Question about Pioneer SD-P55A3-K 55" Rear Projection Television
Taking apart and moving a 55 inch projection TV
I have a 55 inch Pioneer Projection big screen TV. It needs to get moved down stairs --- but it has to go around a corner. The last time it was moved in, it was really tough. I was wondering if it was "safe" to take the back apart from the front and move both pieces independently - then reassemble it down stairs. I know a lot of things can go wrong...but I think it's a better choice than turning it on it's side like my husband wants to do.
    Champion:
  • 277 Answers
Hi do this as last option! there is 30,000v inside the tv!! you can die before you even think about it the only way to do soo is unplug the T.V from the wall for a week at least (so the volt will dissolves) you can turn the tv on its side you will have a problem if it will get a slap or will fall in my opinion just take on its side....but its your decision JUST BE CAREFUL PLEASE!!! good luck
Posted on Mar 21, 2006
Pioneer 47 inch big screen, was getting dim but would flicker back to normal, now there is just no picture at all but has sound
Sounds like you got a bad connection, that has finally come off.
Moving those big things can cause that.
Open the back and check.
And call an expert.
If ya in VB, I'll do it.
PLEASE RATE THIS ANSWER
Aug 29, 2011 | Pioneer SD-P55A3-K 55" Rear Projection...
I have a 64 inch hdtv pioneer projection monitor sd-643hd5 and it won't fit into my basement. What can I do? Thank You In Advance, Bruce Morash
Ha Ha, I had the exact problem. I think mine is the same model of TV as well, I have a 64" Pioneer made in 2003. So my TV would hit the slanted ceiling above my stairs as I tried to move it down. I first took off the wheels of the TV and this helped but it was not quite enough. So since the bottom of the TV is flat with exception of the side boards and the front trim. I removed the front trim temporarily and cut off the side boards with a circular saw till even with the flat bottom. This gave me 2.5" more clearance which was enough to fit the TV downstairs. Hint if you scribe the cut line with a utility knife it will reduce chipping.
TimBilt
Mar 28, 2011 | Pioneer SD-643HD5 64" Rear Projection...
My big screen tv is about 3 inches to big to take down my stairs into my basement. Can it be dissasembled? Are there any sketches on how to dissasemble the speakers? Thanks Don
Yes but it would be easier to widen the stairs and just moving them can stop them from working so if you decide to take it apart just be careful, Manuals are available online but non are free
Dec 02, 2010 | Samsung HLT6187SAX 61" DLP HDTV
I want to move my 65 inch mitsubishi from the ground floor to the second floor of my house where will i get the instruction on how to disassemble it.
Don't disassemble this tv,it have very sensitive CRTS Tubes assemblies.U take it aparts,it will not funsctions the same way again or not at all.Buy another tv smaller lighter take it up stair.
Jun 15, 2010 | Mitsubishi WS-65807 65" Rear Projection...
My Pioneer 55 inch screen tv SD-P5553 has a solid black horizonta
This sounds like a picture mode issue. You maybe in a ZOOM mode. Try adjusting your set to FULL mode. If you are using a Sat receiver or cable box, some of these may have picture viewing mode as well, wich may need to be set in FULL or NORMAL viewing mode.
Good Luck!
Jan 18, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Cabinet removal
Unfortunatly no there isnt. The tv bottom contains all the circuits, color guns, speakers. From where the bottom of the screen starts to the top is all part of the entire cabinet which is molded plastic. The top part contains a mirror and the screen you see as well as possibly a remote sensor. Short of sawing it in half and tossing it away you could take it apart but this would have to be done completely to gain you the most space and could be dangerous considering the high voltage transformer that the unit uses to power the color guns.
Mar 07, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Disassemble Rear Projection TV
well the short answer is : Check the sides of the set see if there is a crack in the middle where you could separate them
Long answer: i would not recommend it even if it does, the screens are sensitive and could get dust inside the screen.
Never taken one apart that far. i suspect most tech don't because of the problems aligning and dust ect.. trying to get it back together.
Dec 13, 2007 | Philips 60PP9202 60" Rear Projection...
Relocating tv
Yes, this set does come apart for moving. Remove the lower screw from each side of the TV back. On both sides, pull off the two plastic caps and remove the two exposed screw. Lift the cabinet top straight up until the guide pins clear the holes in the bottom cabinet. Be careful and don't drop anything.
May 03, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Pioneer SD-P55A3-K 55" Rear Projection Television Logo
1,678 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
