The memory card is pre-formatted. If a memory card needs formatting the phone will request that you format the memory card (the menu for this will appear on the phone). You can't re-format it.
Memory status
You can check the total amount of memory for media items and the amount of memory currently in use in each media box.
Your phone is preset to use FAT16-formatted memory cards.
If you insert a FAT32-formatted memory card, the phone will ask you to reformat the
memory card. If you do not, you will not be able to access the card from the phone. If a folder on a memory card has sub folders which exceed the maximum folder depth supported by your phone’s file system, you may not open or delete the maximum depth sub folders on the phone.
Frequent erasing and writing will shorten a memory card’s lifespan.
• Do not remove a memory card from the phone or turn off the phone while data is being accessed or transferred. This could result in loss of data and/or damage to the card or phone.
• Do not subject memory cards to strong shocks.
• Do not touch memory card terminals with your fingers or metal objects. If dirty, wipe the card with a soft cloth.
• Keep memory cards away from small children or pets.
• Do not expose memory cards in a place subject to electrostatic discharge and/or electrical noise.
I had the card in backwards. So I think this doofus should be shot! lol
