Question about Compaq Armada M700 Notebook
Controller Driver Issue on Armada M700
Support,
I was wondering if anyone has installed a newer drive (ata100) into an Armada M700 and running windows xp home? My particular question is what driver is installed for the ide ata/atapi controllers? If you have an ata (ide/eide) drive does it use the sata ahci controller driver? This is found under device manager.
Thanks,
348patterson
I am running a Armada M700 with a Hitachi HTS541060G9AT00 60GB Hard Drive - Ultra ATA-100, 5400 RPM, 8MB. The driver that is loaded in mine is on both primary and secondary is atapi.sys. This driver is also installed on the Intel 82371AB/EB PCI Bus Master IDE Controller, along with intelide.sys. The main difference is I am running Window XP Pro SP2. But I believe that they should use the same driver.
Hope this helps.
dferguson64
Posted on Sep 17, 2008
My Dell poweredge 600SC has a Dell CERC ATA 100/4 Ch Raid controller that is emitting a continuous shrilling tone. Bad card or bad drive?
I'm assuming by now you've resolved this but if not it could be either the drive went bad OR due to a raid card driver issue the controller card thinks the drive is failed. I have three of the 600SC machines in my test lab and have experience the following issues.
= W2K3 Server
The native driver that will install with W2K3 has a number of times caused the CERC card to think a drive is failed. When using the driver from Dell's site and either using F6 at the beginning of the install the problem is resolved.
= Linux
Newer releases (circa early 2009 on) of Linux don't directly support the CERC ATA100/4 ch card and the driver has to be compiled into the kernel from the source code. Specifically my experience is with CentOS 5.2 and later.
I have a number of clients that are using both Dell 600SC and 400SC PowerEdge servers and have spent an inordinate amount of time learning to deal with these PITA controllers.
Anyone who like to share more regarding these can contact me at Shaferconsulting.com
Cheers!
Mike Shafer
Feb 09, 2010 | Dell PERC2 4-CHANNEL RAID CONTROLLER CARD...
Installing wifi in Compaq Armada m700??
yes, aslong you have USB port or PCMCIA card slot
if your compaq armada m700 is the p III series it's alot better
Jan 25, 2009 | Compaq Armada M700 Notebook
Armada M700 & Linux XP 2006
Yes I used the latest version of Ubuntu Linux.
Get it here
Ubuntu 8.10
You will need to install NDIS in linux after the install to use the windows drivers for your wireless card if you have one. Sometimes older wireless cards will work but most of the time you need the NDIS to use the windows disk that comes with your wireless device(if you are using one) Your hard wired ethernet port should be detected automatically as well as all your other drivers(since the machine is old)
Good luck..if you need any more help I will be around. No other compatibility issues exist, and it will run a lot faster than XP. I would suggest 512MB of Ram but 256 will handle it fine.
Oct 14, 2008 | Compaq Armada M700 Notebook
Fujitsu Drive installation on Armada M700 Laptop
I would stay away from fujitsu hard drives. They are complete trash. I would stick with either Seagate Western Digital or IBM. I have the hitachi that came with the machine and although it is slow it still works after over 10 years. I would like to know more about your situation if you need help installing it tell me what it is doing.
Sep 17, 2008 | Compaq Armada M700 Notebook
Installing a Seagate Dive into an Armada M700
Here at my shop I have run into this exact same problem on several P3 Compaq's and a few Toshiba's. I found that some of these machines, not all, but some, will not accept the 5400RPM drive, but will take the 4200RPM drive just fine. It's just weird because some that do are the exact same model, and I'm not real sure why it won't accept them. I've looked into it and the best that I can surmise is that 5400 is too fast for the reading system in the bios, or it's a power issue. Go with a 4200RPM drive and you shouldn't have any problem. You won't be able to tell any difference in the machine's performance between the two RPM speeds.
Aug 01, 2008 | Compaq Armada M700 Notebook
Wireless card
Let me guess...it comes up as an unknown pcmcia controller.
I have 4 pcmcia cardbus cards and the only one that my armada M700 recognizes is a twinmos B. All others come up as unknown pcmcia controller.
Apr 13, 2008 | Compaq Armada M700 Notebook
Keys arent working
are they #s instead hit fn try to get latest driver for it from site make sure its pluged in tight under it if u know how
Feb 04, 2008 | Compaq Armada M700 Notebook
Keyboard problems
You need to download and install the proper drivers from Compaq (now HP). Go to http://www.compaq.com and do the following:
Click "Get Support" at the top.
Enter "armada m700" in the "Enter a product number" box.
Click the little submit button that looks like ">>".
Click "Download drivers and software".
Click one of the "Windows XP" links. Doesn't matter which one.
Scroll down and click the "Download" buttons that correspond to each driver you want to download.
Install the drivers you downloaded.
Feb 02, 2008 | Compaq Armada M700 Notebook
Will not read DVD-ROM
Computer DVD Support.
Good Luck, Please dont for get to Vote, Follow instructions.Thank you.
Dec 26, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Oct 09, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
180 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
