screen etc..)
After that. Go and download all the updates and drivers from Palm Web site.
Oct 04, 2007 | Palm Tungsten T5 Handheld
Setup Versamail with Outlook 2000
This would likely occur if the M$ I-Explorer is configured for OE as the default Email application. To inspect and change, ope IE, select Tools/ Internet Options/ Programs. Change the Email selection to app currently utilized.
Sep 15, 2005 | Palm LifeDrive Mobile Manager Handheld
I use Versamail with my web-based, non-work email account (which is what it sounds like you have - web-based at least). I don't sync Versamail, I just use it to dial in to my account and download/send emails.
Sep 15, 2005 | Palm LifeDrive Handheld
T5 Outlook Calendar Synchronization failed - Any one have a fix?
I went to the MY COMPUTER folder, clicked open PROGRAM FILES, open PALMONE folder, open the username folder and deleted the back-up files. However, before I did this I deleted all of the problems dates in the PC calendar and set the hotsync to PC overrides handheld. While this works, unfortunately I have found that I need to do it every once in a while which is very disappointing. It seems that Windows does not operate seamlessly with the Palm T5. I find that the hotsync crashes 50% of the time forcing me to reset my Palm T5. No information is lost, but it is really a pain in the *** to have to do so often. Versamail hotsync sometimes freezes on the handheld, but that is another issue which I have managed to fix much in the same way as describe above.
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Is possible to sync only a specific folder of Outlook?
Yes - you can specify which folders. By default the VersaMail conduit synchronizes the Inbox folder from your Outlook/Exchange account. If you do just as you mentioned creating a MyPalm folder, you will be able to have only that folder synchronize. Open up the Custom menu item from the HotSync icon. From there select the VersaMail conduit and double click it. Select the account from the dialog that appears - if you have multiple VersaMail accounts, the one to choose is your Outlook profile name. Then click on the Advanced button. Choose the rightmost tab which is called Folders. Here you can individually select the folders which do and which do not synch. Turn the Inbox folder to No and turn the MyPalm folder the Yes. That is it.
Sep 11, 2005 | Palm Tungsten E Handheld
Palm LifeDrive Mobile Manager Handheld Logo
579 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
