Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
When i turn the control to the off position, it keeps running.
I can go from fwd to rerverse and to off but it still runs, sometimes it will turn off but not erery time.
    Scholar:
  • 157 Answers
Hello james gray. Your description is for a hand control type motor with the control knob on the handle. Disconnect the power to the motor. Carefully disassemble the handel making note of procedures. Check your wiring to control. It would be helpful to use a multimeter to check the voltage on the wiring connections. This should confirm the wiring shorting or most likely a bad switch. The switch could be found from a local electrical supply store or a marine store.
Posted on Sep 29, 2008
Blower shuts off but compressor keeps running.Even if I turn it off. I have to unplug it to turn it off.
On the circuit board there is a micro relay that is stuck in the closed position. Or it is wired so that the sensing ability (thermostat) controls the comp and it is stuck closed
Jul 09, 2015 | Whirlpool Heating & Cooling
Motor will go in rerverse but red light comes in foward shred and will not go
I wish the manual said to clean the sensors. I had the whole thing apart. Cleaned her real good. Put it back together. Still a red light indicating a paper jam. I read this post, really helpful! Cleaned the sensors. We are back up and running!
Dec 03, 2013 | Fellowes Powershred 420 Shredder
INTERTHERM HEAT PUMP/AC. BLOWER KEEPS RUNNING WITHOUT THE COMPRESSOR ON. SOMETIMES FOR HOURS. ALREADY REPLACED THE CONTROL AND LIMIT SWITCH.
Blower? Internal house air blower I assume. - Blower relay contacts pitted and stick in on position.
BAD Control BOARD, fault or adjustment program keeping relay energized. Bad emperature sensor not telling Board unit has use up cold air. loose wiring to sensors and board connections
Sep 11, 2013 | Intertherm Heating & Cooling
2001 silverado security light on after accident
You need to take it to a qualified repair shop .
Dec 02, 2017 | 2001 Chevrolet Silverado 1500
Four wheel drive switch lights flash randomly on dash board
the 4 wheel is run by an electronic motor on ther transfere case it sounds bad
Nov 14, 2012 | 2001 Chevrolet Blazer
Car won't keepidel1989 300e Car won't keep idel, starts up runs for a while but cutsoff
first ensure your spark plugs, wires, cap and rotor/coil packs are in good shape. once thats done check for a check engine light, sometimes they come on then go off but a code will be stored regardless. once you have made sure your getting good spark and there are no trouble codes the issue is most likely a dirty throttle body or fault IAC (idle air control) valve or throttle positioning sensor. hope this helps, good luck
Mar 15, 2012 | 1989 Mercedes-Benz 300-Class
Motor runs on
They have issues with there switches.Depending on model # check for recall. This is a safety issue.
Jul 04, 2009 | Hitachi Drills
System error
ok try this pls take out the mem stick b4 going fwd
factory reset the camera
Home Screen>Settings>Main Settings1>Initialize press OK on Control Button and then OK select Initialize All Settings press OK
then pls turn off the camera and take out the battery then move power switch of camera to ON position for 1 minute
after 1 minute move power switch to OFF position and then put the battery back and see everrything is OK
pls let me know with the results
Rate me FIXYA if i fixed ur problem
Feb 06, 2009 | Sony Cybershot DSC-H3 Digital Camera
Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
118 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
