Question about HP DeskJet 5740 InkJet Photo Printer
HP DeskJet 5740 won't feed paper correctly
I saw that you fixed a problem with your DeskJet 5740. In my case, the paper jams as it rolls into the printer (every time). Any suggestions? Thanks.
-- Brian
  • benji_vts Nov 24, 2008
    Hi All,
    Mine does exactly the same thing. Is it repairable or should I be looking to buy a new one...?
  • coggz Dec 29, 2008
    I would appear to have the same issue, I am hunting for a solution now, and will post back here if I find one..
  • 724 Answers
Only time I have seen HP printers not feep properly is
small piece of paper in the way that is hard to see
Dampness is a killer
and the tractor well it is a drum feed the gears are jumping or sciping in just one spot that will shut the transport dow it has to have a continuous flow other than that I cant see anything else in my mind's eye
Posted on Jul 31, 2009
I put paper on my hp printer and keeps jaming up wht can i do to fix tht problem thank you get to asap thanks again
60 Second printer paper jam fix by hp technician solves feed ...
? 4:56
Oct 25, 2011 - Uploaded by BrokenPrinter1
60 Second paper jam fix by hp technician how to solve feed ...I've been trying to figure out why my printer has been jammingfor days! Days I ...
Fixing a Paper Jam - HP Deskjet 3050 All-in-One Printer ...
? 12:07
Jul 5, 2011 - Uploaded by HP Printer Support
My hp printer was working great until yesterday when I seemed to be taking ... I was able to fix the paper jam error on my friend'shp desktjet ink ..
Oct 20, 2015 | HP Office Equipment & Supplies
HP deskjet 1056 won't feed paper
I just fixed mine. The paper would feed part way then jam and twist a little off center. When I pulled the paper out there was a crinkle on the bottom edge, left side, about 2 or 3 inches in. I did some looking with the scanner removed a saw a plastic tab like the ones that hold and feed 1 sheet at at time. This tab was located inside a little "box-like" thing on the underside of the printer. I turned the printer over. There are several openings/ holes in the 'box'. You can take a pencil or similar object and slide a flat 'tab' that is inside the 'box'. You will see a small spring in one of the holes. Slide the flat tab toward the spring until it locks in place. My printer now works fine. To me the 'box' mechanism looks suspiciously identical to an analog counter wheel. If it is, then it is counting the pages and then engaging the tab to cause a paper jam so you will buy a new printer. Similar things happen electronically to my HP psc 1210 & my Officejet 5610. They will stop scanning or printing, give "no cartridge" error codes, etc... I unplug them for a few weeks and it's like they are new again. PS, if the printer can't talk to HP it will work longer.
Apr 16, 2013 | HP DeskJet Office Equipment & Supplies
My HP Deskjet 5740 says it's out of paper but there is paper in it and no paper jam
you printer need a proper cleaning, please clean your printer properly with an air blower because an small or very tiny peice of paper seems to be stuck in the print roller or paper loader assembly, if that does not work, pls get your paper loader, roler or paper try checked by an printer technitian, you might also have to change your sensor assambly board.
Aug 25, 2011 | HP DeskJet 5740 InkJet Photo Printer
My hp deskjet 5740 shows up with asian language not english in the set up boxes and it is impossible to work out fonts, paper feed, portrait/landscape etc, can you offer a fix
Just unstalled the driver by deleting the printer from the printer and fax in control panel and unplug your printer from the system.
Go to this link below and download the printer driver by selecting your operating System
Double click the installer and in the language column select english (if by default it can be any asian language). Connect your printer only after finishing installation.If the installtion wizard search for the printer hardware,select you will connect it later.
This will solve your problem.
Dec 23, 2009 | HP Deskjet 5740 InkJet Printer
My HP deskjet 5740 will feed the paper through but prints nothing even thought the ink cartriges are full
How long ago was it since you last used it? Inkjet and deskjet printers don't like to sit more than a week or two without you printing anything or they dry up.
Your cartridges may have dried up on the bottom or the part that the cartridge sits in may have dried up. Take a Q-tip dipped in isopropyl alcohol and dab it a few times. Make sure it's totally try before putting your cartridge back in.
Sep 25, 2009 | HP Deskjet 5740 InkJet Printer
Hp deskjet 6122 paper feed
Try putting Isopropyl alcohol on the feed rollers. These rollers become hard and smooth with time and cause all sorts of paper feed problems. You can find isopropyl alcohol at any drug store(it is rubbing alcohol).
Aug 10, 2009 | HP DeskJet 6122 InkJet Printer
Jammed paper
On the bottom rear of the printer there should be an access door with a thumb latch to open it.
Jun 27, 2009 | HP DeskJet 5740 InkJet Photo Printer
Hp deskjet f380 paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 07, 2009 | HP DeskJet F380 All-In-One Printer
HP DeskJet 5740 InkJet Photo Printer Logo
595 people viewed this question
Ben Johnson
