Question about JVC CH-X1000 12-Disc CD Changer
The cable from box to radio
That cable is broken do tou sale by separed?
I need the cable
Posted on Feb 27, 2009
How to change the region on the tv
your going to go to a place sale electronic/tv. your going have buy a converter, the converter changes from pal to usa configuration, take the old cable with you and the new cable you need to convert.
radio shack, big box stores, tv repair places, where the deal with tv and installation service, walmart mite have it, electronic wholesaler,
you r also going to buy power adapter for cycle change or plug in, you just plug it into power cord and than plug into wall. the converter will transfer the 50 cycle to 60 cycles that the united states uses.
you find online, walmart, radio shack, where they may sale tv or call tv repair shop ask for help.
Oct 09, 2015 | Computers & Internet
How do I replace a radio fuse in a 2000 mitshubishi galant?
Wit separate amplifier, could be 10A DEDICATED FUSE 6 or 4 in the engine compartment relay box.
Without separate amplifier, could be 10A DEDICATED FUSE 6 or 15A DEDICATED FUSE 5 in the engine compartment relay box
Jul 03, 2014 | Audio Players & Recorders
Colors have separated in my toshiba big screen. Don't even know where to start with this... Hopefully someone else does.
looks like u had something magnetic around tv,if u have digital cable box hooked 2 it, u may want 2 try swapping that out just 2 make sure it's not box, but prob. tv.look on craig's list 2 find another,or a pawn shop that way u don't have 2 put 2 much money into another,or watch sales at best buy but get warranty.i just deal with pawn shop cause ur taking chances even with new products & u won't have as much money forked over.good luck
Feb 15, 2013 | Televison & Video
I have a 1994 ford escort,my radio,power windows and overheadlight quit at the same time. i checked and replaced the fuses with no lluck. what can i do to correct problem?
You may just have a bad fusible link. This will often cause several of the cars electrical systems like power windows, sunroof, radio etc. to stop working at the same time. It is usually located at or near the battery and built into the cable with a square plastic box that surrounds the cable. Follow the large positive (red) battery cable from the battery connection towards the starter relay. Look for the long separate wires that connect to the starter solenoid or a square fuse box that surrounds the cable. That is the fuse link and has blown due to a current surge condition, the box or insulation around the wires will show bubbling and melting (it's supposed to do that) or it may just have crystallized and gone bad. Basically, it is just a wire or strip of metal connecting the two ends of the cable. Replacement links are available at most auto parts stores. I hope this helps Tim
May 29, 2011 | Ford Escort Cars & Trucks
2002 Sentra, ac/heather electrical problems
most likely you have a blend air door cable that has either been broken, disconnected or stripped out. there are blend doors that control the direction of air flow, and another one that controls temprature. look fr a cable coming from the back of the unit, or if it is a electric then you will have to trace wires. the temp door should be in the rea behind thee glove box.
May 01, 2010 | 2002 Nissan Sentra
How difficult is it to change freq in a sph21dt 2 way radio? Isn't it a simple plug in to a programmer?
You have to go to a Uniden dealer. They have the software, and the cables to reprogram the radio. You could buy the software and cables yourself if Uniden has them for sale. I bought 2 Yaesu FT-2800M's with the programming software and CAT cable (the software and cable cost $30) and found it a delightful and easy way to program the radios.
Longshorts.
Jul 17, 2009 | Uniden SPH21DT (1 Channel) 2-Way Radio
The monitor keeps displaying the menu box randomly in the centre of the screen and I can't stop it from appearing. Can anyone help please?
10% chance it is the button of the menu stitch. Can you tap the monitor on the front, sides or corners without moving it or the cable and make it go into Menu?
80% I'm guessing you have a broken but occasionally touching connection wire in the video cable. Take it off (both ends) and go to Micro Center or PC World and get a replacement. This is an odd problem...
10% chance it is the button of the menu stitch. Can tou tap the monitor and make it go into Menu?
Mar 26, 2009 | Hansol H750 17" LCD Monitor
Info on the SW9800 Subwoofer
I would like to buy your subwoofer for my broken system. Please contact me ASAP
adam.roseneck@gmail.com
Dec 23, 2008 | Philips Cineos HTS9800W System
Starview 3 codes tele 4th dec
4 th dec
tw
co f6 61 87 91 f9 67 57
f0 83 35 e5 28 40 49 b2
Dec 04, 2008 | Audio Players & Recorders
FINDING A RADIO FOR A SEMI TRUCK
Those measurements are a standard single DIN automotive radio.
You need to find a "XM ready" or "With XM controls" radio and install a separate XM receiver box. For example this would be the in dash deck:  http://www.crutchfield.com/App/Product/Item/Main.aspx?o=p&showAll=N&g=300&i=158XRCA350&tp=5684 And this is the XM receiver: http://www.xm-radio-satellite.com/index.asp?PageAction=VIEWPROD&ProdID=3951
I would suggest finding an in dash receiver that also does HD radio as well as XM.
May 16, 2008 | Car Audio & Video
JVC CH-X1000 12-Disc CD Changer Logo
115 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
