Question about Toshiba Televison & Video
Toshiba 36A61 Analog CRT TV
The set suddenly shut down and left only the power light blinking. The remote wouldn't turn it on or off. I unplugged for 10 minutes. It came up with a very dark picture and garish colors. A few more turn ons and offs and color/tint set to minimize red, it still has a magenta overall cast and magenta smearing from bright areas. Degaussing doesn't help.
  • 51 Answers
Check the blue and green drive ics..they will be transistors on the crt board
Posted on Sep 09, 2008
TV images have gone green
power might be to low for it
Apr 16, 2010 | Toshiba 32HFX71 32" TV
Toshiba 36A61 TV Deglaussing Problems
DEGAUSS IS INTERNAL AND ONLY WORKS WHEN THE SET IS FIRST TURNED ON. YOU WILL HAVE TO OPEN THE SET AND EITHER SOLDER THE BURNT CONNECTION OR REPLACE THE THERMISTOR. THE DEGAUSSING COIL GOES AROUND THE OUTSIDE OF THE TUBE(INSIDE THE SET) 2 LEADS AND PLUGS IN CLOSE TO THE AC LINE CORD. IT IS CONNECTED THREW A TEMPERATURE COMPENSATING RESISTOR THREW A RELAY DIRECTLY TO THE A.C. LINE INPUT FOR ABOUT 2 SECONDS WHEN THE SET IS FIRST TURNED ON.
Dec 27, 2009 | Toshiba 36A61 36" TV
Power problems problem on
I would try a power drain:  Unplug the TV's power cable so the TV is not grounded to the house.  Then press and hold in the TV's own power button for one minute to drain the capacitors. Plug the TV back in and see what happens.  If the TV will still not turn on, I would say you have a problem with the TV's mainboard as a dead power supply will not light any LED's for you.
Mar 24, 2009 | Toshiba CN36X81 TV
Toshiba 32AF43 problems
bright red with lines left to right? would be shorted crt. shutting off would be normal due to high beam current.
Nov 09, 2008 | Toshiba 32AF43 32" TV
SCreen turns red then shuts off
The 46H84 has 3 CRTs instead of a lamp. Red, Green and Blue. Your red CRT is shorting out shutting down the set.Here is how you test that theory. Remove the speaker grille, there will be an access panel behind the grille remove that and you will see the CRTs red is usually on the left. hit the power momentarally to locate which tube is red. then power down and unplug the power cord. Carefully remove the tubes Circuit board. ( you may have to carefully slice the glob of silicone applied at the factory to get the circuit board off) Once you have the circuit board off the Red CRT make sure it isnt touching anything and try powering up the set. If the set stays on and the other 2 CRTs light up. That tells you the RED crt is shorted and thats whats shutting your set down. Let me know if I can assist you further.
Mar 25, 2008 | Toshiba 46H84 46" Rear Projection...
Tv power light flashes on and off, but no picture or sound
the problem is, the system control or "jungle" ic as the call it was malfunction need to replace.need more help....dnlsabangan@yahoo,com.
Feb 15, 2008 | Toshiba 36A61 36" TV
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Power but no picture on a toshiba 36a61 36" tv
could it be the socket wirings was loose check and retightened. more help....dnlsabangan@yahoo.com
Nov 09, 2006 | Toshiba 36A61 36" TV
TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Jan 11, 2006 | Toshiba 43H70 43" Rear Projection...
Televison & Video Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
