Question about Palm TX Handheld
Touchscreen After performing a Sync, the TX is not responding to touchscreen any longer. Keep resetting the touchscreen and this feature is also giving a problem. Tried resetting the Tx on several occasions sometimes the problems goes away but only until the next Sync Tony
I had a similar same problem. It occured when pluging or unpluging in the USB cable into the bottom of the Palm TX when the other end of the cable was already pluged into a live USB port on my PC.
The solution was to make sure the cable is unpluged first from your PC before you plug or unplug the cable into the bottom of your Palm TX.
Posted on Sep 12, 2008
No signal how do I fix it
You have not said what model garmin nuvi ?
The touchscreen on a Garmin nuvi GPS usually loses sensitivity or stops responding if it's lost calibration.
This usually happens after prolonged usage.
Touchscreen problems are also caused by dirt, smudges and improper care.
If your Garmin nuvi's screen isn't performing as expected, Garmin provides solutions and tips to not only improve the device's performance, but prevent premature wear and tear.
Calibrating the Screen
If the Garmin nuvi's touchscreen isn't working, you need to calibrate the screen.
Calibration resets and repositions the screen for optimal performance without deleting saved settings.
Before calibrating the screen, press and hold the "Power" button to turn off the device.
Pressing and holding the "Power" button again for about 30 seconds automatically displays the calibration screen.
Pressing the dot on the white screen calibrates the touchscreen automatically.
Updating Software.
If The Garmin nuvi's touchscreen is still unresponsive, updating the device's firmware to the latest version can solve operating system problems that lead to touchscreen problems.
Before updating the device's firmware, connect the GPS to the computer using the USB cable. When the computer detects the GPS, the "AutoPlay" menu appears on the screen.
Tapping the arrow on the menu automatically opens the "myGarmin Agent" download page.
From there, follow the prompts to update your Garmin nuvi's software quickly and safely.
Cleaning. In some cases, the Garmin nuvi's touchscreen won't respond to touch if the screen is dirty. Touchscreens are sensitive to dirt and smudges that decrease sensitivity.
If the screen is dirty, cleaning it with a soft, clean, lint-free cloth improves performance.
If the screen is severely dirty, using water, isopropyl alcohol or eyeglass cleaner removes tough stains.
To avoid damaging the screen, apply liquid to a cloth instead of directly to the touchscreen before cleaning it.
Tips.
Refer to your Garmin nuvi's maintenance and storage information found on the device's manual prevents premature wear and tear.
If the screen stopped working after prolonged exposure to extreme temperatures or water, the device's hardware is most likely damaged.
In such a case, you need to contact Garmin for additional troubleshooting and possible repairs.
Attempting to disassemble and repair the GPS yourself only increases the risk of damaging the unit even further.
also it could be a battery problem if the nuvi is not getting power ?
May 08, 2013 | GPS
My v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
Jan 20, 2013 | Visual Land V-Touch Pro (8 GB) MP3 Player
Konica Minolta Bizbub C253
To output a TX Report after every fax transmission, perform the following:
1. Press the Utility/Counter key.
2. Touch [3. Administrator Setting] on the touchscreen.
3. Enter the Administrator password (default password is 12345678).
4. Touch [OK] on the touchscreen.
5. Touch [7. Fax Setting] on the touchscreen.
6. Touch [7. Report Settings] on the touchscreen.
7. Touch [TX Report] on the touchscreen.
8. Touch [ON] on the touchscreen.
9. Touch [Exit] on the touchscreen to return to the normal copy screen.
Please send posotive feed back if this helps.
Aug 06, 2008 | Office Equipment & Supplies
Palm TX power button and touchscreen
We have three TX's in our family with non-working power buttons. I downloaded the program Au Dodo http://www.freewarepalm.com/utilities/audodo.shtml and simply now use the far left button (button 1) as my 'power' button. It works wonderfully.
I haven't found out how to fix the calibration problem, but power on/off has been totally fixed. Good luck for you.
Jul 06, 2008 | Palm TX Handheld
Touchscreen not responding
Hello Cutie,
I would try a master reset it will be your best option, just make sure that you try backing up any informaton to a pc or laptop, or install the motorola phone tools program in a computer and Sync your phone to the pc and then transfer all your numbers, pics and videos or documents u may have stored in there then perform the master reset. Of course if u are having touch screen failure then all this might be a problem. If none of this works for u then you are in trouble because if im not mistaken Motorola has no service repair department, maybe if u call them they may be able to exchange under manufacturers warranty if its under a year.
Good luck..
Jun 08, 2008 | Motorola Mobility A1200
Palm TX erratic touchscreen
Change the screen. You can have the part here, as well as directions on how to change it:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390
Apr 16, 2008 | Palm TX Handheld
Touchscreen
try calibrating the unit
Oct 17, 2007 | Pioneer AVIC-N1 Car DVD Player
Touch Screen Frozen
Note: A master reset will erase all favorites1 and will restore your device to the default factory settings. If you would like to back up your favorites to your computer, you can find instructions to do so on the Garmin site
To perform a master reset on a nuvi 300 series device:
1.Start with the device OFF and unplugged from the power source
2.Touch and hold the top right corner of the touchscreen2
3.Power the device ON while continuing to hold the touchscreen
4.The message "Do you really want to erase all user data?" will appear
5.Remove your finger from the touchscreen when this message displays
6.Touch Yes
After the nuvi resets, follow the on-screen prompts, and then place your device in an area with a clear view of the sky until it acquires satellites.
Although the master reset will erase all saved favorites, any loaded custom points of interest will remain intact on the device.
If the message in step 3 does not appear when using the top right corner of the touchscreen, please repeat these steps using the bottom right corner of the touchscreen instead.
Jan 19, 2018 | Garmin n vi 360 GPS Receiver
Touch screen
You may have dust accumulation around the edges of your touchscreen, between the screen and the case. Try using a can of compressed air. Gently press down on the edges of the touchscreen to expose the gap between the screen and the case, and shoot the air in there. This worked for me when my Treo 600 touchscreen stopped responding.
May 23, 2007 | Palm Treo 600 Handheld
Palm TX Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
