Question about Sony Cyber-Shot DSC-F717 Digital Camera
Battery will not charge
Have tried new battery and won't charge- will only work with power supply. What do you think is problem and remedy
Well i think that your battery is not rechargable... hehe...
Posted on Oct 09, 2008
My car will not start. The battery is new and has a full charge and turns everything on when I turn the key but when I try to start it, it will not do anything not even clicking noise.
if the battery is good it is NOT the alternator. the alternator charges the battery, if it won`t start with a new battery the alternator does nothing to affect the situation. check voltages at the starter motor connections for proper voltages even the wires that the ignition switch supplies power to. if you have proper voltages at the starter you can try hitting the starter while someone tries to start the car. if it starts the starter is worn internally and will have to be replaced.
Aug 05, 2015 | 2003 Hyundai Santa Fe
My hp pavillion laptop will not charge my battery . It won't even work without the battery but plugged in with power supply even though i know battery and power supply are sound.
It won't ever be a 'software' issue....it will be either a :
Adapter/Charger issue (Have it tested by local PC repair shop.)
if it is good, then it is the other prob. If it is not good, then buy a new one.
OR
Laptop power connector issue. (expensive repair.)
Sep 06, 2012 | Toshiba Satelitte M300 St3401 Core 2 Duo...
My hp pavilion dv4 laptop's battery cannot sustain even for 1 hour.please give some ideas to maintain the battery and is there any remedy for this issue.Also which is better among, using laptop always...
If the battery appears to be charging, the drop in the time it sustains power is likely due to a faulty or old battery. Eventually it will appear 100% charged and drop to zero in 5 minutes or less. I would think you need to replace the battery.
If you want to maintain the battery properly, it is best to remove it once fully charged and use on ac power alone. If using the laptop on battery, remove the AC connection and allow the battery to fully discharge before recharging it ( there is some debate on this method, other may disagree)
Jul 14, 2011 | Computers & Internet
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Toshiba Laptop will not stay on
Yes, you need to get a new battery pack since it does not charge anymore.
Jul 29, 2009 | Computers & Internet
My laptop wont come on (Dell Inspiron 2200)
I have experinced the same issue with the Dell laptops.
My remedy was to purchase a new power supply..(This is the name of the power cord that came with your laptop). You can purchase the power cord from any computer store.
Ask he sales person if you can try the new power cord prior to leaving the store just to make sure this solution works.
I hope this solution works for you as well.
Feb 10, 2009 | Dell Inspiron 2200 Notebook
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
Garmin 330 battery
"my garmin c330 will not charge in the car while traveling?it has a full charge when i head out but after 4 hours it shows low battery,i was thinking the gps was supose to charge with the car adapter plug in.my will not charge."
There is a problem with the cable or the cigarette lighter power supply. If the cigarette is working then when you start the car the Garmin should turn on and when you turn off the engine the Garmin should shut down. If you are manually turn the unit on/off then it is not running off the cigarette lighter power supply. Check to make sure there is power coming from the cigarette lighter.
Aug 11, 2007 | Garmin StreetPilot C330 GPS Receiver
Sony Cyber-Shot DSC-F717 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
John Peabody
John Peabody
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
