Question about Dryers
Admiral Dryer model ADE7000AYW
The dryer does not start like there is no power. I changed fuses ans checked pigtail connections. Any suggestions?
  • Anonymous Sep 10, 2008
  • buckostuco Dec 30, 2008
    The admiral dryer I have just did the same thing today; First it seems like a problem with overheating. Clean out the duct and check breakers; If you have a AC/ Volt meter check for current to outlet....Carefull as it is 240V.
    The most likely culprit is the High Limit fuse. Once the Hi Temp thermostat over heats due to clogging of ductwork, the Hi Temp fuse blows so that the unit doesn't catch on fire. There is no repair except replace the Fuse.
    You can get both a sensor and a fuse at, about $30 dollars and 30-60 minutes and it should work fine.
SOURCE: Dryer not starting
Dryer needs a new motor. I changed the thermal fuse and the dryer worked for a minute then stopped without the ability to restart.
Posted on Jul 08, 2008
SOURCE: how to access heating element and thermostat on Admiral ade7000ayw dryer
The top has a hinge bracket in the back. pop the front up with a flat screw driver. you should see the heating element there and be able to access it from that point.
Posted on Aug 21, 2008
  • 291 Answers
SOURCE: maytag electric dryer not heating
To check the block put meter on 220 volts touch the end of the leads to the outside wires of block.. black and red... should give reading of 220V. IF no reading try one lead at a time with neg side of v meter on ground if you get a reading of 110 one side of the 220 is not coming thu and could be your problem
made sure u checked the hi limit fuse on burner for continuity also
Posted on Nov 01, 2007
  • 2651 Answers
SOURCE: need to change dryer pigtail
3 wires, black and red goto either side, and the white goes to the center terminal , if you have a green(ground) that attaches on the body of unit itself
Posted on Dec 07, 2008
SOURCE: Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Posted on Jan 01, 2010
If an "Admiral" dryer stops getting warm or hot, wouldn't it be the hot/warm selector switch?
it could be the element burnt or restricted venttube or maybe even a burnt wire from the pigtail take the cover off where the pigtail goes into the dryer and see if one of the wires burnt
Jan 08, 2013 | Admiral Dryers
Admiral dyer model ade7000ayw wont make heat
You will need to replace the heating element and the thermostat. They come in a kit and is a simple job to replace them. Here is a link to the kit.
Oct 14, 2012 | Admiral Dryers
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
I have a maytag admiral dryer (ade7000ayw) stopped working over tonight? It's plugged in and the outlet has power.
The thermal fuse is what the problem very likely is. It is located on the side of the heater housing on the upper part of the back wall of rear drum support. To check it UNPLUG DRYER,remove the 2 white wires on the right side of where the heat element goes and check the thermal fuse for continuty (zero ohms resistiance) using a meter set to measure ohms of resistiance
Aug 12, 2011 | Dryers
ADMIRAL ADE7000AYW This dryer will not start at all. Light inside is not on. There is power at the plug. Is there a internal breaker
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Jun 18, 2011 | Dryers
I have an Admiral ADE7005AYW that will not start. We have checked the plug and it is fine but the dryer will not turn on or light up. What could be the problem?
I f the cord is ok where it connects inside the dryer then There are several other things that could cause this.
A couple of the more common things to check are:
1. You could have a defective door switch. you can check the switch with an ohm meter for continuity.
2. You could also have a bad thermal fuse.Also check this thermal fuse for continuity. this fuse shuts the dryer down if it over heated. if the thermal fuse is bad check your venting for blockage or crimping.
Jul 11, 2010 | Whirlpool LER5636P Electric Dryer
Kenmore Washer Model 417 44052400 will not turn on at all. Only sign of life is a beep when press the reset/cancel button. Any suggestions?
first of all check with an electric meter to see if the proper voltage is going into the dryer from the outlet
If you have proper voltage from the wall outlet (in USA it's mostly 240 volts for a standard full size dryer) then check where the pigtail, cord, goes into the back of the dryer to insure the connections are tight.
If all of the above checks out as good then my first thought would be the start button since the power goes straight from the cord to the start button then proceeds to the dryer components.
Hope this helped
Mar 18, 2010 | Washing Machines
Heating element only turns red when dryer door is open
You are correct you do have a dead short on the element.You need to replace the element.Hope i fixya :)
May 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not starting
Jul 05, 2008 | Dryers
How to access heating element and thermostat on Admiral ade7000ayw dryer
May 21, 2008 | Dryers
Dryers Logo
1,549 people viewed this question
Top Dryers Experts
