Question about Motorola Mobility C650
Motorola C 650
My phone is not charging and I have tried other batteries & chanrgers.
  • the amazing Apr 26, 2008
    MY MOTOROLA C650 does not charge tried chargers new batteries and still does not charge
Boot Loader
07.B0
SW version:
R364_0_0b.d1.1
AR
Batter OK
OK to Program
Connect USB
Data Cable
When my Motorala c650 not in frequent function. What I will do to repair/work with it.
Posted on Oct 25, 2008
Hi, I also find like this case, Plase carefully open the connetor, and press the ground plate at rear position of connetor. Just push smootly.
Posted on May 01, 2007
    Champion:
  • 277 Answers
Hi your inlet is probebly bad there is a small tab inside there try pushing it out a little bit so the connection will be good dont be too aggressive or you will brake it good luck
Posted on Mar 21, 2006
Just purchased new battery and when I tried to charge it my phone shuts off. Why?
Let it fully charge before turning it on for the first time.
Mark
Motorola Support
Apr 30, 2014 | Motorola Mobility E815
Motorola Fire XT (XT530) charging problem .
Motorola FIRE XT Tips for extending battery life
Back to Previous Page
Are there any tips on how to extend the battery life?
Things you should know about charging your battery.
New batteries are not fully charged. Plug the battery charger into your phone and an electrical outlet. Your phone might take several seconds to start charging the battery.
Tips:
  • It may take several charging cycles for your battery to reach optimum performance.
  • The battery charger shipped with this device is designed specifically for Motorola mobile phones. Other chargers might take longer to charge your battery, or cause your calls to fail during charging.
  • You can charge your phone via USB cable but this charging time will vary based on computer specifications.
Tips to extend battery life:
  • Select a shorter backlight duration
  • Lower the display brightness
  • Use the AC adapter to charge your phone whenever possible
  • Turn Bluetooth off when not in use
  • Turn Wi-Fi off when not in use
  • Close any third party applications running in the background
  • Playing music, videos and viewing images in your phone will affect your battery life
General Battery use & safety
  • Motorola recommends you always use Motorola-branded batteries and chargers. The warranty does not cover damage caused by non-Motorola batteries and/or chargers.
    Caution: Use of an unqualified battery or charger may present a risk of fire, explosion, leakage, or other hazard. Improper battery use, or use of a damaged battery, may result in a fire, explosion, or other hazard.
  • Your battery can be charged without it being fully depleted, and can be charged every day if desired.
  • Battery usage by children should be supervised.
  • Important: Motorola mobile devices are designed to work best with qualified batteries. If you see a message on your display such as Invalid Battery, Invalid Charger or Unable to Charge, take the following steps:
    • Remove the battery and inspect it to confirm that it bears a Motorola "Original Equipment" hologram;
    • If there is no hologram, the battery is not a qualified battery
    • If there is a hologram, replace the battery and retry charging it
    • If the message remains, contact a Motorola Authorized Service Center
  • New batteries or batteries stored for a long time may take more time to charge.
  • Charging precautions: When charging your battery, keep it near room temperature. Never expose batteries to temperatures below 0°C (32°F) or above 45°C (113°F) when charging. Always take your mobile device with you when you leave your vehicle
  • When storing your battery, keep it in a cool, dry place.
  • It is normal over time for battery life to decrease, and for the battery to exhibit shorter runtime between charges or require more frequent or longer charging times. Motorola batteries are designed to last between 350-700 charge/discharge cycles at room temperature. This amounts to approximately a year to a year and a half of battery use for most people.
  • Avoid damage to battery and mobile device. Do not disassemble, open, crush, bend, deform, puncture, shred, or submerge the battery or mobile device. Avoid dropping the battery or mobile device, especially on a hard surface. If your battery or mobile device has been subjected to such damage, take it to a local service center before using. Do not attempt to dry it with an appliance or heat source, such as a hair dryer or microwave oven.
  • Use care when handling a charged battery-particularly when placing it inside a pocket, purse, or other container with metal objects. Contact with metal objects (such as jewelry, keys, beaded chains) could complete an electrical circuit (short circuit), causing the battery to become very hot, which could cause damage or injury.
Apr 17, 2014 | Motorola Mobility XT530 Fire XT Black...
Re: motorola tracfone
firstly sir check your charger is he capable to charge your phone..and secondly check your battery is she working well
Jan 27, 2010 | Motorola Mobility RAZR V3
Motorola w220 invalid battery problem
you better change the battery and dont recharge too. charge daily per hour
Sep 19, 2009 | Motorola Mobility W220 Cellular Phone
My motorola slvr L7c will not charge.
try removing the battery and make sure it's in properly and try again
Jun 22, 2009 | Motorola Mobility SLVR L7 Cellular Phone
"unable to charge"
I had an old Motorola V3, which used to show me that error. It could result if the charger is not firmly connected to the phone. To diagnose this, try borrowing someone's moto charger. It's also possible that battery contacts could have dust. Try dusting them off so that they're nice and shinny as usual. Finally, try removing the battery for a few minutes, reinsert and charge, leave the phone off when you charge. The phone usually starts working after the regimen. If the problem persists, you'd know which method worked and what failed, so you can press for a warranty. Cheers
Jun 02, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
We had a new battery it Razr/V3c and the phone is working but try to charged the battery and it say "unable to charged" i need to know why it not working.
hi ... i think your battery charge is gone under minimum limit ... Please try charging your mobile with another battery and try to switch on your mobile and after five min remove the battery, charge with your battery and see whether its charging or wat??
May 30, 2009 | Motorola Mobility RAZR V3c Cellular Phone
NTO ABLE TO CHARGE BATTERY
Try charging the battery for a long time.
Feb 29, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Hello I got a Motorola Razor "brand new" from e-bay.....
reflash the firmware on the phone or service it
Dec 07, 2007 | Motorola Mobility RAZR V3
Motorola Mobility C650 Logo
64 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
