Question about Kenmore Refrigerators
Side by side not cold
Compressor runs for 10 seconds, fan is running. Cleaned coils. Compressor still only runs for 10 seconds. Turned unit off to 30 seconds and turned it back on. Still 10 second cycle.
  • 958 Answers
Compressor overheated or stuck. also check starter relay...maybe broke.
if ever thing is alright,
let it stand for about 4 hours unplugged to cool the compressor.
plug it after 4 hours and if the compressor would still run for 10 seconds, then you have a faulty compressor.
tnx 4 using fixya,
Posted on Sep 09, 2008
Compressor goes in and out
Sounds like low on charge or internal compressor safety.
Jun 27, 2013 | Heating & Cooling
GE Profile Side-by-Side running warm
If it's cutting off at too high a temperature it is a good possibility the probe is faulty. However if the compressor is not cutting off at all, suspect short of gas.
Apr 24, 2012 | Refrigerators
9-10 year old Frigidaire Gallery FRS26ZSH refrigerator stopped cooling as only the fan was running and not the compressor. Cleaned the lower coil and fan of a small amount of dust. The unit worked for 1-2...
might be your compressor relay gone bad. if the condenser fan was running and no compressor that could be the case. Also could be a bad compressor. you could try installing a 3in1 start kit. cost about $30. if doesn't start with that then compressor is kaput.
Jun 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Out kenmore side by size freezer 10 years old with never any problems, notice the freezer isn't very cold and stuff is softening. Help!
First, check to make certain the compressor (underneath the refrigerator) is running. Second, make sure the compressor fan (near the compressor) is running. Third, make sure the evaporator fan (inside the freezer, likely behind an access panel) is running.
In checking on the compressor and compressor fan, look at the refrigerant coils. If they are dirty, they need to be cleaned.
Oct 18, 2009 | Refrigerators
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Whirlpool side by side not cooling
wihtthe modle number you can look up a part, try replacing the overload/relay( starting device) for compressor, may be bad compressor( in which ase youll need a professional) but the overload relay you can do yourself for about 60-75 bucks
Mar 28, 2009 | Refrigerators
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Subzero 590: freezer works, refrigerator not cooling
This is a Sub Zero and many technicians do not realize that these units most all run on 2 separate systems. 2 cold controls 2 compressors 2 evaporators. They share a condenser and condenser fan motor. What you are describing is most likely a bad cold control. It is pretty common for these to get some age and go bad. If you are very savvy with repairs yourself then if you access the compressor area and feel that the compressor on the right is cool and the compressor on the left is warm then you know that the ref. compressor has not been running. UNPLUG THE UNIT OR CUT THE BREAKER OFF. Remove the shelving from the fresh food section and the cover to the lights and the panel below the lights and lean the back panel forward to access the cold control. You will see 3 wires to the cold control. The green wire is the ground wire of corse. Unplug the other 2 wires remembering their location on the control unit. Take a jumper wire and jump these 2 wires. If when you power the unit up the right side compressor comes on then you know that your fresh food cold control is bad. Replace fresh food cold control.
Feb 01, 2009 | Sub-Zero 690 Side by Side Refrigerator
Hot point side by side
Could be stuck in "defrost" mode. Happens a lot. See if you can hear if the compressor is running or the compressor cooling fan is running (in back underneath the unit). Worse case is the refrigerant leaked out and you have a sealed system problem.
Sep 28, 2006 | Hotpoint FFU00 Side by Side Refrigerator
Refrigerators Logo
185 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
