Question about Canon PIXMA MP130 All-In-One InkJet Printer
Waste ink absorber almost full
After cleaning pads how do you reset the mp130 (no green light)
    Problem Solver:
  • 18 Answers
4 times
Green
Waste ink counter reset
See waste ink counter reset
procedures helaw.
Service mode operation procedures
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the StoplReset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop 1 Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the StoplReset button the specified number of time(s) according to the function listed in the table below.(Each time the StoplReset button is pressed', the LED lights alternately in orange and green, starting with orange.)
Posted on Sep 18, 2008
Canon pixma mp130" waste
As a short term fix you can reset the counter.
If you reset the waste ink counter without replacing ink absorber, this means that you are may be about to overload ink absorber. If you only do this one time, it may be tolerable. Be careful if you do this more than one time, because it can flood your printer and harm other part.
To reset the ink absorber counter on the MP130
1. Turn on the printer,2. Press the MENU key, and the SCAN, COPY and SCAN again - entered the service mode
3. Select NVRAM ACCESS, pressr OK
4. Select SET ABS-M LEVEL and set value equal to zero
5. Select SET ABS-M LEVEL and set value to zero
6. Turn off the printer POWER button
7. Your printer can now be turned on and is in normal mode
If your absorber is full, call Canon at 732-521-7230 to order the replacement pads for the ink absorber.
If you do not have access to new ink absorber pads, you can extend the life of your current pads by rinsing them thoroughly and allowing them to dry before reinstalling them.
To replace the pad:
1. Open the printer as though you were going to install new
ink cartridges, letting the carrier move to the center of the printing unit. Unplug the printer so that the carrier will remain centered.
2. Locate the waste ink absorbers in their black rubber frame. They will likely be on the right side of your printer, and will be located underneath the area where the ink cartridges rest when the printer is in standby mode.
3. Use a paper napkin or other disposable and absorbent material to soak up any excess ink that may be in the pads by pressing it down onto the top of the frame.
4. Pull the rubber frame free from the printer, wearing gloves to keep your hands clean. Carefully remove the ink absorber pad or pads from the rubber frame.
6. Insert new ink absorber pads firmly into the rubber frame. Replace the rubber frame in its original position and close the printer.
7. Hold down the power button, then plug the printer back in. Continue holding the power button down until the printer begins to reset itself and come online.
8. Wait for the green power light to turn off, then press and release the power button again. It should blink for two to three seconds, then stay lit; this will indicate that the printer has been reset and is ready to print again without errors.
Let me know if you have any other problems or questions. Thanks.
May 18, 2011 | Canon PIXMA MP130 All-In-One InkJet...
The waste ink absorber is almost full
Follow the steps to fix the issue.
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by presing <--- or ---> then OK
3)SET ABS-M LEVEL TO 0
4)OK
Or the steps below.
To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
There ya go MP130 up and running again.
Regards,
Ron
Feb 25, 2011 | Canon PIXMA MP130 All-In-One InkJet...
My Printer - Canon Pixma Mp130 says my waste ink absorbers are almost full, what do I do ? How do I fix this problem ? Please help !!!
If this happens, just turn off the printer plug,then hold the reset\stop button,after that you turn on the plug while pressing the stop reset button, then follow these steps:
-Press Menu-Scan-Copy-Scan to enter service menu.
-Use arrow keys to scroll to "Service menu counter access".
-Press OK.
-Use arrow keys to scroll to "ABS-M DOT COUNT"
-Press Copy.
-Use arrow keys to reset count to zero.
-Press OK.
-Press Stop/Reset.
To clean physical pads (optional):
-Open cover (as if replacing ink cartridge).
-Locate waste ink pads, they are far right under cartridge slider.
-Pry up waste ink pads (inky, might want to wear gloves).
-Rinse pads in sink or with alcohol, dry.
-Replace pads. Make sure pads are fully seated.
Dec 09, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Mp130 waste ink absorber almost full. how to fix?
There are two possible ways to remove the error from your printer. First is to actually clean the absorber pads that are full of waste ink. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads
. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error or E-27.
Use a reset procedure to clear the error in your printer
and start printing again
3.
Press SCAN button
4.
Press the COPY button
5. Press the SCAN button then wait until it enters the service mode.
6.
Select NVRAM ACCESS further OK
7.
