Question about D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337)
Dlink When I leave the computer either on or on sleep, it disconnects from the internet and I have to shut down to be able to restart. Shut and restart does not work.
    Problem Solver:
  • 8 Answers
There is a setting in the router configuration that enables the router to disconnect at a specified period when inactive.
Posted on Sep 10, 2008
Where is the sleep button on my Lenovo laptop computer?
The sleep button is with the place you would go to shut down your computer. It will either say shut down, restart or sleep. Hope this helps
Mar 16, 2015 | Lenovo Computers & Internet
Toshiba satellite L750-iq6 won't shut down or sleep?!?
That is a software issue with the OS. Was it always like this? If not, try a system restore to some time in the past when you know the unit was working fine.
Sep 06, 2017 | Toshiba Satellite L750 Notebook
I am unable to access the internet from sleep mode Can only get on internet from shut down mode
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
Dec 20, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
Mac cannot see 750GB maxtor 4
Did you disconnect the firewire drive before installing? You may need to update your firmware. Also, try these things:
1. Shut down and disconnect your firewire drive leaving nothing is connected to the firewire ports.
2. Restart, and use Disk Utility to repair permissions on your internal.
3. Shut down, and disconnect the AC power from the computer and your drive; also remove battery if laptop.
4. Let computer sit unpowered and disconnected for15 minutes.
5. Reconnect AC power to only the computer and reinsert battery.
6. Restart computer.
7. Verify that firewire ports are visible using System Profiler.
8. Reconnect your firewire drive, and refresh window in System Profiler to rescan the firewire bus, and confirm that drive is visible.
9. Repair disk and permissions on the firewire drive.
Dec 13, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Internet shut down.
Try changing your power settings to Always On when downloading overnight. If the machine enters sleep or hibernate mode, it will drop any active downloads.
Jun 01, 2009 | Gateway Computers & Internet
Sleep vs Shut down
It depends on how long computer is being used in a day.
for general use
you can shutdown your computer once in 2 days but i highly recommend not to put in sleep mode and betting putting in hibernate mode instead of sleep mode.
note: most of simple issues are resolved by restarting PC so you can guess now how important is to shut down computer.
Good luck,
Mar 25, 2009 | Apple 24" iMac Desktop
My computer does not shut down
Ok
Gonna try and teach you some basic programming :-).
What the following will do, is create you a Desktop Shutdown Icon, which when you double click on it, will hopefully shut down your PC rather then restart it.
So here's how to do it :-).
1. Right click on your desktop and select new > shortcut.
2. In dialog box type “shutdown –s”
3. Click next to continue and then type a name for shortcut (IE Shut Down PC) and click finish.
Now you should see the shortcut on your desktop and will hopefully solve your problem.
Dec 08, 2008 | Computers & Internet
Won't install properly...
Go to your power management setting and turn everything off. I don't know what version of windows you have, so I'll use Windows XP.
Start => Settings => Control Panel => Power Options. Turn all options OFF.
If it disconnects at random you may need to change the channel setting on the cable router.
http://www.wifi-forum.com/wf/showthread.php?t=6768
http://kbserver.netgear.com/kb_web_files/n101668.asp
Jan 10, 2008 | NetGear MA111 802.11b Wireless Adapter
Must boot 2 times to reach internet.
Just a thought...got to Start->Control Panel->Power Options
What are the settings? Is anything shutting down after a short period of time?
When it's disconnected, can you manually reconnect? Have you tried that before rebooting?
What kind of router are you using, have you modified it's settings in any way? I have some other thoughts, but maybe you shoudl answer these questions first.
Dec 19, 2007 | HP Pavilion dv1310 Notebook
D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337) Logo
105 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
