Question about KitchenAid Kitchen Ranges
We just bought the KitchenAid 4.8 Cu. Ft. Self-Clean Electric Smooth Top Convection Range (YKERS205TS)at FutureShop. The features indicate that there is a warming drawer wwhich was very important to us. However, now the range was delivered, we can't figure out how to use the warming drawer. We do have a drawer, but it is looks much more like the storage drawer that we had with our old stove.
There is no warming drawer, only the YKERS807 has the warming drawer
Posted on Sep 24, 2008
How can I clean burned tin foil from the bottom of my gas range
You may have to scrub it off using something that will not destroy the bottom material.
Sep 16, 2016 | Samsung FX510BGS 30" Freestanding Gas...
Trying to use self clean feature on my 2009 themador wall oven and E106 code appears?
Are you sure of the error code number? A list that I found only goes from E1 to E15 and F0 thru F9 & also a Fd code. Double check the code and respond back to me and I will see if I can help you further.
Aug 01, 2014 | Thermador Masterpiece MEDMCW71JS 27"...
LED screen fogs up when an oven and range are on at the same time.
The seal on the display is broke and you will need to replace the board. Eventually it will short out from the moisture. Here is that part to order.
All parts come with a 365 day, any part, any reason return policy.
Oct 21, 2013 | KitchenAid KDRS483VSS 48" Commercial-Style...
The burner in question is the center back the indicator light stays on even in off mode
u may have a bad switch.. if the light stays on while all burners are off.. u will have to check each switch one by one to get the right one..
Dec 12, 2012 | DCS Professional RDU486GLL 48" Pro-Style...
My oven is locked and i can not get it to open. i used the self cleaning maxx clean, and it beeped about 20 minutes before the 4 hours were up.
Here is a tip that I wrote about the self cleaning feature and the pit falls of it...
Also contains some ideas on how to get the thing unlocked...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Mar 30, 2010 | Electrolux EW30ES65GS 30" Slide-in...
When using the convection roast, does setting it to 325 show on the display as 300? I am cooking my turkey at 325 and display reads 300.
Your range has the feature called auto recipe conversion,that means it will automatically adjust your settings to compensate for the changes when useing either convection modes, bake or roast,rest assured you turkey will turn out perfect with convection roast. Remember that raosting time will be slightly reduced also with convection roast bakeing. Have a wonderfull Thanksgiving and Holiday season. Good luck !
Nov 26, 2009 | LG 30 in Kitchen Series Dual Convection...
Hi, My LG Dual Convection oven is taking over one
mine too. it took 2 hrs to get to 300. Self cleaning does not get hot enough to clean. it seemed to work for a day after that, but is not working again. i got the error F-7 but can't locate my book to see what that means. the stove is only 1 year old....have you found an answer to your problem??
Kitchenaid DF Range F04 error code
I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
LG Kitchen Series Electric Range Smooth touch controls POSESSED!
The is a tough one if there is no tech there. I have not heard of this problem as yet. There could be a loose connection in one of the ribbon cables or it could just be a defective board.
You can try putting it in to test mode to see if it can self diagnose itself.
Press 'favourite' and 'settings' at the same time, 'diagnois' will appear, press them again and the prompts will appear. Note make sure the top surface is clear as well as the oven. If an error pops up at least you will know what is wrong with it. There is also a tech sheet on the back with the fault codes.
side note, do not put alluminium foil on the bottom of the oven cavity.
Sgt 48
May 29, 2008 | LG 30 in Kitchen Series Dual Convection...
Kitchen Ranges Logo
672 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
