Question about Hotpoint Ovens
Hotpoint built in oven top grill element renewal
Do i need to remove oven from base unit to renew element. would appear screw fixings for element are from backside
    President:
  • 1,462 Answers
Yes they are - two nuts on posts that stick out from the base plate plus one screw inside oven opposite the base plate
Posted on Sep 09, 2008
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
How to replace the grill element in a Stoves 720EF double oven?
1) Isolate the unit by turning the power off at the main switch.
2) Remove appliance from housing unit.
a) When handling the appliance care should be taken to ensure the outer frame trim is not damaged.
b) The appliance is secured into the housing unit by 2 screws through the top corners of the front frame, open the doors and unscrew the 2 corner screws.
c) Grasp the bottom of the frame, pull forward and out onto a suitable surface.
3) Unscrew the top and rear panel securing screws and lift the panels clear.
4) From the rear of the appliance, pull off the 4 (top) grill element leads and the earth lead.
5) From inside the oven unscrew the 2 screws from the grill mounting plate.
The above is from the Handbook. I assume from point 5 the element is then free to be removed. reverse the procedure to fit the new element.
If you want a copy of the Handbook, then I will need an email address for you.
Mar 11, 2010 | Stoves 720EF Electric Double Oven
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
We have a hotpoint cooker UY46, our electric tripped the cooker off and , now the nob and grill works but the bottem/main oven is turning on and the fan is circulating but not getting hot ? please help ;(
You need to replace the element. Very easy job remove the back plate from inside the oven (4 screws) and you will see a circular element held in place by one screw in the centre of the fixing plate. Remove the fixing screw then remove two wires and refit new element job done.
Regards Neville
Jul 16, 2009 | Neff U1721 Double circotherm Electric Oven
Oven problem
Check that the solar plus grill element is working properly by selecting full grill, the whole element should heat up, if only half element heats up , then you need to fit a new grill element complete.
If the grill element is o/k , then it is possible the top oven base element is faulty, to check that is working, put top oven on and after a few minutews feel the base of the top oven, and it should be hot to the touch if it is not, then the base element has probably failed , and you will need to fit a new one.
These are the possible reasons for it to heat up slowly.
Plz rate my solution.
Thanks.
Jan 25, 2009 | Ovens
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
I want to replace the top grill element in a zanussi zhq 575
Regardless of wether it is built in or free standing you will have to remove the rear panel, possibly the top cover as well.
The element may be fastened from the inside of the oven .or on the outside at the rear, depending on which way the screws have been fixed.
Undo the fixing screws, disconnect the wires taking note of the connections ,this is very important, and withdraw the element from inside the oven.
Fit new element in reverse order, it is a fairly straight forward repair to do..
Plz rate my solution.Thanks.
Jan 03, 2009 | Zanussi ZHQ575 Electric Double Oven
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Thanks.
Dec 26, 2008 | Ovens
B1641 Fan Element Renewal.
If you can see the element once you have removed the inside rear panel, then remove any screws that you can see, and ease the element forward, pull the wires off, but do not let them slip behind the rear wall of the oven, or it means removing the whole oven, to fit the wires back on.
If you cannot see the screws, or they are fastened from the rear, then it will have to come out of the housing.
Hope this helps.
Please leave feeedback.
Dec 05, 2008 | Neff B1641 Single circotherm super...
Ovens Logo
208 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
