Question about Kenmore 72073 Top Freezer Refrigerator
Top freezer opens when lower door is shut
When the lower refeg. door is shut sometimes the upper freezer comes open
  • govinda_sr Sep 13, 2008
    I started out with the same problem. It got worse. My freezer and fridge just pop open spontaneously. I have been duct taping them shut. Now the seal just refuses to you know, seal. So the milk's been spoiling in 2 days, etc. So last night I taped the top and bottom shut with painter's tape, all the way around. It was very cold this morning so I know that the seal is the problem.
    I am going to try the boiling water and hair dryer tonight. I sure hope it works. I miss having refridgerated food.
  • 76 Answers
This could be the door rubbers, try boiling some water and pour it slowly over the rubber,it would turn soft and wold return to the original state.
now close the door and with a hair dryer set on hot,blow on the rubber untill it seals all over.
let the door stand close for at least 6 ours...
Let me know if it worked..
Good luck.
Posted on Sep 09, 2008
The top freezer door opens slightly and then reseals whenever the lower refrigerator door is closed
The lower section is connected to the top section through a common opening in the freezer floor. Shutting the bottom, being it is larger, will force air to open the top door. I installed a roller for a cabinet on top of my fridge to keep the door from pumping open. It is used to keep children out of cabinets. It is a roller wheel mounted on a spring loaded arm. It keeps the freezer shut until we open it. Some times the pumping action will force the door open enough it will not shut and things get soft. Hope this Helps Fix Ya up.
Jun 27, 2011 | GE PTC22SBMR Top Freezer Refrigerator
The top compartment in the refrigerator is cooling effectively. But the lower compartment in the same refrigerator is not at all getting cool. Why is this so?
your damper vent door from the freezer to the refrigerator compartments is either stuck or frozen shut from moisture,sometimes they break and jam too,if this door doesnt open and close your food will get too warm or cold the door needs to move to keep the temperature correct
May 13, 2011 | Whirlpool ET1MHKXM Top Freezer...
Our back door (double glazed with locks at top, middle and bottom) has become permanently locked from the inside. It would appear that the lock at the top has bolted shut. (We have safestyle doors and...
Hi, W/D here.
Easy fix. Your upper locking bar has slipped. While someone is holding the door handle in the open position, you'll need to push the upper lock bolt back far enough to get the door open. You can slide it back carefully with a screwdriver or knife, a little at a time, while holding slight tension on the door with the handle. OK, door's open. Remove the inner door lock cover plate. The lever and locking knob will come off with it. Remove the mortise cover plate, on the edge of the door. Insert a small, thin bladed into the upper alignment slot in the lock behind the mortise cover plate, and loosen the upper allen screw behind the inside lock cover plate. Use the screwdriver to engage a slot in the locking bar, and raise or lower the bar until you have it level with the alignment slot. Tighten the allen screw.
Sometimes, the bar is so far out of alignment that you will have to gain access to the other end of the bar, in order to raise or lower it. This is done by removing the plastic cover on top of the door, and using needle nosed pliers to move the bar.
This should fix you up.
Best regards, --W/D--
Jan 28, 2011 | Locks & Locksmithing
The freezer door on my top-mount no-frost refrigerator comes open every time you shut the bottom door. What is the problem????? Before I purchase another brand...
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Dec 26, 2010 | GE (GTS16BBS) Top Freezer Refrigerator
Why is there no cool air going into my refrigerator when freezer door is shut but works when freezer door is open
Good day,
All cooling comes from the freezer compartment. There is a supply vent connecting the top of the freezer to supply some cold air from the freezer thru the opening on the top connecting the freezer compartment to the fridge side.
As well there is a second opening or return chute located in the fresh food section on the bottom lower half, that allows air to return the air back to the freezer, completing the air flow cycle.In almost all cases, the return chute going from the fresh food section to the freezer compartment has become blocked.
Usually iced up.
It will ned to be completely defrosted. Many times, the return chute is difficult to see and in many cases almost impossible to defrost easily.
If you can see the blockage, then it can be defrosted with the gentle use of a hair dryer.
However, if too difficult to access, you may need to open both doors and leave the machine unplugged for an extended period, usually 12 to 24 hours.
I know it's a pain, but sometimes necessary. Many times, rushing a refrigerator repair is impossible.
The reaon it works when you open the doors is, you have given the machine a secondary source of air from the room.
Jun 29, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
I have a Haier Refrigerator, Model HTE18WAAWW-08. The freezer door has shifted down and the refrigerator door will not close smoothly. How do I adjust the freezer door upward to allow the refrigerator door...
Hi, this is caused sometimes by Teens and Adults holding the door open with there hand on the upper corner resting as they look for goodies, I do this. This sometimes will cause the door to loosen up and move down a wee bit. Look over the hinges on the door, they should be adjustable to see if they have moved. I am sure this is the problem. You can loosen some more, and raise or lower the door. It would be a lot better to have another set of hands to help with this.This will take care of the freezer door.Best of Luck, Sincerely,
Shastalaker7
Nov 23, 2009 | Haier HTE18WAA Top Freezer Refrigerator
On our Fridgidaire refrigerator - freezer door comes open
Good day,
When you close the fresh food door, air is pushed in, and forced into the freezer compartment.
Check to see if the machine is leveled. Slight tilt to the rear is ideal.
If the freezer door fits properly, then usually it is weak magnets in the door gasket, and the door gasket needs replaced.
There are specific details on how to replace a gasket. A qualified counter-man at an appliance parts house will explain the details.
Very important.
Nov 09, 2009 | Refrigerators
Freezer door stays ajar after closing the refrigerator door.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Oct 16, 2009 | GE GTS22KBP Top Freezer Refrigerator
Freezer door stays open when bottom door is shut
Door or gasket is binding on the upper door or the door is bent. Check and loosen the mounting screws on the hinge. Realign then tighten screws. If you moved the fridge lately the door may have sprung open and is bent. Use duct tape when moving fridges to keep doors shut. The door gaskets may be out of place look on all sides top n bottom for one side making up before the other. A realignment may be all that necessary. Door gaskets warped is sometimes helped by heating it with a hair dryer. if they are coming apart its new gaskets time.
Hope this helps please rate me accordingly even if you just read this. And Good Luck.
Mar 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
Re: Lg Lrtpc1831t
Shirlee, you might not have the refer leveled right. The doors should close by themselves when released. Have someone bring the front levelers down so it is pitched back a little. This should eliminate the freezer door staying open. This is caused by the rush of air from the lower compartment to the upper compartment during closing.
Nov 03, 2006 | LG LRTN19314 Titanium Top Freezer...
Kenmore 72073 Top Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
