Question about Samsung ML 2010 Laser Printer
Samsung troubleshooting I have a blinking red light with exclamation and the printer is not connecting with the PC what shoud I do?
    Sergeant:
  • 293 Answers
Well my first suggestion is to consult the printer's user manual. (found here: http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf)
However, if both the online/error and toner save light blinks you could be having a spoiler problem, a software problem, or a connectivity issue. If this is connected to the computer directly, check all your connections. See if the error (exclamation mark) has any other information as to what the error might be. Check to make sure the front manual load panel is closed and that there is paper in the general paper tray. Check for a paper jam which the manual will explain how to do in detail. And if push comes to shove restart the printer, reinstall the drivers on the computer.
If it is connected to a network or router, check to make sure the computer is directed to the printer on the network and make sure the proper port controller is activated and directed as well. Make sure the network is recognizing the printer or the printer is even plugged into the network.
Posted on Sep 12, 2008
My printer has eror red light indicator on top of my printer what should i do to connect my printer
Dear
The red light blinks for many reasons. You may try to know exact problem with the use of SMART PANEL a software that can downloaded from samsung web site and install in the PC.
After installing the software get a test print. or open the smart panel from the program.
thanks.
Jan 20, 2015 | Samsung ML 1610 Laser Printer
Dr Printer error Unable to connect to the server
Dear
You can use EPM(easy printer Manager) or smart panel. These files can down loaded from the samsung site. install and run in the PC it will show the status of the printer.
The red light blinks and printing is possible means get ready to replace the toner cart. with a new one.
Thanks. Printer Support SAMSUNG India
Apr 25, 2012 | Samsung ML-2510 Laser Printer
Power light blinks on AIO Dell 920 and does not print
does your printer work
this might be a connectivity problem check all leads that attach to your printer make sure they have good connectiond and the leads arent faulty
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Nov 13, 2011 | Office Equipment & Supplies
Apple Laserwriter 8500 paper light out, when there is paper in the cassette. Not blinking. Solid yellow.
make sure the usb lead connection is secure
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? ! question exclamation mark or a red X
hope this helps you
Oct 06, 2011 | Apple LaserWriter 8500 Printer
Epson cx3810 printer have had it for over 2 years, used it only a few times. now I need to use it for a pc free copies, and when I turn it on, I have6 lights blinking, e.g.4 green & 2 red lights
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Sep 05, 2011 | Computers & Internet
Switch on the printer and it goes through its cycle and a red light comes on. With the black toner blinking. I have changed the toner switched on and this time just the red light comes on. Samsung...
unplog the printer from electrik for 10 minutes and try aggain, if the problem still occure try to update the soft ware using the web side from samsung for this printer, this should solf the problem.
Apr 18, 2011 | Samsung CLP-315W Laser Color Printer
The orange light is blinking. Above the light is a triange with an exclamation point in it. I have tried deleting and reloading the printer and that doesnt work.
Do you have a new toner cartridge loaded? The red/orange light will blink when toner is low, even if everything else is working fine. Try printing out a test sheet and see what that tells you about your toner level. (Test sheep prints by holding the orange button down a second or two and releasing.)
Since I'm mainly printing drafts for my own use, I've just let the light blink while I eke out whatever I can from the remaining toner (occassionally removing the cartridge and shaking it -- being careful of clothes and surroundings -- to re-distribute the toner on the inside.
Oct 17, 2010 | Samsung ML-2510 Laser Printer
Printer is on status redlight on lights blinking in yellow and blue carteidge positions
the yellow and blue cartridges are almost empty.go to samsung web site and download smart panet to pc.after installing smart panel reboot with printer connected to pc,the red status will be determined.smart panel will diagnose problem with printer.
Jul 01, 2009 | Samsung CLP 300 Laser Printer
Samsung ml-2850 Blinking Red Light
Change cartridge chip r paper pickup sensor
Nov 15, 2008 | Samsung ML-2510 Laser Printer
Samsung ML 2010 Laser Printer Logo
250 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
