Question about NEC PlasmaSync 61MP1 61 in. Television
Problem with plasma tv
I have a 61" nec plasma tv. Just the other day we turned the tv on and only half of the screen was showing. Right now i have the cable box and a dvd player hooked up to it.(they are hooked up separetly). when i try to watch either cable or dvd only the bottom half of the show is visable. any ideas of what is wrong??? we've only had the tv for 2years.
  • Plasma_help Jan 02, 2008
    Same problem with the 50MP1 - eventually the video will reset by repeatedly turning off the on. Once reset the screen operates normally. Any ideas?
  • Anonymous Mar 16, 2014
    can i hook up my cable tv box to my nec px 61xm3a and how
  • 513 Answers
Something in the path to drive the other half of the screen has failed or is broken. Need some basic troubleshooting information in order to be any more specific, but I've seen this problem before with NEC plasmas. If still under warranty better use it Good luck
Posted on Mar 22, 2006
Panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
Apr 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
Hi, My Pioneer PDP 506XDE made a loud cracking noise and now the top half of the screen has no picture but shows only a green film . Bottom half of display is fine
The screen has broken, probably a stress crack waiting to happen from the day the plasma panel was manufactured. It will cost less to replace the TV completely than to have a replacement 50" screen fitted. In the six years or so since your tv was manufactured the screen technology has evolved significantly, fitting a new panel may not even be possible without other major component changes.
The new tv will have a new warranty, but just fitting a new screen will typically get you a maximum 90 day warranty.
Jul 01, 2011 | Pioneer PDP-506XDE 50 in. Plasma TV
32 inch,plasma,will not turn on
Your TV has obviously shrunk by 10 inches.
Other than that, what symptoms did it show before it died. Also what model number is it.
Mar 25, 2011 | NEC - 42" Commercial Plasma Screen ***(no...
Plasma shows half screen
Have a technician come and replace the display drivers or buffers boards they are some times called.
May 15, 2009 | NEC PlasmaSync PX-61XM1A 61 in. Television
Mitsubishi DLP 65 in half of screen is tinted yellow - 3 mth old
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD, DLP & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 26, 2017 | Mitsubishi WS-65857 65" Rear Projection...
Just a half picture on the screen
1. Remove the rear cover 2. remove the perforated large shield on the main board housing (almost in center). 3. Unplug the right top fan and temp sensor plugs ( two small plugs at the top of the main board). 4. Remove screwsthat secure the main board housing, there is also four screws by the video inputs. Do not unplug the board, just gently pull it away 6 to 8 inches. 5. Remove the cover with the Top fan attached (more screws). 6. Now the scan board for the top half of the screen is exposed. The board has four large heat sinks with two large Electrolytic aluminum caps next to each heat sink. 7. The problem caps are at the very top right side of the scan board C192 Nichicon 220 uf next to the IC, the other cap is C120 100UF on the lower side of the IC next to a heat sink. I replaced them without taking the board out. C192 is the one that failed, the other one tested OK but I replaced both.
I got the caps from they are 69 cents each, the Mouser part number for the 220Uf is: 647-UUD1C221MCL1GS (Nichicon 220uFm 16V 6.3x7.7 mm surface mount); the 100uF is:647-UUD1E101MCL (Nichicon 100uF 25V 6.3x7.7mm), both are 105 degree C. I bought two extra spares in case I need them for the future.
Reassemble the unit in the reverse order and you are done. Note if you test it without closing everything, make sure you have the main board shield back on, otherwise the screen will bleed due to the noise from the board. good luck! mine has been working fine.. just like new..
May 16, 2008 | NEC PlasmaSync 61MP1 61 in. Television
A Plasma TV
Sorry forgot to say ours is an NEC plasma PX42vp4g/s
Nov 18, 2007 | NEC PlasmaSync 61MP1 61 in. Television
Broken plasma broken 61
I need one too
Nov 06, 2007 | NEC PlasmaSync 61MP1 61 in. Television
Cracked plasma tv screen
I had one broken a few months ago. I got a couple quotes.. it was about $200 less then a brand new one. I'd just buy a new one.
For the new TV I'd pickup a screen protector for it. My son threw a toy at my TV the other day and I nearly had a heart attack from the flashbacks. Thank God I picked up one of these a few weeks earlier. It stopped it.
Oct 27, 2007 | NEC - 42" Commercial Plasma Screen ****(no...
NEC Plasma
thats bs, stop calling nec, there are plenty of repibuble repair shops who have or can get aftermarket part
Oct 12, 2007 | NEC PlasmaSync PX-61XM3A 61 in. HDTV-Ready...
NEC PlasmaSync 61MP1 61 in. Television Logo
628 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
