Question about Canon SmartBase MP390 All-In-One InkJet Printer
Not printing the display is flashing from the normal information to'put in cartridge'and back
    Champion:
  • 277 Answers
Hi by this messege you need to insall the ink cartidge this page allowes you to find what yoy wish, open the "set-up" file and see how to install the cartidge and user manual http://alpha03u.c-wss.com/inc/ApplServlet?SV=WWUCA900 good luck
Posted on Mar 21, 2006
  • ted windem Mar 21, 2006
    home page of the unit: http://consumer.usa.canon.com/ir/control...
    go to:
    "Product / Software Manuals "
Check print cartridge and color button are flashing
The cartridges are coded and communicate as to how full they are, if they are being refilled, the usage, and other data. If you took out your cartridges, then sometimes the printer assumes it is empty when put back, even if they are full. Try to do a Clean Heads option and see if Aligns the heads and gets back to normal.
Jan 10, 2014 | HP Photosmart C3100 series
EpsonstylusPHOTOrx500 red light flashing no action with keys. Normal action yesterday when I tested ink nozzles and replaced two low ink cartridges. All Epson inks. The ink display now shows 100% full...
Try to take out again all the cartridges and put them back and make sure you put them back properly because sometimes and they are not connected properly you will have this problem..
Hope that helps.........
Jul 18, 2008 | Office Equipment & Supplies
It won't print and the light keeps flashing. I lost the instructions!
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Feb 13, 2012 | Lexmark X1240 All-In-One InkJet Printer
I unhooked my computer system to put laminate floor down. Then rehooked everything. Now the printer HP photosmart c5580, after a few minutes the power button and the print photo button and the close up...
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Good Luck!!!!!
Sep 13, 2011 | HP Photosmart C5580 All-In-One InkJet...
How to change cartridge
Step one: Prepare the print cartridge CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print cartridge with a sheet of paper. Follow these steps to make sure the new print cartridge is ready to install into the product.
  1. Remove the new print cartridge from the packaging. Gently rock the print cartridge from front to back to distribute the toner evenly. c00382111.gif CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  2. Pull the tab and remove all the tape from the print cartridge. Put the tab in the print cartridge box to return for recycling. c00382112.gif
Step two: Open the product
  1. Make sure you have turned the product on. Press the Power button if it is not lit.
  2. Open the print cartridge access door, and then wait until the carriage is idle and silent.
  3. Remove the old print cartridge. See the recycling information inside the print cartridge box. c00382110.gif
    NOTE: If you cannot remove or install the cartridges even though the power is on, check the product control-panel display for error messages. If none appear, turn off the power and then turn it back on.
Step three: Replace the old print cartridge
  1. Insert the new print cartridge in the product. Make sure the print cartridge is in position. c00382113.gif
  2. Close the print cartridge door.
CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric .
Nov 07, 2010 | HP Hewlett Packard LaserJet 1022 Printer
How open in laser toner catridge make-xerox model-phaser 3100
Replace the toner: Always use the smart card provided with the new Print Cartridge when replacing the cartridge. The smart card contains the information necessary to reset the level of Toner. Replacing the cartridge without using the smart card may result in the consumable management system being inaccurate.
  1. Insert the smart card provided with the new Print Cartridge into the smart card reader. A "Change Toner?" message will be displayed.
  2. Press the [OK] button. An "Open Front Cover Replace Toner" message will be displayed.
  3. Push on the left and right side of the Front Cover and simultaneously lower the cover.
  4. Grasp the handle on the Print Cartridge, and then raise and remove the cartridge from the machine.
  5. Unpack the new cartridge, and then insert the cartridge into the machine.
  6. Close the Front Cover. A "Have You Changed the Toner?" message will be displayed.
  7. Press the [OK] button. A "Please Wait" message will be displayed while the machine reads the smart card, and then a "New Toner Remove Card" message will be displayed.
  8. Remove the smart card from the reader and dispose of the card as normal office waste.
    NOTE: If the smart card has been used with a previous installation of a Print Cartridge, a "Remove Card Already Used" message will be displayed. The smart card can only be used once. Make sure to use the card that came with the new cartridge.
Aug 30, 2010 | Office Equipment & Supplies
Message says problem with tri color cartridge
I don't think the date on the cartridge is the problem. It might be the electronic on your color cartridge. If there is an orange light flashing and the printer won't pull the paper to print, in 99%, the problem is one of the cartridges. Try removing the color cartridge and gently wipe out the electronic with a dry cloth. Put it back in and try to print. If that doesn't help, try removing the color cartridge and print (I am not sure if that will work, because all in one printers usually need both cartridges in order to print, but you can try that too). You can also try scanning something and see what the message on the printers display tells you. If there is an E an the color button is blinking, I think you should replace your color cartridge.
Apr 04, 2010 | HP OfficeJet 7310 All-In-One InkJet...
I need to change the cartridge on my HP LaserJet 1020, and I can't find the book detailing how to do it. All I need are the instructions................
Step one: Prepare the print cartridge CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print cartridge with a sheet of paper.Follow these steps to make sure the new print cartridge is ready to install into the product.
  3. Remove the old print cartridge. See the recycling information inside the print cartridge box. c00382110.gif NOTE: If you cannot remove or install the cartridges even though the power is on, check the product control-panel display for error messages. If none appear, turn off the power and then turn it back on.
Dec 09, 2009 | Office Equipment & Supplies
All the lights on my HP 1350 printer are blinking and it will not print. Normally where you could put the number of copies i " E" is in thaat spot.
In addition to providing information about current tasks, the lights on the front panel can also indicate error conditions, as described in the table below:
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HPPSC.
2 Turn your HPPSC off and on by disconnecting the power cord and reconnecting.
Alternatively,
All ights blinking: An error caused the HPPSC to stop functioning.
1 Turn the HPPSC off and then on.
2 Restart your computer.
3 If the problem is not corrected, unplug the HPPSC and plug it in
again.
If the problem persists, contact HP.
Apr 26, 2009 | Office Equipment & Supplies
My printer does not print
Try using the utilities of your printer, clear the heads and align them. This usualy happens when the cartridges are new. Maybe the problem is that previous cartridges where empty and the new ones need alignment.
This is just a proposal though i need more information concerning your truoblshooting.
Are the cartridges OEM HP or reconstructed?
When you try to print the green light flashes or not?
try giving any piece of information you can
Dec 01, 2008 | HP Deskjet 2460 InkJet Printer
Canon SmartBase MP390 All-In-One InkJet Printer Logo
32 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
