Question about Kenwood KAC-749S Car Audio Amplifier
Car amp power problem
I have two car amps that do the same thing. the power light pulsates and i assume the power does too. what should i look for to be wrong with them?
    Champion:
  • 277 Answers
Hi your assumption is wrong the light blinks for meny diffrent reasons: 1) power is too low - check the battery of the car 2) connections are wrong 3) the AMP is in safe mode here is the manual of the product: http://kenwood.nl.nt.ims.hr/languages/EN/support/manuals/KAC-849~749S%20(EN).pdf here is the home page: http://www.kenwoodeurope.com/support/Menu2.aspx?men=2&M1=3 good luck
Posted on Mar 21, 2006
Pulsating when acceleration
You do not remove the battery cable to clear data
You use a codes reader or scan tool
What that does is clears all your monitors & most
data that has to be relearned
You need to check out why you got the PO420 Converter
Code
Start by looking at fuel trim,cat temp & make sure the spark
plugs are changed every 3 years & you have no cylinder misfires
or fuel control issues & MAF reading are good for your altitude
Could be you never replaced slow & worn out O2 Sensors
at 100,000 miles
Can't tell if what your describing was there before or after the work your did or is even related to engine performance
Feb 28, 2014 | 2007 Toyota Corolla S
Pulsating power drain
1/2 amp is just the computer drain. The rule is if it is not at least a 1 amp drain don't worry about it.
Sep 06, 2012 | 1986 Ford F 350
When i plugg in my rca cables to my amplifer in my car it pulsates the sub really bad.
does the amp light flash with the pulses? if so the amp may be bad, you may have a bad or too small of a ground wire, or the amp may just be pushing too hard. turn the amp power down and see if it takes care of it.
Mar 02, 2011 | Car Audio & Video
My amps protect light is on and the sub wont work and it sounds like it is pulsating
it sounds like you have a short somewhere in your wiring, i would be checking the wires in this order 1)amp 2)rcas 3)back of sub
if after checking these you still havent found anything, one of your wires carrying a positive current has probably rubbed through to the metal on your car body.
so if you disconnect one set of wires at the amp at a time with the power off and then reconnect power you should be able to work out at least which wire set is at fault.
cheers,
dont forget to rate me the thumbs up or not.
Jan 12, 2011 | Rockford Fosgate P3001 Car Audio Amplifier
Legacy audio LA590 car audio amp protecet mode
Is that on all the time or are you saying the light is on? If that light is always on that just means it's protecting your amp. If it's off and not playing bass then your in trouble
Mar 01, 2010 | Legacy Audio American Legacy II LA590 Car...
I have a pioneer gm-d8400m the amp isnt working
flashing light could mean a few different things. 1- constant power may not be there. check with a test light or multimeter. should read around 12 volts. it would be a good idea to check all the power and ground leads. make sure u have a good ground. 2- bad sub. im assuming sub since its a monoblock amp. you can meter the subs. make sure the total ohm load is no less than 2 ohms. any lower the amp will go into protect mode. 3- bad amp. power supply may be bad. the newer pioneer amps are full of protection circuits. ive been a professional installer for a shop about 8 years and we sell pioneer. hope it helps.
Dec 25, 2009 | Car Audio & Video
Amp protector light going on and dimming
first thing you want to check is the fuses in the amp, and power wire if applicable. This might cause the protection light to come on. I do assume you are referring to the protection light on the amp itself and not your car.
Post back if you have checked your fuses and have still not solved the problem.
Thank you for choosing Fixya!
Oct 03, 2009 | Car Audio & Video
Interior & Trunck lights NOT working & headlights pulsate
Check grounds near battery.. you have a short it seems. There are also fuses in engine compartment as well.
Jul 07, 2009 | 1997 Oldsmobile Achieva
Power Light, Pulsating Level Control, Blows Fuses
you may of caused a short in the connections or it got moisture why in storge if so the hole subwoofer is screwed
Jun 07, 2009 | Infinity BASSLINK Car Subwoofer
1000w Sony Xplode car amp
Sounds like the power supply is shutting down because of it sensing a bad output channel. I'm assuming of course that you have checked all your battery, ground, and trigger wires to see if they are OK. Good luck.
Apr 05, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Kenwood KAC-749S Car Audio Amplifier Logo
164 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
