Question about GE WSM2780W Stacked Washer / Dryer
Holes in clothes
My tenants tell me that the dryer is leaving holes in their clothes.
  • 2 more comments
  • inmankb Sep 09, 2008
    There are no sharp areas in the drum and cannot see any damage to the holes
    is it possible that clothes are sucked into the holes during drying? I can't think of any other way it would be damaging the clothes. And if so, what is the solution?
    More advice please
    Any more comments?
    Master:
  • 638 Answers
It its electricdryer check this
house fuse or breaker ( needs 2! )... - heating element ... - burnt wire ... - thermostats ... thermal fuse ( not all models )... - motor heat switch ... - timer ... - selector switch ... - burnt power cord/plug ...
it its gas dryer check this
glow bar igniter ... - thermal fuse ( not all models ) ... - coil on the gas valve ... - gas valve ... - thermostats ... - motor heat switch ... - timer ... - selector switch ... - sensor ...
Posted on Sep 09, 2008
    Genius:
  • 1,239 Answers
Hi sir..  first see that don't put too many clothes at the time.. because the air will **** too mush.. due to this one reason there may be the problem.. and also see any minutee damage in the machine.. so, due to the mechanic problem,, it may stuck..  and also verify the whether climate.. it is a another problem so it make a black spot's..   thank u .. rate me..
    Brigadier General:
  • 5,158 Answers
Several things spring to mind... what material is she washing....
how is she washing it.... bleach will burn holes in clothes and perhaps that is something you need to check on.
some materials are just not meant to be put in a dryer and when you do they usually require a special cycle.
the cool down cycle may not be working on the dryer if that model has one.
Robert
  • Roberta Smith
    Roberta Smith Sep 09, 2008
    oh and one of my favourite from experience. if her husband works in the automotive trade he may have splashed battery acid on his clothes. the holes don't show up till after they are washed and other materials end up with holes... you wouldn't closely examine washed clothes ... just toss them in the dryer
    Robert
    President:
  • 1,952 Answers
Hey it depend upon quality of cloth...i think all of ur cloth are not gettin damaged at a time...mostly this ll happen due to suction by a dryer...it may also cause due to inbetween gap in ur drum..
tis can be solved by using dryer with very little amount of clothes and also avoid clothes with pins inside dryer
    Brigadier General:
  • 3,614 Answers
You need to check that you are not washing items on wash programmes with a final spin speed that’s too fast for them.
Different manufacturers and different models of washing machine may vary but this chart shows that certain items should not be spun at full spin speed –
  • Cottons: 1400 rpm
  • Minimum iron: 1200 rpm
  • Delicates: 600 rpm
  • Woollens: 1200 rpm
  • Silks: 400 rpm
  • Shirts: 600 rpm
  • Denim: 900 rpm
Other possible causes of holesBra wire (or underwires)
Other obstructions in the tub, a damaged drum, loose drum lifter etc.
Buy drum lifter or drum paddle
Zips and buckles
Biological detergents could damage wollens and silks
Bleach
Hope this initial info, helps you in your problem..
Any further assitance, let me know.
Regards,
micro-
  • 1 more comment
  • micromaster
    micromaster Sep 09, 2008
    got my post over here:
    Regards,
    micro-
  • micromaster
    you need to check that you are not washing items on wash programmes with a final spin speed that’s too fast for them.
    spin speed –
    • Cottons: 1400 rpm
    • Silks: 400 rpm
    • Shirts: 600 rpm
    • Denim: 900 rpm
    1. Other possible causes of holesBra wire (or underwires)
    2. Other obstructions in the tub, a damaged drum, loose drum lifter etc.
    3. Buy drum lifter or drum paddle
    4. Zips and buckles
    5. Biological detergents could damage wollens and silks
    6. Bleach
  • micromaster
    Kindly please rate my solutions, will yah?
