Question about Sharp AL 1631 Copier
Sharp copier AL 1631
Flashes a L on the display. No functions
  • 1 more comment
  • Anonymous Sep 10, 2008
    Flashing L and the # 1.
  • Anonymous Nov 28, 2008
    letter L flashing alernately with number 1
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is there any numbers after the L that flash on the screen?
Not sure
Posted on Sep 17, 2008
  • Sharp Master
  • 2,794 Answers
Make sure that the lock isn't on the scanner. It is located under the left side of the scanner. If it's off there could be binding in the cable underneath the scanner causing binding to happen. The scanner glass can be removed and the tension released. If the cable is moving around too much, it can be secured using scotch tape.
Posted on Sep 10, 2008
AL 1631 Grayscale Copier: letter h is blinking in the display unit does not ...
all the codes with(H4,H3,.......)can be removed by simulation 14
May 16, 2010 | Sharp AL 1631 Copier
SHARP AL-1631, SCANNER NOT MOVING WHEN MAKING
You try any zoom copy, I maen 80% small then move scanner.
Apr 21, 2010 | Sharp AL 1631 Copier
My sharp al-1631 will not run when plugged in. the light comes on by the window where the number of copies just flashes H and then 4. is this an easy fix
It looks like you have a bad component in the fuser. It could be a bad thermofuse or thermistor. At this point it would be best to take it in to be serviced by a Sharp dealer as they should be able to repair it fairly quickly.
Apr 19, 2010 | Sharp AL 1631 Copier
On a Sharp AL-1631 copier I installed a new TD Cartridge and ????
That must be the drum cartridge symbol anyway do this; Press C, Exposure, C , Exposure in that sequence.The display will go out. Enter 24 press print 07 print. Then press C twice and you are done.
Nov 12, 2009 | Sharp AL 1631 Copier
Sharp AL-1631 Fuser Unit
The fuser codes are only H2,H3 and H4. To reset , press C, Exposure, C, Exposure.Display goes off enter 14 press print.
Nov 05, 2009 | Sharp AL 1631 Copier
Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Oct 16, 2009 | Sharp AL 1631 Copier
How do you restart a Sharp AL 1631 After replacing the drum
press C - Auto - C - Auto the display will go off . Enter 24 press Print press 7 press Print . It will display 00. Off and On.
Jul 01, 2009 | Sharp AL 1631 Copier
SHARP AL-1631 COPIER NOT RESPONDING
try re-installing the software, and re-post if necessary
May 14, 2009 | Sharp AL 1631 Copier
Sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Apr 02, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
