Question about Canon PowerShot A510 Digital Camera
Canon powershot a510
My cameras lens wont go back in........its just out.....it makes a noise as though it wants to go in but it cant.....see what had happened was that it fell on the lens.....the lens was bent half way in....i pulled it out cuz i thought it would help but when i tried to use it.....it didnt work anymore....i cant even view my saved pics or anything
    Problem Solver:
  • 4 Answers
Try this test. While turning camera off apply light pressure to the lens tube to see if there is a point where the gear engages to close the lens fully. This fault indicates broken gear teeth on the outside of the largest diameter barrel. Scrap the lens or use it for parts. A broken gear in the motor gear box will not respond to this test whatsoever. A lens that doesn't fully close, sticks up about a quarter inch and freezes on the Canon logo on power up inidicates the focus mechanism has not fully closed--perhaps a software glitch. The repair involves desoldering plastic ribbon connections and removal of the back panel to gain access to the focusing screw type motor armature to reset the small internal lens so it is flush with the back cover. This lens prevents the lens from completely closing. Reassemble and start taking pictures again.
Posted on Aug 02, 2007
    Scholar:
  • 124 Answers
Well, unless you know your way around those things, i dont think there's any way you can solve this by yourself. chances are some mechanizm inside the camera got broken. Ithink you have no other choice but to take it to repair and hope for the best.
Posted on Mar 21, 2006
I have a Cannon Powershot A510 when I turn it on only a picture of a bird comes up and then screen goes off I cant get to a blank scream to take a picture or lens don't open
Have you removed the battery an waited about 30 or more to reset camera? Sometimes this works. If there is a backup battery in camera remove it also. Generally this means a service for this camera is needed. If you want to send it to Canon, they may charge a lot. IF you can find a local shop that would even look at it make sure you get a price for looking at it. Sometimes it as simple as cleaning off the electronics, or putting the pinion on the drive again for the lens. but most of the time the elecrtronics have failed. Dont ever leave a camera in storage, hot car, attic, boxed up again wth batteries in it. Cameras dont take heat or dust well. Good luck
Mar 27, 2014 | Canon PowerShot A510 Digital Camera
Date and time won't stay set
Had the same problem. The problem is a small button cell that needs to be replaced. From Canon's support page:
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a510?CMD=MIXED_SEARCH&mName=PowerShot+A510&mType=PowerShot+A+Series&pageKeyCode=ekbresults&searchString=date+and+time+wont+stay&BASIC_SEARCH_CURRENT_TOPIC_ID=1236&BASIC_SEARCH_CURRENT_TOPIC_TYPE=0&RESULTS=RELEVANCE&RELEVANCE_START=1&RELEVANCE_COUNT=25&CONFIGURATION=1011&PARTITION_ID=1&TIMEZONE_OFFSET=null&USERTYPE=1&isSecure=false
Jul 13, 2012 | Canon PowerShot A510 Digital Camera
Canon Powershot A510 black screen when taking photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 20, 2009 | Canon PowerShot A510 Digital Camera
Can't format memory card in A510 Canon digital camera.
Have you used this card in the past? Is this a new card?
Is this card rated to be used with this camera. Some cameras can only support cards of certain sizes.
If the card is compatible, take the card to target or best buy and format it on a camera there and see if it works then put it back in your camera and see if it works after.
Mar 07, 2009 | Canon PowerShot A510 Digital Camera
Canon powershot A510 all of a sudden no power??
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try. Recommend trying first the one listed that describes removing the memory card before powering on the camera:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
May 11, 2008 | Canon PowerShot A510 Digital Camera
Canon digital camera power shot A510
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 08, 2008 | Canon PowerShot A510 Digital Camera
Wont start up
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try:
Dec 28, 2007 | Canon PowerShot A510 Digital Camera
Canon Powershot A510...
The a70 drops a screw in to the mechanism.
you will need to take the unit apart carefully as it is intricate.
I used a web site to show me but have lost the link.
try looking for cannon A70 problems / erors Etc.
Oct 15, 2007 | Canon PowerShot A510 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Canon PowerShot A510 Digital Camera Logo
261 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
