Question about Hoover H120M Front Load Washer / Dryer
Hoover H110m help needed
Dear sir/madam my washing machine does not spin when it come to spin cycle drum move but not fast enough to drain and spin the cloths.i tried few time and now its even cycle does not complete its stop some time half way through.. can you advise me wot to do thanks
    Champion:
  • 277 Answers
Hello sounds like the drum is stuck probebly the pole is cloged with hair and stuff if you have the skill open the machine and clean all while your at it look for the belt from the motor check her condition - bad? - install a new 1 there is a stretching unit for the belt 1) relese the bolt of this unit and change the belts 2) pull and stretch the new belt and then close the bolt good luck
Posted on Mar 21, 2006
My washer is leaving clothes wet after spin cycle, spin cycle is very weak.
It's possible neither the machine isn't spinning fast enough, which could be the brushes on the drum motor. Or there could be something either blocking the drain pipework or snagging the drain pump impeller
Mar 03, 2018 | Washing Machines
Hoover 2305L goes through all cycles well.does not spin fast enough to dry clothes.
how old is the 7 kg washing machine
should be direct drive to the drum not a belt drive
the motor could be wearing out
are you over loading
May 11, 2016 | Hoover Washing Machines
Hoover optima 614 drum wont spin
Either a broken drive belt or a failed transmission.
Jan 12, 2015 | Hoover Washing Machines
Fast spin not working. drum going round and draining but not spinning. Help!!!!
Possible there is no drive voltage to the motor at this point of cycle, could be due to fault in the controller unit.
Need to check the voltage on the unit to confirm this case as the drain gets connected..
Jul 27, 2012 | Hoover Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
Machine doesn't start cycle properly, rather than slow turning of drum does 3 or 4 short very fast spins, then gives up and the start and pre-wash buttons flash. Have tried draining filter and running...
Sounds like your motor is faulty. It has a built in tachometer or rev counter and if it goes faulty then the motor spins up as though it is on a spin. I'm afraid you may have to change the motor. Not a hard job but it is expensive. Just need to remove back panel or tip machine back or on its side and remove screws holding it. Hope this helps
Mar 03, 2011 | Hoover Nextra HNWL 3166 Front Load Washer...
I have a Hoover washing machine, its a front loader, I don't have the exact model in front me at the moment. I recently moved house, and yesterday after re-plumbing my washing machine, I put the washing...
If water remains in the drum after the drain cycle, the unit will not go into the spin cycle. There may be a couple of reasons for your problem.
Make sure the drain hose is raised above the machine hose outlet to create a siphon effect. The drain hose needs to have a loop in it to work correctly. You can tie a string around the hose and hook it on the water valve creating a loop in the hose. Raise the loop of the drain hose so the top of the loop height is at the center of the washer drum.
Apr 06, 2010 | Hoover AI130 Front Load Washer
Hoover H120M Front Load Washer / Dryer Logo
482 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