8.
Select SET ABS-R LEVEL (if any) and is set to zero.
9.
Do this as many times if the first attempt didn't work until it fully reset.
Aug 08, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber is full and need to be replace unable to print
The waste ink absorber is a pair of pads at the bottom of the printer paper path (one on each side). You can order replacement pads from a service center. Alternatively, you can resuse them. First, you need to pull the old pads (have plenty of paper towels handy). This can take nearly disassembling the printer. Then rinse the pads with running water until they are clean and then let them dry, if you want to reuse them. Once dry, reinsert them and reassemble the printer.
Next you need to reset the counter for the waste ink absorber. With the printer plugged in but off. Press and hold the Stop/Reset button then press the power button. Once the Power light is lit, press the Stop/Reset button twice while holding the Power button. Release the buttons in any order and the printer is in a service mode. With the lights Green, press and release the Stop/Reset button four times (the light will go orange and green alternately and will be green at this command). Set the counter to zero. Press the Power button to save the setting. Then turn on the printer normally.
Do not reset the counter until the waste ink absorber is cleaned/replaced, you will get ink everywhere.
Please note that the printer was designed to fail about the same time that the waste ink absorber counter hits the point that locks the unit. (ie the waste absorber doesn't get full while the unit is under warranty), the printer may have additional failures soon.
I hope this helps.
May 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber replacement options - MP130 or how do I clean it? It is almost full according to error message
Removing & Cleaning the Absorbent pads.
The printer has 2 ink absorber pads that are located under the ink cartridges.
1. With power off the head assembly / cartridges can be moved into the middle for access.
2. Each of the 2 ink absorber pads are seated in a rubber retainer. The pads can be easily removed cleaned or replaced.
3. Carefully remove the pads using long nose pliers or tweezers.
4. Clean the using with running warm water, or use an isopropyl alcohol bath, or an isopropyl alcohol based aerosol if they are really dirty. DO NOT USE ANY SURGICAL SPIRIT OR ANY OIL BASED CLEANERS. At a push you can use a warm water mild washing up liquid bath but be sure to thoroughly rinse out the solution after cleaning. The pads should be white when they are clean.
5. Dry the pads – it may take some time and placing them in a warm environment or near a warm radiator will speed this up.
6. Clean away any ink on the retaining rubbers using a cotton bud or clean and soft lint free cloth.
7. Replace the DRY pads in the rubber retainers.
8. Replace the Ink cartridges.
9. Power on the printer and print a test page and clean and realign the heads as required.
10. If the E27 error message reappears then you will need to reset this.
Clearing procedures for E27 or Error 27 Code.
1. Power on the printer by pressing the Power button while pressing and holding the Stop/ Reset button.
2. When the Power led is green press the Stop/Reset button two times while pressing and holding the Power button.
3. When releasing the Power and the Stop / Reset buttons the printer will move into a service mode and will be Waiting for a menu selection.
4. When the Power led is green, press the Stop/Reset button 4 times for waste ink counter reset.
5. Power off the printer and Power it back on again to complete the reset.
Oct 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber is almost full. How do you empty or replace the waste ink absorber? The printer will no longer print.
if this happens, just turn off the printer plug,then hold the reset\stop button,after that you turn on the plug while pressing the stop reset button, then follow these steps
Use arrow keys to scroll to “Service menu counter access”.
Press OK.
Use arrow keys to scroll to “ABS-M DOT COUNT”
Press Copy.
Press OK.
Press Stop/Reset.
(optional)
Oct 20, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Jul 05, 2009 | Cannon Office Equipment & Supplies
Ink waste absorber is full, what do i do!!!
1. To clean physical pads:
Press OK.
Press Copy.
Press OK.
Press Stop/Reset.
Mar 15, 2008 | Canon PIXMA MP130 All-In-One InkJet...
The waste ink disposal is almost full and it won't print
The waste ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>
WASTE INK NEAR FULL The printer has a built-in waste ink absorber to hold the ink used during print head cleaning, for example. This error message indicates that the waste ink absorber is nearly full.
Press the OK button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact a Canon1.gif service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing cannot be performed until the Waste ink tank is replaced.
this answer is directly from canon
Jan 30, 2008 | Canon Pixma iP6210D InkJet Photo Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
129 people viewed this question
old marine
old marine
