Question about RCA RCR350 Remote Control
"Input" button doesn't work
We purchased your RCR350 Product and it works for both our JVC TV and Pioneer DVD player. The Problem is the "Input" button, which is supposed to enable the TV to get DVD signal instead of cable, does not function. Since We tried both manual and direct programming with no result please provide us with your technical support. Your help is much appreciated. Regards, P. Najafi
  • 3 more comments
  • Pooyan Najafi Mar 23, 2006
    Thanks for your suggestion. However, as mentioned in our original comment, we've tried every code (direct and manual) and only the "Input" feature doesn't work and as the remote control is brand new it's highly doubtfull that only this particular button malfunctions due ot dust and dirt. Nevertheless, we appreciate your kind suggestion.
    P. Najafi
  • Pooyan Najafi Apr 11, 2006
    I got a way around but not by using the control, you have to use the menue button, and selecting Input.
    Pooyan
  • arunas gaulia Nov 05, 2007
    i programeg TV sanyo and it worked.After, i tryed on HITACHI TV and TV button on RCA remote just lights once,but doesn't come on.Why? And now no reaction on any TV
    you are idiots asking for asisstens 10 dollars, when the item cost 10 dollar.
  • Anonymous May 07, 2008
    input button doesnt work
    Champion:
  • 277 Answers
Hi first of all it is not OUR Product this sites purpose is to Find a solution to a Product with problems we wish to help with your problem! there are some products wich the remote cannot work with you havent signed wuch model you want to control so this is my guess try this remote control code finder: http://remotefinder.rca.com/ enter the unit you need and hopefully it will work if the problem is in the "input" button itself then: 1) open the remote - screws 2) clean the surfaces and check for good connection 3) close good luck
Posted on Mar 21, 2006
How to program the TV remote to work with an APEX DVD player? I do not have the APEX DVD code.
As far as I can remember, the original JVC remote doesn't support a DVD player. It doesn't have the necessary buttons to control the player functions. You'll need to stick with the original Apex remote if you have it, or look for a universal remote that is compatible.
Jul 30, 2011 | JVC AV-32D502 32" TV
I have picture but no sound LG flatron TV and Pioneer DVD player.
connect audio output (RCA Jack white n red color) from the video, to the audio input of your TV. Make sure you use same AV channel for the video and audio.
i.e AV1 or AV2 or AV3
Apr 10, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
How do I change my remote for TV to Input Video 1?
There should be a button on your remote denoting "Input." If you connect the DVD player to the TV on "video input 1" then push the input button on the remote or TV itself until the DVD appears on your TV (which will be Video 1). Some TVs must have the component (in your case) the "DVD" player connected to the TV before the TV will recognize it. Make sure the DVD is powered up and then push the input button until the DVD player appears on the TV. Depending on your TV inputs, there may be multiple inputs like, Video, Component, DVI, or HDMI. The above are listed in the respective order of "quality." HDMI being the best. Whatever input you hook the DVD player up to on the TV will be the "input" you will look for when pressing the input button. Hope this helps.
Oct 26, 2009 | Mitsubishi WS-48515 48" Rear Projection...
JVC RX-888V hook up to cable box - no video
There is some sort of setting you need to change on the JVC receiver. I had this same problem, and I read the manual and it solved it. You need to press and hold down a button to change the mode. Your unit probably says "TV Sound" right now. Once you press this button (not sure what button) like the manual says, the display should change to "DBS" and then it should work just fne.
Mar 20, 2009 | JVC RX-888V Receiver
Can't play dvd player on JVC tv; I don't have a JVC remote.
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
Dec 31, 2008 | JVC AV-32F476 32 in. Television
DVP-NS77H will not work
You need to make sure that you change the input on the TV. It is most likely AUX1 or video input 1. Look on you TV remote for a button that says "input" or "source". Make sure your DVD player is on, press press play, then hit the input or souce button on the remote.
Dec 23, 2008 | Sony DVP-NS57P
Proper input for TV audio signal
Do you have your DVD player running through your receiver? You want the red and white (audio) cables to go from your DVD player to your receiver and the yellow (video) cable to go from your DVD player to your TV. Separate the red, white, and yellow cable into separate strands if you need to, but be careful not to tear the insulation. They should pull apart fairly easily. If I'm totally off or you're using a coaxial or component video/audio cables or a fiber optic cable, let me know. Hope this helps
Feb 16, 2008 | Pioneer VSX-D812 Receiver
Input button
Read further into the manual. If I recall correctly, you have to program the input button seperately. If not, it possibly isn't supported (not uncommon at all, but annoying for sure).
Sep 11, 2007 | RCA RCR350 Remote Control
JVC DVD player problem
You have set the DVD to progressive output for your big tv. The little one will not accept this. Your manual will tell you how to reset it. The remote may be needed. Reconnect it to the big tv and check the menus.
Sep 01, 2007 | JVC XV-N422S DVD Player
The input button
On some sets you can use the menu button to enter the menu and navigate to the page which shows what input is currently selected and change it there. If your set does not have that option, then you will need the remote to do it. I have found that on some universal remotes, the TV/VCR button switches the inputs on the TV when the remote is in the TV mode. If that button does not work on your remote for your set, and you have tried all possible codes for JVC TVs, then the only way to switch inputs is to invest a few dollars more and get an original remote from JVC or have the set repaired so that the input button on the TV functions again.
Jul 11, 2007 | JVC AV-27F702 27" TV
RCA RCR350 Remote Control Logo
1,816 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
