Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Inoperative Ice Maker
The ice maker, located in the door, fails to make ice. The area is cold (certainly cold enough to freeze) and the 'fingers' that move the ice through the tray work. LG customer service had me press and hold the ice size selector button until the mechanical part of the system rotated through a complete cycle. There was no sound of water flowing although I am able to get water from the door dispenser (so water to the entire refrigerator is available). Also there was no motion to the ice-bucket-full detector rod but I don't recall that it ever moved. How does the fridge know that the ice bucket is full? I suspect that the valve controlling water flow into the ice maker tray is bad and that otherwise, things are all playing okay. No proof of this though. Any suggestions? ICE MAKER WILL NOT MAKE ICE. HAVE REPLACEDTHE FILTER BUT THAT HAS BEEN OUT FOR A WHILE. BUTTON ON INSIDE OF FREEZER (ON/OFF) FLASHES.
  • Lee Schickling Sep 11, 2008
    That describes my exact problem. What can you do to see what is the issue.
    I have the exact same issue. What can you do to find a solution or wha tthe issue is?
  • 126 Answers
FROM WHAT YOU SAYING LG HAS MADE YOU DO A SELF TEST ON THE ICE MAKER AND ITS WORKING FINE.YOU NEED TO CHECK THAT YOUR SECOND WATER VALVE AT THE BACK BOTTOM RIGHT CORNER IS WORKING OK THAT MIGHT BE YOUR PROBLEM.GOODLUCK/ MOHAMED
Posted on Sep 12, 2008
Ice maker not getting water on new refrigerator
Check if the unit has a cold water dispenser that it will fill a cup. If so than problem is with Ice Maker. If not than problem is with water supply to unit.
If water to machine works make sure that the arm on the ice maker is in the down position. If it is up it will disable the ice making unit. Cycle the am a few times to insure that the switch connected to the arm has not gotten stuck in the off position.
On some ice makers there is a separate switch to disable the Ice maker usually right on the ice-maker not easily missed.
It is possible that the water feed tube into the Ice Maker has become frozen where it enters into the back of the freezer at the top. You can look through to see where the water fills into the cube tray. If ice is present it would be an indication that the feed tube has become frozen If suspected the safest way to fix would be to turn off the unit and allow for a manual defrost.
Next check the operation of the ice maker. Locate the arm in the up position prohibiting the ice maker from cycling. Wait three hours or more. Open freezer door and return the arm into the down position. After a few minutes you should observe the ice fingers rotating to release the cubes into the tray. If the fingers do not rotate I would suspect the ice maker or the connecting electrical circuit. Remember after dropping the arm the Ice Maker has to warm up to melt the ice cubes from the tray before the fingers are told to rotate,
If the fingers rotate then I would expect that the water supply solenoid has failed inside of the unit near to the location the the water supply is made. Replacing this part needs to be done by a qualified experienced technician.
Nov 15, 2015 | Refrigerators
Samusung RFG297HDRS Ice maker not cold enough to produce ice.
Suspect that the rubber boot that runs all around the edge of your freezer door is deformed, allowing warm air to seep into your freezer. You will see where your temp sensor is located by clicking into the site of a parts supplier like ShopJimmy.com and pulling up their photo of the guts of your unit.
Oct 29, 2014 | Samsung RFG297HDRS Stainless Steel
Ge bottom freezer not freezing
Check to see that the evaporator is not covered with layer of ice. The latter serves as an insulator and prevents freezer temps from going down to about zero degrees. If the defrost heater/timer is defective that will certainly be a cause. Since the freezer air is not cold enough to freeze, then the refrigerator temps are also high. Using a digital thermometer will confirm this.
Leaking door gaskets can also be responsible for higher internal temps
May 17, 2014 | GE GFSF6KKYWW 25.9 cu. ft. French-Door...
Freezing fingers will not freeze the ice, will not get cold...any suggestions?
you have a frigid air ice maker w/ the fingers ice maker? call a service tech. that's the most difficult ice maker to work on, and you cant get much help over the internet in my opinion.
Aug 05, 2013 | Refrigerators
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
Our ice maker has stopped making ice. I've replaced the water filter (we are still getting water through the door), the "arm" is in the down position, and the temperature is cold enough. Any...
If the cube slots are empty try filling with tap water and allow to freeze while arm is down. If cubes drop and the ice maker does not refill with water then the dual water control valve=> 67005154 Dual Water Control Valve Another possibility is the ice maker thermostat pictured here=> MZD2669KES Ice Maker Parts Breakdown item 13 in photo. If the test fails then it is sometimes better to buy the complete ice maker=> 7824706Q Ice maker Module
Jan 26, 2011 | Maytag MZD2669KES Stainless Steel Side by...
Hooked up water to frig and got water in door but no water to icemaker. Any ideas?
Make sure the lever is down on the ice maker . Also , can pour about 2/3 cup of water into ice maker , so it will freeze and start the cycle . Otherwise , wait , and when the ice maker gets cold enough , it will cycle on its on to start the ice making procedure . If you get water to the door , then it's connected properly , and water will go to the ice maker , if the water valve and ice maker are in working order .
Sep 09, 2009 | Kenmore Refrigerators
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Icemaker
IT DOESNT MEAN YOU GETTIN WATER IN THE WATER DISPENSER THAT THE VALVE IS OK.MOST FRIDGES ARE FITTED WITH TWO VALVES.CHECK THAT THE ICE MAKER VALVE IS WORKING IF THATS OK YOU MIGHT HAVE A PROBLEM INTERNAL ON THE ICE MAKER BEST YOU GET A TECHNICIAN TO CHECK THAT.GOOD LUCK.MOHAMED
Sep 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
The icemaker stops working because excessive water gets into the control box(where circuit board is housed) through the shaft hole of "finger" and freezes the wheels to turn the "ice-bucket-full detector rod". This stops to send the signal to open water valve.
To fix, remove the icemaker from the wall (need remove two screws - make sure power switch is OFF) and carefully separate the snap-on cable (retangular shape) and a ground cable on the bottom side of the icemaker. (Now you can remove the icemaker out of the refrigerator).
You can open the contol box (need unscrew one and carefully prop it open using a screw driver or a knife. You can unplug color corded snap-on cables for easiness to work (very simple).
You will see ice formed around the plastic gear wheel controlling the "ice-bucket-full detector rod". Remove all ice and dry all the parts in the box and put them back. Make sure all the cable are back to the matching color receptable(only fits in the right place). Connect the cable(rectangular shape) and connect the ground cable. Mount the incemaker on the wall using two screws you removed at first.
Turn the power ON and reset the system by press down the ice cube size selector until the "fingers" make a full cycle. You will see the metal rod moves up and down as system resets. During this cycle the water will be filled into the icemaker.
I believe this icemaker has a design flaw but it's very simple to correct the problem you are experiencing. You do not need much electronic or mechanical knowlege to fix this.
Best wishes
Young
Jun 15, 2007 | LG LFX25960ST Stainless Steel French Door...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
186 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
