Question about Whirlpool GHW9400 Front Load Washer
Washer Tub Gasket
I have a Kenmore model 417.42052100 front load washer which I believe is made by Whirlpool anyway. The door gasket slipped off the plastic ring around the tub area, which is creating a major water leak. I'm assuming it is held in place by a spring reatiner around the outer edge of the tub??!! How do I access this, re-install the gasket and secure back in place?
Thanks,
Ron
    President:
  • 1,462 Answers
Remove gasket from cabinet - just held onto cabinet by a simple clamp and fold gasket inside drum. this will give you enough room to access the retainer. you may find it easier to remove the top as well
Posted on Sep 09, 2008
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
My grey rubber gasket around the tub has a 1" rip in it. This is located where you open the front load door and on the grey rubber gasket just inside. Is there a patch kit? Or do I have to replace...
I search on google and no such patch kit. I tried a bike inner tube repair kit and it seems to work, but my holes are less than 1". Check out my post. I have a gasket on the way just in case.
Jan 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have lost a "washable" bear in my HE2 front load washer. I paid sears nearly $200 last month when a small "beanie" hat got stuck somehow behind the gasket. I did nto see how the sears repairman removed...
Door Gasket Removal Procedure
  1. Unplug the washer for your safety.
  2. Open the door and locate the door gasket retaining hoop. Stretch the retaining hoop spring and remove the hoop from the perimeter of the door gasket.
  3. Peel back the door gasket from the lip of the tub into the drum.
  4. Remove the door switch from the front panel.
  5. Remove the top panel/cover of the machine.
  6. Remove the console.
  7. Remove the front panel.
  8. Carefully pull the door gasket from around the inlet and window washer tubes.
  9. Remove the door gasket retaining clamp by loosening the clamp screw on the upper right of the tub opening.
  10. Peel off the door gasket completely from the tub. Be careful not to tear or punch a hole on it.
  11. Reassemble the parts in reverse order of the removal procedures given.
Door Switch Removal
  1. Remove the screws holding the door switch on the right side of the door opening.
  2. Lift the door switch and pull it away from the front panel.
Top Cover Removal
  1. Remove the screws securing the top panel at the back of the machine and lift it off.
Console Removal
  1. Disconnect the ribbon connector from the left side of the central control unit which is located directly above the rear of the tub.
  2. Release the ribbon connector from the wiring harness brackets on the right side of the washer top.
  3. Pull the detergent dispenser drawer out and press down on the release tab at the back of the drawer then pull it completely out of the washer.
  4. Remove the screw in the recessed hole next to the drawer opening.
  5. Open the door and insert a flat-bladed screwdriver into the slot in the bottom center of the console.
  6. Push the console up to release the center tab and remove it from the washer.
Front Panel Removal
  1. Remove the three screws holding the toe panel to the front of the washer.
  2. Lift the toe panel slightly then pull it to the front to remove it.
  3. Remove the two bottom screws and two top screws holding the front panel to the washer.
  4. Remove the front panel from the washer.
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpool Front Loading Door leaking water
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
Jan 03, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Duet leaking out the front door. They replaced
Hello LPeck, This is a pretty common issue with all front loading washers. Typically it has to do with the door bellows (gasket) that seals the door to the washer cabinet.
First, look very carefully at the gasket all the way around, using a flashlight. Pay close attention to the area where the water flows into the washer. This is usually located on the upper part of the gasket and sometimes the water inlet port gets the gasket moved out of place and when the water is flowing into the washer, it can leak outside of the gasket. Make sure that the gasket is properly located around the water inlet port and that the gasket does NOT extend past the water nozzle.
The other thing to do is again look very carefully at the entire gasket for small cuts or tears that might be allowing water to leak out. Even a small cut can allow alot of water to leak out of the wash tub, so carefully push/pull the gasket with your fingers while shining the flashlight onto it.
In almost all cases, it is a cut or torn gasket that is the source of the leak.
This is an easy self-service repair, only requiring a few basic hand tools to remove the gasket bellows from the washer cabinet and inner wash tub. Just fold the back lip from the washer cabinet and you'll see the retainer wire that holds the bellows onto the cabinet. With that removed, you can then slip the bellows gasker off the cabinet lip and see and get at the inner wash tub retaining clamp. Typically held on with a large diameter hose clamp. Remove that and you're ready to install the new one in the reverse order.
Just be sure to let the new gasket lay out to help get most of the kinks out of it, from being in the small shipping box, and install it slowly and carefully, so not to put any cuts in it.
This will save you around $150 +/- instead of having a service tech do the installation/repair for you.
If you want to see and order the part yourself, you can go to the following link to see the gasket and how it is installed. You can order it online from sears, or any place you wish.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=GHW9150PW0&productCategoryId=0153200&brandId=1198&brandDescription=WHIRLPOOL&modelName=RESIDENTIAL-WASHER&diagramPageId=00002&componentDescription=DOOR%20AND%20LATCH%20PARTS&documentId=W0501061&blt=06
Hope you find this Very Helpful and best regards!
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door boot seal on a front load washer how to change
front gasket/door boot.... replacement isn't easy but do-able. first remove three screws that hold front lower panel on and remove panel (where lint filter is). then remove 3 screws that hold on top panel (screws located at rear of top of washer), next remove 3 screws on top front of washer, then remove 4 screws that secure the contol panel. you must remove the washer door at this point, just a few screws and pin hold the door on. now, remove control panel by gently pulling the top away from the washer, it's held by a few plastic snaps. then, remove three screws that secure front panel of washer. now you're ready to remove the old boot/gasket. first look toward lower right side of gasket and pull the spring and remove wire that secures front of gasket. next... at about 3 o'clock on the gasket you'll find a longer screw (about 3 inches) that secures the rear of the gasket. loosen this screw until you can remove the gasket. remove the water inlet and hose from the boot/gasket.... now remove gasket from washer. you're ready to install new boot/gasket. find the small triangle on the new gasket and line this up w/the triangel at the top of wash tub. begin working the gasket onto the lip of tub, make sure to align the triangle and water outlets of the gasket w/the triangle and outlets of the washer tub. once back of gasket is on install the rear wire holder and tighten screw to former tightness. now work front of gasket onto the lip of washer, install spring wire to secure the front. place water inlet and hose into respective holes on the gasket. put front panel back on, put door on, put control panel on, put top on... and wash. like i said, not easy but do-able... i completed it in 1.5 hrs w/no instruction.
Nov 11, 2009 | GE WSXH208A Front Load Washer
Mold on the gasket of kenmore duet front loader. have run the clean cycle, and scrubbed the gasket and inner liner also
This is a common problem with front loading washers. To prevent this issue leave the washer door slightly ajar after use. It will promote air circulation and prevent mold.
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Gasket came loose and rapped around laundry-tub seems loose
if your metal ring (clamp) came off it is most likely due to you shocks or the spring at the top are worn out and need to be replaced. this will happen more often if the cycles are off balance or the washer is over loaded
Nov 26, 2008 | Whirlpool GHW9400 Front Load Washer
Water Remaining in Gasket Around Door
normal problem all front loads all brands.. leave door open as much as possible.. to clean fill tub with hot water pour in 2 cups chlorine bleach use rag in solution wipe gasket out as good as possible allow washer to run normal cycle ..do as routine when ever odor is first noticed leaving door open will allow most of water to evaporate
Nov 19, 2008 | Kenmore Elite 45986 Front Load Washer
Chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool GHW9400 Front Load Washer Logo
163 people viewed this question
Dan Webster
Dan Webster
Sal De
