Fan is humming? Need a replacement. Where do I find one? PN I think is AFB1212L
  • 51 Answers
Model and brand
Posted on Sep 09, 2008
Refrigerator hums
Check the fan underneath. If it has stopped, it hums quite loudly. It might just be jammed, but may need replacing. Is everything else ok, i.e.temperature etc.?
Apr 24, 2014 | Samsung Refrigerators
I have a Lasko fan, PN 4914, there's electricity
try it otherwise the reset button is failed and need to test. Another problem is the bulged capacitor or burn capacitor inside replaced.
God bles you
Jul 11, 2013 | Dryers
38CKC036 Air Conditioner: outside fan will not come on makes a humming noise...
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
May 18, 2010 | Carrier 38CKC036 Air Conditioner
Kdt-42we655 red/standby power switch flashes 3 times at a repeat, after tv is turned on just replaced bulb after last on burned out causeing small amount of damage due to clugged fans
Your lamp door is not secure. You may need to replaced the door if it warped. PN: X-2048-503-3. Also, you need to address the clogged lamp fan, it should be replaced. PN: 1-787-460-11.
Mar 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Our TV is making a loud humming noise. We think
It's likely your color wheel rather then your fan. I've replaced quite a few of these and the fans are usually good. Get and estimate - I generally charge $250-350 Total
also google your model # and color wheel to investigate further.
Oct 24, 2009 | Toshiba 52HM95 52" HDTV Projection...
Doesnot spin or agitate.
if you have the front panel off and you can see the motor is spinning the belt is turning then your transmission has failed.waring keep hands clear of all moving parts! transmission pn wh38x10002 for around $185 if mtr is not moving pn wh49x10040 for about $240 depending on what you need and how old your washer is it might be time for a new one
Dec 13, 2008 | Washing Machines
Error code on Digital LG Dehumidifier - CH 1
Change the sensor assembly, Part # 6877A30013M from Appliance Factory Parts in Englewood CO, about $30. Easy to change, plugs into control board, remove old temperature probe by pry T-well open with small screwdriver and then crimping back closed when new sensor is installed, about an hour start to finish, hardest part is getting all the covers off. Mine is back to working like new again!!
Nov 10, 2008 | LG DH404E Dehumidifier
Fan Replacement
If the fan spins freely the problem is most likely not the fan but the 8 pin smd Mos-Fet fan speed control current amp has failed. Not difficult to replace and are a common problem with these projectors.
Jun 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