    Master:
  • 505 Answers
Hey guys it also depends how you wash the cloths to. if there not wash right the cloths split and the stress in the dryer or washer can split the material and make holes
  • Make sure tenants aint wearing your cloths to lol
  • maby there trying to scam you so you can re in burst the cost of the cloths
    Genius:
  • 1,142 Answers
If clothes are old then there is a chance that the clothes can get torn while getting sucked in the drum spaces while spinning...otherwise..it has to be problem with the spin drum...
  • 1,031 Answers
Holes will be when they get stuck when the dryer is still turning most especially if it is getting stuck between the inner and outer drums check to see if there is any wobble in the inner drum by opening the door and placing your hand at the top of the outer rim of the panel and place your fingers to the top of the inner drum pull your fingers towards your hand if there is any movement other than the bearings are gone which will need replacing once done then this will solve the problem if there is no movement check to see if there is a seal missing from between the inner and outer drum u can check this out using your fingers .
  • 1,879 Answers
Dryer cant do that - have the washer checked OR a possibility that they have very sharp *blings* on their clothes when they washed them
  • 435 Answers
Its better to change the belts & the assembly that holds the door.
Also, replace the drums....
Thanks
    Master:
  • 726 Answers
Ok make sure there is nothing stuck in the machine that is sharp ,make sure none of the little holes though out the machane are damaged and check if there lying to get free clothes lol joking
Why is my hotpoint tcm570 tumble dryer leaving a puddle on the floor
Since no dryer I am aware of uses any liquid, I suggest you may be putting wet clothes into the dryer.
This can happen if the washer does not spin the clothes nearly dry. Many dryers have small holes in the dryer drum to let excess water flow out, I would guess that may be the case with yours.
Are your clothes nearly dry when they come out of the washer?
If not, perhaps the washer has a loose belt or has a problem with the "dry" cycle.
God bless your efforts.
Nov 02, 2015 | Hotpoint Dryers
Why is the metal screen with round holes located in my dryer drum melting some clothes and leaving its impression on those clothes. My appliance is a Frigidaire gas dryer model # LAQG7011KBO.
The metal screen is the place where the heat from the dryer enters the drum. If the dryer is melting items, you have one of two possible issues:
  • The dryer thermostats are allowing the dryer to get too hot.
  • You are drying delicate clothes on too high of a heat setting.
Jan 14, 2015 | Frigidaire Dryers
Ge dryer makes holes in clothes
That is worn glides and bearing like in this video I made:
Oct 11, 2012 | GE Dryers
Clothes with pin holes are seen afetr washing/drying with He2 plus/He Washer dryer combination
Are you over loading the dryer? I know those combo machines can't dry a lot at once
Apr 28, 2012 | Kenmore HE2 Plus Front Load Washer
Dryer makes small holes (cigarette burn size) on clothes
Get a new dryer. Old ones tend to tear-up clothes and burn holes.
Apr 29, 2009 | Dryers
Holes in clothes
I'd bet the holes are the same size as the holes in the dryer tumbler. the only thing I can think of is that your dryer isn't tumbling and the heat that is pushed through the holes is burning your clothes.
Apr 18, 2009 | Miele Novotronic Premier 500 Front Load...
Holes in Clothes
You'll need a drill with a wire brush attachment and take that to the front of the heating element. The heating element gets a lot of crud built up on it and yes it'll put holes on clothes.
Apr 02, 2009 | GE DWSR405EBWW Electric Dryer
Holes in clothes
Be carefull not to overload and inspect around door and heat entrance area for catch points or sharp areas.
Its usually Washers that tear clothes inspect closly to determin cut or tear. if tear try smaller loads with only similar materials
Dec 31, 2008 | GE DCSR483EA Electric Dryer
Holes in Clothes from Dryer
clean dryer vent. check the inside of drum for sharp points and the back for proper seal.
Jul 12, 2008 | Kenmore Dryers
GE WSM2780W Stacked Washer / Dryer Logo
207 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
